External Resource
Content List
Action External Resource Behavior
Set External Bitmap
Common Properties
ExternalResourceId String
A unique id of an external resource to be provided.
ExternalResourceManagerId String
A unique id of an external resource manager to retrieve the external resource from.
ImageProvider ExternalBitmapProviderBehavior
External Bitmap Provider that retrieves and provides a bitmap.
Condition External Resource Behavior
Check External Resource Change
Common Properties
Value Processing External Resource Behavior
Retrieves an external bitmap with ExternalResourceId from an external resource provider with ExternalResourceManagerId and provides the bitmap to an associated bitmap node.
Common Properties
TargetNode Candera::AbstractNodePointer
The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
Set External Bitmap
  1. Drag&drop a BitmapNode from the "Nodes 2D" panel of the Toolbox to the Scene Editor or the Scene Tree.
  2. Drag&Drop an External Bitmap Provider behavior from "External Resource > Value Processing" on Toolbox on the BitmapNode in the SceneTree.
  3. Drag&drop two Buttons from the "Control" panel of the Toolbox to the Scene Editor or the Scene Tree.
  4. Drag&Drop a Set External Bitmap behavior from "External Resource > Action" on Toolbox onto the Actions sections on the Extra scene tree of each of the ButtonNodes.
  5. For each of the Buttons, select the Set External Bitmap behavior. Set the "ImageProvider" property to the External Bitmap Provider attached to the BitmapNode clicking on the magnifying glass on the right of the property.
  6. For each of the Buttons, select the Set External Bitmap behavior. Set the "ExternalResourceId" property to a specific external resource by clicking on the magnifying glass on the right of the property.
  7. Run the player and click on first button (the first image is displayed), then second button (the second image is displayedpicture shows up).
  2. Drag&Drop an External Bitmap Provider behavior (which is a Value Processing Behavior) on the BitmapNode in the SceneTree.
  3. Select the External Bitmap Provider of the BitmapNode on the right side of the Scene Tree view. Set the "ExternalResourceId" property using the "Select template for item" button and select an external image from the "Chose External Images" dialog. Alternatively, the resource id can be set manually.
  4. The BitmapNode shows the external resource.
