Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
  1. Create a new solution
  2. Opne an existing solution
  3. Save solution...
  4. Open asset library generator dialog...
  5. Open safety asset library generator dialog...
  6. Run/Stop Player/Embedded Player, Update Embedded Player
  7. Select Player/Embedded Player setting
  8. Open automation scripts dialog...
  9. Undo
  10. Redo
  11. Add a new 2D scene
  12. Add a new 3D scene
  13. Add a new safety scene
  14. Select active scene
  15. Select perspective (Scene Design/Animation Design/User created perspective)
  16. Open Culture solution option dialog
  17. Select culture
  18. Create new animation
Select animation Start animation Stop animation Animation fast forward speed Animation fast forward Go back to one previous active item Go forward to one previous active item Edit current profile Add a new profile Delete current profile Select profile Start the execution of the script system Stop the execution of the script system
Icons through 18 to 25 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Navigation:Animation: 18 and19,to 23, Navigation: 24 and25, Editor Profiles: through 2026 to 23,29, Scripting System: 2430 and 25)31)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
