Patch installation procedure
Start Installer
1) After confirming that you want to allow this app to make changes to your computer...
2) you are asked if you want to apply the CGI-Studio patch. If you want to proceed with the installation you need to select "Yes".
Extraction Process
You do not have to click, just wait. After the extraction process the CGI Patch Installer opens.
Cancelling Patch Installation
| Button to be clicked | Color | Function |
| "X" | Green | Process stopped, confirm- window opens. |
| "Cancel" | Blue | Process stopped, confirm- window opens. |
You have four options:
| "Yes" | Green | Patch installation is cancelled, can be restarted anytime. |
| "No" | Blue | Extraction Process continues. |
| "X" | orange | Cancelling is cancelled = same as "No"-Button: Extraction Process continues |
| "Cancel" | Pink | Cancelling is cancelled = same as "No"-Button: Extraction Process continues |
CGI-Studio - Patch Installer
- Version - CGI Studio version
- Customer - The customer that should receive a patch.
- Target OS - The target operating system the player can run on.
- Target Platform - The target machine the player will run on.
- Patch Number - Patch sequence number. Patches must be applied in correct order.
- Patch Files - How many files will be patched.
- Version Check - Patch compatibility check.
Get Information about Patch: Open Patch Release Notes
Select CGI- Studio- Installation Path
Compatibility Check
Possible Results are:
| Unknown | ![]() |
| Match | ![]() |
| Mismatch | ![]() |
Install Patch
Cancelling Installation
| "X" | Pink | Patch installation is cancelled, can be restarted anytime. |
| "Cancel" | Orange | Patch installation is cancelled, can be restarted anytime. |
