Project Settings
Several project related configurations can be performed in the project settings window which is accessible var the “Edit” menu or the shortcut “Ctrl + 0”.
Via the List on the left the displayed options can be filtered to make it faster to find a related setting.
All project settings (with a few additions) are available in any build that is executed. For more details about this refer to “Builds”Builds chapter chapter..
General
Property Name Description
Name
Name of the project.
Description Description of the project.
Icon Custom icon used for the project.
Interface
Interface Definition
File containing the Interface definition. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Complex-Type Definition File containing the Complex-Type definition. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Native-Function Definition File containing the Native-Function definition. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Tools
Generic
Enables generic support. This will provide a plain C/C++ interface.
MATLAB Enables support for MATLAB. This will provide additional options/setting related to Mathworks MATLAB support
CGI Studio
Root Path
Path to CGI Studio package. The path can be either absolute or relative to CGI Connector/Project path.
Device-Platform
Platform
Name of the CGI Studio Platform (as found in CMake)
MATLAB Name of the CGI Studio Platform configuration (as found in CMake)
Scene Composer
Executable
Executable used to edit the Scene Composer solution file.
Solution Scene Composer solution file. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Courier
XCDL Definition File
File containing the Courier definition. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
XCDL Include Path Additional include path required to by the XCDL definition. Multiple path must be separated by a ‘;’
Code Generation
Compiler
Compiler used to build code.
Architecture Architecture used to build the code.
Build-Project File File containing default builds. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
MATLAB
Build-Project File File containing MATLAB related builds. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Connector
Edit Complex-Types Script File
Script file executed when editing Complex-Types. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Edit Native-Functions Script File Script file executed when editing Native-Functions. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Edit SC Solution Script File Script file executed when editing SC Solution. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Edit XCDL Script File Script file executed when editing Courier definition. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Edit Build-Project Script File Script file executed when editing a Build-Project. The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
Show Console Window When enabled, shows a command line window executing scripts. This can be used to debug scripts.
Show Code Script File Script file executed when editing code (via the log window). The path can be either absolute or relative to CGI Connector/Project/CGI Studio path.
