Default Adjustments
An adjustment is specified by a mode and a delta. Mode defines the way of the distortion, delta defines the amount. The following modes are available:
    Parallelogram Trapezoid Pin balance Pincushion Shift Width Height Rotation (around bitmap image center point)
    For each reference point and corresponding shift vector, the adjustment is computed and applied. The resulting shift vector is again cached in the warping library. This way of implementation allows incremental adjustments.
    Following are tables detailing supported adjustments:
    Mode
    Direction Trapezoid Parallelogram Pincushion Pin balance Up
    Left
    Right
    Mode
    Direction Height Width Rotation Shift Up
    Down
    Left
    Right
