External Resource
Content List
Action External Resource Behavior
Set External Bitmap
Retrieves a bitmap and sets the bitmap of the associated Render Node when its action is triggered.
Common Properties
ExternalResourceId
Full path to resource.
ExternalResourceManagerId
External Resource Manager ID.
ImageProvider
External Bitmap Provider Behavior which sets an external image on a node and is the target receiving set resource on action.
Condition External Resource Behavior
Check External Resource Change
Reacts on ExternalResourceChangedEvents, reloading the resource and invoking an update if ExternalResourceMangerId  and ExternalResourceId match.
Common Properties
TargetNode
The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
ExternalResourceId
Value Processing External Resource Behavior
Loads a bitmap at scene start from an External Resource Manager using ExternalResourceManagerId  and ExternalResourceId.
Common Properties
TargetNode
ExternalResourceId
