Patch installation procedure
1. Start Installer
1.1 Allow app to make changes to computer
If you allow app to make changes to computer, you are asked if you want to apply the patch. Otherwise this process is stopped. You can restart anytime.
1.2 Apply Patch
You are asked if you want to apply the CGI-Studio patch. If you want to proceed with the installation you need to select "Yes".
You can cancel Applying the patch with clicking "No"- button. You can restart anytime.
1.3 Extraction Process
1.3.1 Continue
You do not have to click, just wait. After the extraction process the CGI Patch Installer opens.
1.3.2 Cancelling Patch Installation
| Button to be clicked | Color | Function |
| "X" | Green | Process stopped, confirm- window opens. |
| "Cancel" | Blue | Process stopped, confirm- window opens. |
You have four options:
| "Yes" | Green | Patch installation is cancelled, can be restarted anytime. |
| "No" | Blue | Extraction Process continues. |
| "X" | orange | Cancelling is cancelled = same as "No"-Button: Extraction Process continues |
| "Cancel" | Pink | Cancelling is cancelled = same as "No"-Button: Extraction Process continues |
1.4 CGI-Studio - Patch Installer is started
- Version - CGI Studio version
- Customer - The customer that should receive a patch.
- Target OS - The target operating system the player can run on.
- Target Platform - The target machine the player will run on.
- Patch Number - Patch sequence number. Patches must be applied in correct order.
- Patch Files - How many files will be patched.
- Version Check - Patch compatibility check.
2. Get Information: Open Patch Release Notes
3. Install Patch
3.1 Select CGI- Studio- Installation Path
3.2 Compatibility Check
Possible Results are:
| Unknown | ![]() |
| Match | ![]() |
| Mismatch | ![]() |
If the patch is compatible (Match) or the compatibility status is Unknown the installation will be allowed. "Install"- Button will be available.
If you did not receive a Match, please try a different folder.
3.2.1 What to do if problems cannot be solved
In case of any questions please contact our Support team on the CGI Studio Lighthouse.
3.3 Start Installing Patch
3.4 Finishing Installation
The patch installation is successful if you get the following message "Patching done":
Please click "Exit"- Button to finish the installation process.
3.5 Cancelling Installation
| "X" | Pink | Patch installation is cancelled, can be restarted anytime. |
| "Cancel" | Orange | Patch installation is cancelled, can be restarted anytime. |
