Patch installation procedure
1. Start Installer
1.1 Allow app to make changes to computer
If
When you allowrun appthe to make changes to computer,installer, you arewill be asked if you want to apply the patch.patch Otherwiseif this installer has your permission to make changes to your computer. If not, this process iswill stopped.stop. You can restart anytime.at
any
time.
1.2
Apply Patch
You arewill be asked if you want to apply the CGI-Studio patch. If
youSelect want[ Yes ] to proceedcontinue with the installationinstallation. youClick needthe [ No ] button to select "Yes".
You can cancel Applyingapplying the patchpatch. with
clicking
"No"-
button. You can restart anytime.
1.3 Extraction Process
A window opens,will showingopen with a progress bar for extracting the compressed data.
1.3.1 Continue
You do not have to click, just wait.
After the extraction processprocess, the CGI patch installer will open.
    To cancel the extraction process, press the [ X ] button (orange box below) or the [ Cancel ] button (red box below) in the upper right corner of the window.
      Pressing any of the buttons will bring up a dialog to reconfirm work cancellation. To execute the work cancellation, press the [ Yes ] button. To cancel the work cancellation and continue the extraction process, press any button other than the [ Yes ] button.
      After the extraction process, the CGI Studio Patch Installer dialog opens.
      1.3.2
      CancellingTo open the release notes (PDF) about the patch, click the [ Open Patch InstallationNotes ] button (orange box above).
      The
      Youpatch haveinstaller twodisplays optionsthe tofollowing cancelpatch Extraction: information.
      Button to be clickedVersion Color Function
      CGI
      Studio "X" Green Process stopped, confirm- window opens.version. "Cancel"Customer Blue Process stopped, confirm- window opens.
      APatch secondprovider window(customer opens to ask for confirm:name).
      You have four options:
      Button to be clicked Color Function "Yes"Target OS GreenTarget Patchoperating installationsystem ison cancelled,which Player can be restarted anytime.run. "No"Target Platform BlueTarget Extractionmachine Processname continues.on which thePlayer will run. "X"Patch Number orangeThe Cancellingsequence isnumber cancelled = same as "No"-Button: Extraction Process continues "Cancel" Pink Cancelling is cancelled = same as "No"-Button: Extraction Process continues
      1.4 CGI-Studio - Patch Installer is started
      Afterof the extraction process the CGI Patch Installer opens.
        Version - CGI Studio version Customer - The customer that should receive a patch. Target OS - The target operating system the player can run on.  Target Platform - The target machine the player will run on.  Patch Number - Patch sequence number.patches. Patches must be applied in the correct order.sequence. Patch Files -Number How manyof files to which the patch will be patched.applied. Version Check Compatibility check of the patch.
        To start the Version Check -and Patch compatibility check.
        2. Get Information: Open Patch Release Notes
        For Readingcontinue the Patchinstallation Releaseprocess, Notes (PDF) clickpress the "Open Patch Notes"- Button.
        3. Install Patch
        3.1[ Select CGI-] Studio-button Installation(orange Path
        box
        below)
        You need toand select the path towhere yourCGI currentStudio is currently installed.
          You can also enter the path directly in the red box below.
          As soon as [ CGI-Studio Installation toPath trigger] is selected, a Version Check will begin.
            If all Patches with lower Patch Numbers are applied and target the versionsame Customer, Operating System, CGI Version (Note: Patch Number is different from CGI Version), and Target Platform, then the Patches are compatible. The patches are compatible if they target the same Customer, Operating System, CGI Version (Note: Patch Number is different from CGI Version), and Target Platform.
            The results of the check are displayed in the [ Version Check ] part of the dialog.
              If this check fails (Mismatch), the installation will stop.
              If Match is not displayed, try a different folder path. If the check results in confirmed compatibility (Match) or unknown compatibility (Unknown), installation is enabled and the [ Install ] button is activated.
              If the [ Install ] button is enabled, press the [ Install ] button to continue the installationinstallation. process.
              ClickThe "Select"-Install Button,window aopens typical open-path-dialog appears. You can also inputand the pathpatch directis intoapplied.
              If the greenPatch markedinstallation Textis Box.successful, the message shown below will be displayed.
                Press the [ Exit ] button to complete the Patch installation.
                3.2 Compatibility Check
                Possible Results are:
                If the patch is compatible (Match) or the compatibility status is Unknown the installation will be allowed. "Install"- Button will be available.
                If you did not receive a Match, please try a different folder.
                3.2.1 What to do if problems cannot be solved
                In case of any questionsquestions, please contact our Support team on the CGI Studio Lighthouse.
                3.3 Start Installing Patch
                3.4 Finishing Installation
                The patch installation is successful if you get the following message "Patching done":
                Please click "Exit"- Button to finish the installation process.
                3.5 Cancelling Installation
                Button to be clicked Color Function "X" Pink Patch installation is cancelled, can be restarted anytime. "Cancel" Orange Patch installation is cancelled, can be restarted anytime.
