Set Uniform
Contents List
    Set Uniform
    Set Uniform
    Receives a value and sets the uniform by the name of UniformName property to it - for the node NodeWithShader.
    Common Properties
    Uniform Name FeatStd::String The name of the uniform whose value will be set.
    Node With Shader Candera::Node* Node whose uniform setter's property will be changed.
    Back to the menu
