Editor
An editor for the Native-Function definition can be found here:
cgi_studio_connector/bin/NativeFunctionEditor.exe
Native-Functions
Properties:
Property Name Description
Name Name of the function. This name must be a valid C/C++ name and must be implemented in the Action-Context.
Description Description of the function.
Has Result If enabled, the function must return a bool value. This indicates that the function is used for Function-Call Events. The return value will indicate if the related event has been raised or not.
Arguments:
A function can have arguments. Arguments can be added/removed with the respective buttons.
Name Name of argument. This name must be a valid C/C++ identifier.
Type Data type of the argument. In principal all types can be used here. However if the argument is used for a dynamic input/output the type must either be a compatible basic FeatStd type or a supported Complex-Type.
Is Output Indicates if the argument is used as an output. This can then be used to apply additional conditions when checking for an event.
Description Description of the argument.
