Set Uniform
Set Uniform
Receives a value and sets the uniform by the name of UniformName property to it - for the node NodeWithShader.
Common Properties
Uniform Name FeatStd::String The name of the uniform whose value will be set.
Node With Shader Candera::Node* Node whose uniform setter's property will be changed.
