External Resource
Content List
Action External Resource Behavior
Set External Bitmap
Common Properties
ExternalResourceId String
A unique id of an external resource to be provided.
ExternalResourceManagerId String
A unique id of an external resource manager to retrieve the external resource from.
ImageProvider ExternalBitmapProviderBehavior
External Bitmap Provider that retrieves and provides a bitmap.
Condition External Resource Behavior
Check External Resource Change
Common Properties
Value Processing External Resource Behavior
Retrieves an external bitmap with ExternalResourceId from an external resource provider with ExternalResourceManagerId and provides the bitmap to an associated bitmap node.
Common Properties
TargetNode Candera::AbstractNodePointer
The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
