Patch installation procedure
Self-Extracting Archive
Installation
The patch installation is done by the patch installer.
Compatibility
The compatibility check starts as soon a CGI-Studio folder is selected. If compatibility check fails, installation will be prohibited. If the patch is compatible or the compatibility status is unknown the installation will be allowed.
The patch is compatible if the patch number is one above the patch number in the current installation and is targeting the same customer, operating system, cgi-version (note: patch number is separate from the cgi-version) and platform.
