Adding HMI Logic
Using Behaviors
  • Car_Cluster is displayed in Scene Tree.
  • ExtraSceneTree is displayed at the right-side view of Scene Tree.
  • The behaviors in RPMGauge are shown in ExtraSceneTree.
  • On the top part of the Toolbox, there is a search bar to easily find nodes or behaviors that are needed.
6. Click the browse button on the right-side of TargetNode
  • Through this operation, the value of RPMGauge control is automatically forwarded to the RPMValue control.
8. Repeat steps 2 to 7 above for SpeedGauge control.
  • For SpeedGauge control, select SpeedGauge_Group > SpeedValue as TargetNode in Step 7.
Adding Multilanguage Features
  • The Cultures solution options dialog is displayed.
  • The Culture Solution Options is also accessible in the menu bar by selecting File > Solution Options… > Cultures.
3. SelectEnglish[en]fromtheCulturedrop-downlist.
5. Press OK button to close the dialog box.
  • Car_Cluster is shown in the scene tree.
  • ExtraSceneTree is shown in the right-side on the Scene tree.
  • StatusBottom is expanded and items Temp, Petrol and Odometer are shown.
8. Click Odometer.
9. In the Properties, under Control category, click the browse button next to the input field of Text property.
  • The Language Table dialog may also be opened via the menu bar Language > Language Table…
  • The drop-down on the top right allows selection of the Current Culture.
Target item Setting value
Text 78.321km
Translation Hint mileage
Culture Setting value
English[en] 78.321miles
German[de] 78.321km
14. After the previous set-up, click OK button to close the dialog box.
  • When English[en] is selected, the unit is “miles”.
  • When either Master[00] or German[de] is selected, the unit is “km”.
In this section, simulation will be run via CGI Player based on the settings made in Using Behaviors and Adding Multilanguage Features.
Items Setting value
RPMValue 8000
SpeedValue 240
  • When en (English) is selected, “78.321 miles” should be shown accordingly.
