Adding HMI Logic
Using Behaviors Behaviors
- Car_Cluster is displayed in Scene Tree.
- ExtraSceneTree is displayed at the right-side view of Scene Tree.
- The behaviors of RPMGauge are shown in ExtraSceneTree.
- On the top part of the Toolbox, there is a search bar to easily find nodes or behaviors that are needed.
6. Click the browse button on the right-side of TargetNode TargetNode
- Through this operation, the value of RPMGauge control is automatically forwarded to the RPMValue control.
8. Repeat steps 2 to 7 from above for SpeedGauge control.
- For SpeedGauge control, select SpeedGauge_Group > SpeedValue as TargetNode in Step 7.
Adding Multilanguage Features
- The "Solution Options : Cultures" dialog is displayed.
- This dialog is also accessible through the menu bar by selecting File > Solution Options… > Cultures.
3. Select English [en] from the Culture drop-downlist.
- Car_Cluster is shown in the scene tree.
- ExtraSceneTree is shown in the right-side on the Scene tree.
- StatusBottom is expanded and items Temp, Petrol and Odometer are shown.
8. Click Odometer.
9. In the Properties, under Control category, click the browse button next to the input field of the Format Text property.
- The Language Table dialog may also be opened via the menu bar Language > Language Table…
- The drop-down on the top right allows selection of the Current Culture.
| Target item | Setting value |
| Text | Trip: %04d km |
| Translation Hint | mileage |
| Culture | Setting value |
| English[en] | Trip: %04d miles |
| German[de] | Trip: %04d km |
14. After the previous set-up, click the OK button to close the dialog box.
- When English[en] is selected, the unit is “miles”.
- When either Master[00] or German[de] is selected, the unit is “km”.
In this section, simulation will be run via CGI Player based on the settings made in Using Behaviors and Adding Multilanguage Features.
- Refer to Run CGI Player and Run simulation by Value Generator how to operate.
- Based on the settings of Using Behaviors, the value in the center of the Gauge must be changed according to the Gauge needle value.
| Items | Setting value |
| RPMValue | 8000 |
| SpeedValue | 240 |
- When en (English) is selected, “miles” should be shown accordingly.
