Tool bar
The toolbar is lined with icons for frequently used operations.
Each number in the image below corresponds to the below icon descriptions.
- Create a new solution
- Opne an existing solution
- Save solution...
- Open asset library generator dialog...
- Open safety asset library generator dialog...
PlayRun/StopselectedPlayer/Embeddedscenario...Player, Update Embedded Player- Select
playerPlayer/Embedded Player setting - Open automation scripts dialog...
- Undo
- Redo
- Add a new 2D scene
- Add a new 3D scene
- Add a new safety scene
- Select active scene
- Select perspective (Scene Design/Animation Design/User created perspective)
- Open Culture solution option dialog
- Select culture
- Go back to one previous active item
- Go forward to one previous active item
- Edit current profile
- Add a new profile
- Delete current profile
- Select profile
- Start the execution of the script system
- Stop the execution of the script system
Icons through 18 to 25 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Navigation: 18 and19, Editor Profiles: through 20 to 23, Scripting System: 24 and 25)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
