Creating a new Solution
The first step is to create a new Solution for Scene Composer. A Solution can be thought of as a project file which contains all resources for a single project. The easiest way to create a new solution is to select one of the available templates.
- Double-click on the Empty template under Samples and Templates.
* Selecting “Empty” template creates a new solution based on the template. - Click save icon in the menu bar.
- A dialog box appears, allowing you to select an appropriate location. Input QuickStartSolution as the file name.
