Patch installation procedure
Start Installer
1) After confirming that you want to allow this app to make changes to your computer...
2) you are asked if you want to apply the CGI-Studio patch. If you want to proceed with the installation you need to select "Yes".
You can cancel Applying the patch with clicking "No"- button or not allowing app to make changes to computer earlier.
Extraction Process
You do not have to click, just wait. After the extraction process the CGI Patch Installer opens.
Cancelling Patch Installation
"X" Green Process stopped, confirm- window opens.
"Cancel" Blue Process stopped, confirm- window opens.
You have four options:
"X" orange Cancelling is cancelled = same as "No"-Button: Extraction Process continues
CGI-Studio - Patch Installer
Get Information about Patch: Open Patch Release Notes
Select CGI- Studio- Installation Path
Compatibility Check
Possible Results are:
Install Patch
Cancelling Installation
