Interface-Buffer
The main class of the generated interface is called “Interface-Buffer”. This class is responsible to handle the data, actions and events from both sides and provide them to the other side.
The Interface-Buffer class contains the following methods:
Init
Initializes the Interface-Buffer.
| Argument Name | Type | Description |
| dataModel |
DataModel | The generated Data-Model. Used to initialize data-values of the Interface-Buffer |
| defaultActionQueueSize | FeatStd::UInt32 | Size of the Action-Queue in bytes. The action queue is used to store actions for later execution. By pre-initializing it with a proper size, costly runtime memory allocations can be avoided. |
| defaultEventQueueSize | FeatStd::UInt32 | Size of the Event-Queue in bytes. The event queue is used to store event for later handling. By pre-initializing it with a proper size, costly runtime memory allocations can be avoided. |
SetDataValue
Sets data values of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
| interfaceId |
InputInterfaceId::Enum | Id of the interface to set the value. |
| data | void* | Pointer to the data to be set. |
| dataSize | FeatStd::UInt32 |
Size of the data to be shared in bytes.
This value will be ignored for static sized data unless INTERFACE_DEBUG_SIZECHECK_ENABLED is defined. |
Result: True if setting the data-value is successful. False otherwise.
GetDataValue
Gets data values of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
| interfaceId |
OutputInterfaceId::Enum | Id of the interface to get the value. |
| target | void* | Pointer where the value should be written. |
| maxTargetSize | FeatStd::UInt32 |
Maximum size of in bytes that the ‘target’ can store.
| dataSize | FeatStd:: |
Actual size of the data to be written. |
Result: True if getting the data-value is successful. False otherwise. If the return value is false and the dataSize > maxTargetSize the cause for the failure was that not enough memory was available to store the output value.
TriggerAction
Triggers the specified action.
| interfaceId |
InputInterfaceId::Enum | Id of the action to trigger. |
| data | void* | Pointer to data needed for the action. |
Result: True if getting action was successfully triggered. False otherwise.
SwapActionQueue
Swaps the action queue.
ProcessEvents
Gets events of the Interface-Buffer. This method is intended to be called by the external system to send data to the CGI application.
| eventHandler |
Internal:: |
Pointer to the Event-Handler |
| maxCount | FeatStd::Int32 | Maximum count of events to handle. Use ‘-1’ for unlimited amount. |
The Event-Callback function must have the following arguments:
| interfaceId |
FeatStd::UInt32 | Id of the event |
| data | void* | Pointer to the event data if available. |
| dataSize | FeatStd::UInt32 | Size of the event data if available. |
ProcessInputDataValues
Synchronizes the Interface-Buffer input data values with the applications Data-Model. This method is intended to be called by the CGI application.
| dataModel |
DataModel* | The generated Data-Model. |
ProcessOutputDataValues
Synchronizes the Interface-Buffer output data values with the applications Data-Model. This method is intended to be called by the CGI application.
| dataModel |
ProcessActions
Executes all queued actions. This method is intended to be called by the CGI application.
| actionContext |
Action::ActionContext | Action-Context used to execute the action functions and basic actions (e.g. Mssage-Actions) |
| sceneContext | Scene::SceneContext | Scene-Context used to execute the scene related actions (e.g. Scene-Interface or Scene-Table Interface) |
| maxCount | FeatStd::Int32 | Maximum count of actions to handle. Use ‘-1’ for unlimited amount. |
TriggerGenericEvent
Raises a generic event. This method is intended to be called by the CGI application.
| interfaceId |
OutputInterfaceId::Enum | Id of the event to raise. |
| data | void* | Pointer to the data of the event if available. |
Result: True if an event was raised (considering additional conditions). False otherwise.
TriggerMessageEvent
Raises a message event. This method is intended to be called by the CGI application.
| message |
Courier::Message* | Message to check if an event is to be raised. |
TriggerFunctionCallEvents
Raises Function-Call events. This method is intended to be called by the CGI application.
| actionContext |
Action::ActionContext* | Action-Context used to call related Event-Functions. |
SwapEventQueue
Swaps the event queue.
