Python-based Data Binding
The Player Connector Library is a simple library written in Python and c++ that provides functionality to start and load scene composer binary assets and interact with a predefined set of data binding items (Variant) through Python scripting.
Player Connector Library Package
The main functionality of the library is contained in two files, CanderaAppConnector.py [1] and BindingSourceEnum.py [2]. These files contain three classes.
CanderaAppConnector: This is the main class to be used to play assets and interact with them using data bindingBindingSourceEnum: A Python enum generated by the build pipeline that contains the enum keys to be used when setting and getting data binding items. The keys underlay the nomenclature "SOURCE<sourceIndex>ITEM<itemIndex>". Source - and item index start at one and go to ten, as we currently have ten predefined binding sources and ten items per source.Logger: Logger class that my be used to generate logs with compliant format and logging levels
The sources and types listed above are contained in a file system Python package that can be installed with pip.
It is suggested to install the library to a virtual environment and not to the global Python installation. For an exemplary usage refer to the Blood Pressure Sample documentation and source code.
[1]: /bin/Player/PlayerConnector/ProfessionalEdition/Python/CanderaAppConnector/CanderaAppConnector.py
[2]: /bin/Player/PlayerConnector/ProfessionalEdition/Python/Generated/BindingSourceEnum.py
Workflow
- Constructing the library with the Player Connector Library binary contained in the delivered package (PlayerConnectorLibrary)
- Initializing the library with the asset binary
- Optionally register data binding callbacks
- Continuously calling step to invoke the render loop and internal message delivery
- Interact with data bindings. Note that internally, changes to the data bindings are reflected on the view when step is called
- Shutdown library and gracefully exit program
Documentation
Constructor
| Parameters |
Init
Initializes the player with the provided asset path. Expects an absolute or relative path to the asset binary as parameter. Must be called before every other method. Returns a bool value whether the operation was successful.
| Parameters |
| Returns | The bool value |
Step
Invokes the internal message processing and render loop execution. Needs to be called continuously. Databinding updates are reflected internally during the invocation of this method. Returns a bool value whether the operation was successful.
| Parameters | None |
SetIntValue
| Parameters |
SetBoolValue
| Parameters |
SetStringValue
| Parameters |
SetFloatValue
| Parameters |
GetIntValue
| Parameters |
| Returns | The integer value |
GetBoolValue
| Parameters |
GetStringValue
| Parameters |
| Returns | The string |
GetFloatValue
| Parameters |
| Returns | The float value |
RegisterCallback
Registers a callback method. Multiple methods can be registered. Passed method must have two parameters. First param is BindingSourceItem and second parameter is value.
| Parameters |
ShutDown
| Parameters | None |
