Patch installation procedure
After confirming that you want to allow this app to make changes to your computer you are asked if you want to apply the CGI-Studio patch. If you want to proceed with the installation you need to select "Yes".
After the extraction process the CGI Patch Installer opens.
You need to select the path to your current CGI-Studio Installation to trigger the version check and to continue the installation process.
Compatibility
The version check starts as soon a CGI-Studio folder is selected. If compatibility check fails, installation will be prohibited. If the patch is compatible or the compatibility status is unknown the installation will be allowed.
The patch is compatible if all the patches with lower patch number have been applied and is targeting the same customer, operating system, cgi-version (note: patch number is separate from the cgi-version) and platform.
After the version check is successful or unknown please select Install to continue the installation.
