Action Behaviors
Animation Action Behaviors
    Configure and Play Animation
    Class Reference
    Common Properties
    TargetNode
    Candera::AbstractNodePointer The Node which is modified. If not set, then the node where the behavior is attached to, will be modified.
    Animation Candera::Animation::AnimationPlayer The animation that should be controlled.
    Action CgiStudioControl::AnimationAction::Enum Action that shall be executed on the animation:
    Start, Stop, Pause, Resume, Speedup, Finish, Change.
    Direction CgiStudioControl::AnimationDirection::Enum Playback direction of the animation.
    Speed FeatStd::Float Playback speed of the animation.
    RepeatMode
    FeatStd::Optional<AnimationRepeatMode::Enum>
    Defines how the animation shall be repeated.
    Possible values: Replay, Bounce
    RepeatCount
    FeatStd::Optional<FeatStd::UInt32> Count of replays. If set to 0 the animation loops till it gets stopped.
    EventDispatchStrategy
    EventDispatchStrategyType::Enum The way the event gets sent.
    DedicatedBehavior
    Candera::Behavior*
    A dedicated process value behavior that will receive the animation event.
    Advanced Properties
    FinishTime
    FeatStd::Optional<Candera::Animation::WorldTimeType>
    Finish time in milliseconds.
    This property is only available if the property "Action" is checked and set to "Finish".
    IncreaseSdpeed
    FeatStd::Optional<FeatStd::Float>
    Increased playback speed of the animation. If set and Play is executed again during playback, animation will speed up (can be used only once per animation!). Zero means immediate position seek.
    This property is only available in the following configuration:
    an "Animation" is configured
    "Action" is set to "Start" or "SpeedUp"
    "RepeatMode" is not checked
    "RepeatCount" is not checked
    IncreasedSpeedRevertMargin
    Defines trailing part of animation (in milliseconds) that will be played at normal speed again. If not set, speedup will last until the end of animation.
    This property is only available if property "IncreasedSpeed" is checked.
    SequenceStartTime
    FeatStd::Optional<Candera::Animation::SequenceTimeType>
    The start point  of the animation. [ms]
    This property is only available if an animation is set in the property "Animation".
    SequenceDurationTime
    Control Action Behaviors
    Breadcrumb Action
    Class Reference
    An Action Behavior that sends breadcrumb action events. It allows you to control a Breadcrumb or a node with a Breadcrumb Behavior attached. This behavior is available for 2D scenes only.
    • SetPath - sets elements contained in the breadcrumb.
    • BackToPrevious - calls breadcrumb to create a path without the last element from the ones existing in the breadcrumb.
    • BackToElement - the action will be called if the element exists in the breadcrumb. It will create a path from beginning to the selected element from the breadcrumb.
    Common Properties
    Action that will be called on the breadcrumb.
    Possible values: SetPath, BackToPrevious, BackToElement
    Path String
    The path with a separator that will be passed when the action is called. The separator is defined in the receiving breadcrumb.
    BreadcrumbNode Candera::AbstractNodePointer Breadcrumb Control Node.
    Change Selection
    Class Reference
    Sends a ChangeSelectionEvent to the SelectionGroup. The SelectionGroup then sends a ChangeSelectionEvent to all of its receivers. The event is emitted via BubbleEventDispatchStrategy to a SelectionGroupBehavior.
    Common Properties
    Conditional Action
    Class Reference
    Common Properties
    Actions Candera::ActionBehaviorArrayProperty The set of ActionBehaviors that TriggerBehavior invokes in the even that it receives a positive response from Condition.
    Postpone bool Set this flag to true to perform the actions after all other actions have been performed. This may become necessary if the actions alter the state and other conditional actions may be invoked due to that changed state.
    Change Drawer State
    Class Reference
    An Action that allows to hide/show the contents of a Drawer or a Node with a Drawer Behavior attached. This behavior is available for 2D scenes only.
    Common Properties
    Action CgiStudioControl::DrawerEventType::Enum
    The action that should be performed.
    Possible values: Open, Close, Toggle
    Advanced Properties
    DedicatedBehavior Candera::Behavior* A dedicated behavior that will receive the event. Only available when Dispatch Strategy is set to 'DedicatedBehavior'.
    Set Focus
    Common Properties
    FocusCamera Candera::AbstractNodePointer Set the camera node for this focus Action.
    Interpolate Value Action
    Common Properties
    Action InterpolateValueAction::Enum
    Action that will be called on the interpolate value behavior.
    Possible values: SetMode, Reset
    AnimationMode InterpolationAnimationMode::Enum
    Use the InterpolationAnimationMode to select the desired type of animation in the InterpolateProcessValueBehavior.
    Interval Switch Action
    Common Properties
    SwitchState IntervalSwitchState::Enum
    SwitchState: IntervalSwitchState: Enum
    Keyboard Action
    Common Properties
    Action KeyboardAction::Enum
    Keyboard action to execute.
    Possible values: Open, Close, Toggle, InvokeKey, ShiftLayout, SwitchLayout, SetConfiguration
    KeyboardNode Candera::AbstractNodePointer Keyboard Node.
    AutoHideKeyboard bool Should keyboard be hidden when node loses focus and show again when node is focused?
    Advanced Properties
    Layout String
    Layout name.
    This property is only available if "Action" is set to "Open", "ShiftLayout" or "SwitchLayout".
    Notifier
    Event sender. If Notifier is invalid then default is node which has attached behavior.
    This property is only available if "Action" is set to "InvokeKey".
    TextNode
    Text node.
    ImageNode
    ImageNode node.
    FocusNode
    FocusNode node.
    Configuration
    String
    Keyboard configuration.
    This property is only available if "Action" is set to "SetConfiguration".
    Map Action
    Common Properties
    MapNode Candera::AbstractNodePointer Map node on which this action should be called.
    Action MapAction::Enum
    Action that will be called on the MapBehavior.
    Possible values: Reset, Pan, Zoom, Tilt, LookAt, CenterAtLocation, Rotate, SetRotation, ChangeTheme.
    Latitude Float GPS latitude at which the camera looks at.
    Longitude Float GPS longitude at which the camera looks at.
    Zoomlevel Float Determines how close is the camera to the ground level.
    Bearing Float Determines the bearing angle at which the camera is rotated relative to north.
    Tilt Float Determines the tilt angle at which the camera looks at specified location.
    SyleUrl String Theme that describes how the map looks like and how is styled.
    Map Location Action
    Common Properties
    TargetNode Candera::AbstractNodePointer Map node on which this action should be called.
    Latitude Float Latitude of the location.
    Longitude Float Longitude of the location.
    LocationName
    String
    Human-readable name of the location.
    Address String Address of the location (usually street name).
    Navigation Action
    Common Properties
    Action MapNavigationAction::Enum
    Action that will be called on the MapNode.
    Possible values: StartNavi, StopNavi, ReverseRoute
    MenuScreenAction
    Class Reference
    Common Properties
    Action MenuScreenAction::Enum
    Action that will be called on the menu screen.
    Possible values: EditMode, Delete, SwapRight, SwapLeft, AddScreen, DeleteLastScreen
    Page Indicator Action
    Class Reference
    Common Properties
    Action PageIndicatorAction::Enum
    Action to perform on PageIndicator (change number of pages, change active index)
    Possible values: ChangeActiveIndex, ChangeNumberOfPages, ActiveDot
    Value FeatStd::Int32 Value to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
    ChangeValue ChangeValue::Enum
    Type of value change to be sent to PageIndicator (for ChangeActiveIndex and ChangeNumberOfPages actions)
    Possible values: Absolute or Relative
    PageIndicatorNode Candera::AbstractNodePointer PageIndicator node to communicate with.
    RenderNode
    Candera::AbstractNodePointer Render node for current PageIndicatorElement (used only for PageIndicatorElement)
    NormalImagePropertyProvider
    CgiStudioControl::PropertyProviderBehavior*
    Property Behavior which contains the image of normal (unselected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement).
    ActiveImagePropertyProvider
    Property Behavior which contains the image of active (selected) PageIndicatorElement (defines visual aspect of current PageIndicatorElement).
    Set Control State
    Class Reference
    Sets the state of a control by sending an Event to a control considering the selected EventDispatchStrategy.
    Supports: Any Node with a Handle Control State attached.
    Used in: SpinBox
    Example Usage
    Common Properties
    State ControlStateEnum::Enum
    Choose the State which has to be changed to True or False.
    Possible values: Selected, Pressed, Enabled, Highlighted, KeyboardFocused, ScopeFocused, Hover, Touched
    ChangeTo bool Switch the state of the control to True or False.
    UseForChildNodes
    bool
    State change will also affect all child nodes of the target node
    EventDispatchStrategy EventDispatchStrategyType::Enum
    Advanced Properties
    This property is only available when Dispatch Strategy is set to 'DedicatedBehavior'.
    Start Timer
    Class Reference
    Used in: ScrollBar
    See also: Check Timer, OnTimer
    Example Usage
    Common Properties
    Delay FeatStd::UInt32 Delay time for the timer event (specification in milliseconds)
    Custom Action Behaviors
    Click to Message
    Common Properties
    Identifier String The identifier of the click message.
    Copy Textures
    Common Properties
    Appearance
    SharedPointer<Candera::Appearance> The appearance to set on the node.
    Gesture Action Behaviors
    Transform Gesture
    Pan
    • Use the Maximum/Minimum properties for X/Y to limit the movement of the position to a certain area.
    • Use the Pan mode selector to limit the transformation to X or Y axis.
    • Deactivate the Pan to disallow any position change.
    Pinch
    • Use the Maximum/Minimum properties to limit the absolute scale of the node.
    • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to non-uniform scaling where both axis are scaled individually.
    • Deactivate the Pinch to disallow any scale change.
    Rotate
    • Use the Pinch mode selector to either limit the scaling to X or Y axis or to switch to none uniform scaling where both axis are scaled individually.
    Example Usage
    Common Properties
    Pan FeatStd::Optional<PanGestureType::Enum> The pan transformation of a pan gesture is applied to the node.
    Pinch FeatStd::Optional<PinchGestureType::Enum> The scale transformation of a pinch gesture is applied to the node.
    Rotate bool The rotate transformation of a rotate gesture is applied to the node.
    Advanced Properties
    PanMinimumX FeatStd::Optional<FeatStd::Float>
    The minimum pan X value.
    This property is only available if panning in x direction is enabled.
    PanMinimumY FeatStd::Optional<FeatStd::Float>
    The minimum pan Y value.
    This property is only available if panning in y direction is enabled.
    PanMaximumY FeatStd::Optional<FeatStd::Float>
    The maximum pan X value.
    PanMaximumX FeatStd::Optional<FeatStd::Float>
    The maximum pan Y value.
    PinchMinimumX FeatStd::Optional<FeatStd::Float>
    The minimum pinch X value.
    This property is only available if pinching in x direction is enabled.
    PinchMinimumY FeatStd::Optional<FeatStd::Float>
    The minimum pinch Y value.
    This property is only available if pinching in y direction is enabled.
    PinchMaximumX FeatStd::Optional<FeatStd::Float>
    The maximum pinch X value.
    PinchMaximumY FeatStd::Optional<FeatStd::Float>
    The maximum pinch Y value.
    PinchMinimumUniform FeatStd::Optional<FeatStd::Float>
    The minimum pinch uniform value.
    This property is only available if pinching is enabled and configured for ScaleUniform.
    PinchMaximumUniform FeatStd::Optional<FeatStd::Float>
    The maximum pinch uniform value.
    RotateMinimum FeatStd::Optional<FeatStd::Float>
    The minimum rotate value
    This property is only available if rotation is enabled.
    RotateMaximum FeatStd::Optional<FeatStd::Float>
    The maximum rotate value
    Property Action Behaviors
    Set Appearance
    Common Properties
    PropertyReference
    PropertyReference::Enum
    Possible values: Self, Other
    Appearance
    PropertyProvider
    This property is only available if the PropertyReference is set to "Other".
    UseAsDefault
    bool
    True if the image shall be used as default image.
    Send Value as Event
    Class Reference
    Example Usage
    Common Properties
    How the event value shall be handled by the receiving.
    Possible values: Absolute, Relative
    Advanced Properties
    Value FeatStd::Variant
    The value of the event which gets sent.
    This property is only available when the PropertyReference is set to "Self".
    PropertyProvider PropertyProviderBehavior*
    Property provider which contains the value which has to be set on the send value as event action.
    It is only available when the PropertyReference is set to "Other".
    It is only available if the EventDispatchStrategy is set to "DedicatedBehavior".
    Set Color
    Class Reference
    Supports
    • Controls:
      • Text
      • Text Value
    • Effects:
      • BitmapBrushColorBlend (as used in TextNode)
      • GlBitmapBrushColorMaskBlend
      • GlDropShadowBitmapBrushColorBlend
      • GlFlipBitmapBrushColorBlend
      • GlOutlineBitmapBrushColorBlend
      • SolidColorBrushColorBlend (as used in SolidColorNode)
    Example Usage
    Common Properties
    Property Reference PropertyReference::Enum
    Color Candera::Color
    The color to set.
    This property is only available if PropertyReference is set to "Self".
    Use For Child Nodes bool If set to true, also child nodes are affected by this action.
    Levels UInt8
    Number of levels to step down through groups. Default is zero.
    This property is only available if UseForChildNodes is checked.
    TargetNode Candera::AbstractNodePointer The node which is modified. If not set, then the node where the behavior is attached to, will be modified.
    Advanced Properties
    Property Provider PropertyProviderBehavior*
    Property Provider which contains the color which has to be set on the effect.
    It is only available if PropertyReference is set to"Other".
    Set Image
    Class Reference
    See also: Set Text, Set Color, Set Control State
    Example Usage
    Common Properties
    Target Node Candera::AbstractNodePointer The node which gets the given image. If not set, then the node where the behavior is attached too, will be modified.
    Image SharedPointer<Image2D>
    Use As Default bool True if the image shall be used as default image.
    Advanced Properties
    It is only available if PropertyReference is set to "Other"
    Set MVG Fill Color
    PropertyReference CgiStudioControl::PropertyReference::Enum     Choose how the property gets set. Via own property or from another Behavior.
    Color Candera::Color The fill color to be set.
    PropertyProvider CgiStudioControl::PropertyProviderBehavior
    Set MVG Stroke Color
    Sets the stroke (outline/border) color of an MVG node using an effect. The color can be applied dynamically when an action behavior is triggered. Can set the stroke color of an MVGArc node when used with OnPress.
    Render Child Nodes
    Class Reference
    Example Usage
    Common Properties
    TargetNode Candera::AbstractNodePointer The node which switches child nodes. If not set, then the node where the behavior is attached to, will modified its children.
    Index Float Index of the child node which shall be active.
    Levels UInt8 Number of levels to step down through groups. Default is zero.
    Set Text
    Class Reference
    Example Usage
    Common Properties
    PropertyReference PropertyReference::Enum
    Text String
    The text that will be set to the Text Node.
    This property is available if the PropertyReference is set to "Self".
    Advanced Properties
    It is only available if the PropertyReference is configured with "Other".
    Set Text Style
    Common Properties
    Style SharedPointer<TextRendering::SharedStyle> The Style that will be set to the Text Node.
    Enable Rendering
    Class Reference
    Example Usage
    Common Properties
    TargetNode Candera::AbstractNodePointer The node which gets the visibility flag. If not set, then the node where the behavior is attached to, will be modified.
    Visible bool According to this value, the affected node gets rendered or not.
    Send Value Changed As Event
    Example Usage
    Common Properties
    Value
    FeatStd::Variant
    Sender
    Candera::AbstractNodePointer The node for which the event shall be emitted. If it is not set then the TargetNode or Node (if TargetNode is not set) will be taken instead.
    c
    TargetNode
    Candera::AbstractNodePointer The node on which the for which the EventDispatchStrategy will be applied. If it is not set then the Node will be taken instead.
    PropertyReference
    Target Node Candera::AbstractNodePointer The target node to which the events are routed from the source node. If this property is not set, the event will be routed to the node of the behavior.
    Advanced Properties
    DedicatedBehavior
    It is only available if the PropertyReference is set to "Other".
    Scroll Action Behaviors
    Send Scrollable Event
    Class Reference
    Common Properties
    Direction Optional<ScrollDirection::Enum>
    The direction in which the scroll should be performed.
    Type ScrollableEventType::Enum The scrolling type. It can be either relative or absolute scrolling in combination of being either itemwise or pagewise scrolling.
    Value Float The number of items or pages scrolled to.
    TreatAnimationDurationZeroAsNotSet
    bool
    When the AnimationDuration is set to 0 it will not be used as a valid animation duration. If a immediate scroll to the target position is intended this flag has to be set to false.
    AnimationDuration
    UInt32
    Duration of the scrolling animation.
    Advanced Properties
    DedicatedBehavior
    Behavior*
    Streaming Action Behaviors
    Configure and Play Stream
    Class Reference
    Starts, stops, pauses, resumes video streams by emitting an VideoControl Event. These Events can be received by Video Stream Behaviors.
    Common Properties
    TargetNode Candera::AbstractNodePointer The node which receives the event. If not set, then the node where the behavior is attached to, will receive it.
    Action VideoControl::Enum
    Action that will be executed on the stream.
    Possible values: Play, Replay, Pause, Resume, Stop.
    The strategy in which the event is sent.
    Possible values: Direct, Broadcast, Bubble, Tunnel, DedicatedBehavior.
    Advanced Properties
    Transition Action Behaviors
    Perform Transition Requests
    Class Reference
    See also: Transition Request
    Example Usage
    Common Properties
    Requests ArrayProperty<TransitionRequestBehavior *> The first TransitionRequestBehavior in the request-set.
    Variant String Default Variant which will be used for attached Requests. Not that Requests can also have their own Variant.
    Transition Request
    Class Reference
    Example Usage
    Common Properties
    RequestType CgiStudioControl::TransitionRequestType::Enum
    Whether a node should be Activated or Deactivated by the transition. Currently running transitions on a node can be ended using the Finish transition type.
    Possible values: Activate, Deactivate, Finish
    Variant FeatStd::String Variant which will be used for this Request.
    Identifier Candera::Transitions::Identifier The Node or Scene that will be subject to the transition.
    Views
    Jump to View
    Use this action to request jump/switching to the configured view (via the configured node). Depending on the view state setup (e.g. with view trees or a state machine) the request will be accepted or denied. The action itself will emit a JumpToViewEvent on the configured node.
    Common Properties
    View ViewIdentifier Identifier of the view that is requested to be shown.
    TheThere is Viewsno documentation for behaviorbehaviors categoryof includes anthe Internal subcategory subcategory.
    The behaviors in Internal are included in the product becauseas they are used internally by Scene Composer and may also be referenced by assets. At present, these behaviors are not intended for customer use. In addition, their behavior, configuration options (parameters), and availability may change in future releases. For this reason, we do not provide detailed, behavior-specific documentation for the behaviors stored in Internaluse at this time..
    Send Virtual Key
    Common Properties
    KeyType KeyType::Enum
    Choose the type of the key. With KeyCode you can select any key.
    Possible values: KeyCode, Modifier
    Modifier
    KeyModifierEnum::Enum
    Modifier Key (e.g. Shift)
    KeyCode
    KeyboardKeyCode::Enum
    Set Culture
    Class Reference
    Common Properties
    Locale FeatStd::String Locale of a culture. Invoking the action will set the culture active.
