Editor
An editor for the Native-Function definition can be found here:
“cgi_studio_connector/bin/NativeFunctionEditor.exe”
Native-Functions
Properties:
| Property Name | Description |
| Name | Name of the function. This name must be a valid C/C++ name and must be implemented in the Action-Context. |
| Description | Description of the function. |
| Has Result | If enabled, the function must return a bool value. This indicates that the function is used for Function-Call Events. The return value will indicate if the related event has been raised or not. |
Arguments:
A function can have arguments. Arguments can be added/removed with the respective buttons.
| Name | Name of argument. This name must be a valid C/C++ identifier. |
| Type | Data type of the argument. In principal all types can be used here. However if the argument is used for a dynamic input/output the type must either be a compatible basic FeatStd type or a supported Complex-Type. |
| Is Output | Indicates if the argument is used as an output. This can then be used to apply additional conditions when checking for an event. |
| Description | Description of the argument. |
