Mixed Reality
Contents list
VideoStream
A control that makes it possible to render a video source into a texture.
Properties
| Property Name |
Type |
Description |
| Video Source | String |
URI to video resource (e.g. path to file or URL). Please also see example strings below. |
| Scale To Video Source |
bool |
If enabled the texture will be resized to the video size, otherwise the size of the current texture will persist. |
| Flip Vertically |
bool |
Flips video vertically. |
| Timestamp |
UInt32 |
Can be used to bind the timestamp of the video to an external timestamp data (e.g. a camera tracker that needs to be synchronized with the video). |
| Target Node |
Node | The node on which the video will be displayed. If nothing is selected, the node on the anchor will be used. |
| Blend Type |
BlendType::Enum | The blend type that will be set. |
Examples of valid Video Source strings
| Source |
Example Video Source String |
| From asset |
asset://Resources#Videos#VideoSourceSample1.mp4 |
| From website |
http://www.cgistudio.at/VideoSourceSample2.mp4 |
| From file |
file:///C:/Videos/Streaming/VideoSourceSample3.mp4 |
NavigationPath3D
Visualizes the proposed route of the navigation system. Input points are received via data binding. This control is available for 3D scenes.
Properties
| Property Name |
Type |
Description |
| Mesh Appearance | AppearanceType | The appearance used for the navigation path mesh. |
| Color Mode |
ColorMode::Enum (Color, RGBA) |
Select how color is displayed. |
| Color |
Candera::Color | Determines the color of the mesh. |
| Path Width |
Float |
Determines the width of the mesh. |
| Path Length |
Float |
Determines the length of the mesh. |
| Y Offset |
Float |
Applies y-offset to the mesh. |
| Input Points |
InputPointsType | This property is used to bind input points. |
| Input Point Handling |
InputPointHandling::Enum (Attach, Replace) |
Determines how new input points are used for the mesh. |
| Interpolation Type |
InterpolationType::Enum (Linear, Bezier, Spline, None) |
Determines which interpolation method is used. |
| Path Mesh Type |
MeshType::Enum (Solid, Points) |
Determines which primitive type is used. |
| Advanced |
bool |
Enables advanced settings of the behavior. (see next 6 properties in this table) |
| Input Point Min Distance | Float | Minimum distance of two control points. Input points that are closer together will be rejected. |
| Req Fragment Size |
SizeType |
Size of the fragment that is requested from the input point list. |
| Req Threshold Distance |
Float |
If the distance between camera and the last point is below this threshold, request a new fragment of input points. |
| Num Of Rows Per Input Point |
UInt32 |
Determines how many vertex rows are used to interpolate between two input points. Increasing this value makes the mesh smoother, but will also shorten the distance of the overlay, as number of vertices per row remain constant. |
| Num Of Vertex Rows |
UInt32 | Amount of vertical vertices in the mesh. |
| Num Of Vertex Columns |
UInt32 | Amount of horizontal vertices in the mesh. |
| Blend Type |
PoiManager3D
The PoiManager handles the creation and destruction of POIs. It receives the camera position via event and uses that information to request all POIs in a certain perimeter from the model. The model responds with a list POIs from a dictionary.
For each type of POI, a custom control that serves as a template has to be created and configured with a valid Asset ID. The PoiManager can then instantiate the correct control according to the dictionary from the Asset ID as a child node. However, the PoiManager does not handle the metadata of its children, but simply forwards metadata messages to them. (For more information on metadata handling see Poi Metadata Handler)
Properties
| Property Name |
Type |
Description |
| Street Points |
StreetPointsType |
List of points of the street. Used to align the rotation of |
| Street Points Min Distance |
Float |
Minimum distance between two street points. Street points that are closer together will be rejected. |
| Req Distance |
Float |
The distance in which |
Float |
Once the camera has moved this specified distance a new request will be sent. |
| PoiMetaData |
PoiMetaDataType | Use databinding to receive metadata updates for the POIs |
| Poi Street Name | String | Name of this poi. |
| Street Control Id |
Candera::Id |
ID of the control that is |
| Poi Parking Name |
| Parking Control Id |
Candera::Id | ID of the control that is |
| Poi Building Name |
| Building Control Id |
| Blend Type |
VideoStream3D
This Control makes it possible to render a video source into a texture. The VideoStream3D Control is available for 3D scenes.
It is similar to the VideoStream Control, offering the same properties.
