Rotation and Zoom of Render Targets
CGI Studio HMI Rotation
It might occur that a hardware display that is designed for landscape mode (horizontal orientation) is installed into an environment where it is actually used in portrait mode (vertical orientation). This would mean, the designers and programmers would have to create the HMI rotated by 90° and arch their neck whenever they want to check if it looks fine.
To support tricky usecases like that, CGI Studio Scene Composer offers a convenient HMI rotation feature that goes far beyond this particular case. The user can design and program his HMI the way it will finally be displayed. The necessary rotation will be added separately. You can configure to rotate the HMI by 0° (default), 90°, 180° or 270° clockwise.
Example and Configuration
Create a Scene Composer solution with a 2D scene  (you can e.g. use the empty solution provided on the Scene Composer's Start Up screen).
Configure the display for landscape (X 800; Y = 480)
