External Resource
Content List
Action External Resource Behavior
Set External Bitmap
RetrievesSets a bitmapExternalResourceId and setsExternalResourceManagerId the bitmapproperties of thean associated Render NodeExternalBitmapProvider when its action is triggered.
Common Properties
ExternalResourceId
String
Full path
A unique id of an external resource to resource.be provided.
String
External Resource
A Managerunique ID.id of an external resource manager to retrieve the external resource from.
ImageProvider
ExternalBitmapProviderBehavior
External Bitmap Provider Behaviorthat whichretrieves setsand an external image onprovides a node and is the target receiving set resource on action.bitmap.
Condition External Resource Behavior
Check External Resource Change
Reacts on ExternalResourceChangedEvents,ExternalResourceEvent reloadingif and only if the resourceExternalResourceId and invokingExternalResourceManagerId of the event match the condition’s properties, triggering the associated action.
Common Properties
Property Name Type Description ExternalResourceId String
A unique id of an updateexternal ifresource ExternalResourceMangerIdto be provided.
ExternalResourceManagerId String
A unique id of an external resource manager to retrieve the external resource from.
Value Processing External Resource Behavior
Retrieves an external bitmap with ExternalResourceId from an external resource provider with ExternalResourceManagerId and ExternalResourceIdprovides match.
the bitmap to an associated bitmap node.
Common Properties
TargetNode
Candera::AbstractNodePointer
The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
ExternalResourceId
String
Full path
External Resource Manager ID.
Loads a bitmap at scene start from an External Resource Manager using ExternalResourceManagerId  and ExternalResourceId.
Common Properties
Property Name Type Description TargetNode
String
TheA Nodeunique whichid isof modified.an Ifexternal notresource set,manager thento retrieve the nodeexternal whereresource the behavior is attached to, will be modified.from.
ExternalResourceId
Full path to resource. ExternalResourceManagerId
