Tool bar
The toolbar is lined with icons for frequently used operations.
  1. Create a new solution
  2. Opne an existing solution
  3. Save solution...
  4. Open asset library generator dialog...
  5. Open safety asset library generator dialog...
  6. Play selected scenario...
  7. Select player setting
  8. Open automation scripts dialog...
  9. Undo
  10. Redo
  11. Add a new 2D scene
  12. Add a new 3D scene
  13. Add a new safety scene
  14. Select active scene
  15. Select perspective (Scene Design/Animation Design/User created perspective)
  16. Open Culture solution option dialog
  17. Select culture
  18. Go back to one previous active item
  19. Go forward to one previous active item
  20. Edit current profile
  21. Add a new profile
  22. Delete current profile
  23. Select profile
  24. Start the execution of the script system
  25. Stop the execution of the script system
Icons through 18 to 25 can be shown or hidden from the menu bar under [ View > Toolbars ]. (Navigation: 18 and19, Editor Profiles: through 20 to 23, Scripting System: 24 and 25)
By mousing the separators in the toolbar, you can customize the placement of icons on a separator-by-separator basis.
