Patch installation procedure
1. Start Installer
1.1 Allow app to make changes to computer
If you allow app to make changes to computer, you are asked if you want to apply the patch. Otherwise this process is stopped. You can restart anytime.
1.2 Apply Patch
You are asked if you want to apply the CGI-Studio patch. If you want to proceed with the installation you need to select "Yes".
You can cancel Applying the patch with clicking "No"- button. You can restart anytime.
1.3 Extraction Process
1.3.1 Continue
You do not have to click, just wait. After the extraction process the CGI Patch Installer opens.
1.3.2 Cancelling Patch Installation
"X" Green Process stopped, confirm- window opens.
"Cancel" Blue Process stopped, confirm- window opens.
You have four options:
"X" orange Cancelling is cancelled = same as "No"-Button: Extraction Process continues
1.4 CGI-Studio - Patch Installer is started
2. Get Information: Open Patch Release Notes
3. Install Patch
3.1 Select CGI- Studio- Installation Path
3.2 Compatibility Check
Possible Results are:
If you did not receive a Match, please try a different folder.
3.2.1 What to do if problems cannot be solved
In case of any questions please contact our Support team on the CGI Studio Lighthouse.
3.3 Start Installing Patch
3.4 Finishing Installation
3.5 Cancelling Installation
