Scene Composer 3.13
UI/UX Improvements
Import feature improvements
  • Improved import dialog UI
  • Integrated file format import menu into [ Import Resources ] and improved UI transition when import is executed.
  • Support for drag-and-drop glTF import into Solution Explorer
  • Disabled 3D model import on OpenGLES1.1 platforms
  • Other minor modifications
Fusion
State Machine
  • Added undo/redo functionality
  • Additional context menu on State Machine Editor
    • Priority setting for transitions
    • Alignment of multiple items
  • Added shortcut key features for fast state machine modifications
  • Added zoom operation support
  • Diagram Bird's Eye feature support added
  • Removed Telerik serialization in the solution file. Solution conversion will handle the state machine data conversion.
Monotype Version Upgrade
The version of Monotype iType and Monotype WT-Shaper have been upgraded to the following versions:
Monotype iType
6.2.2
Monotype WT-Shaper
5.0.0
Text Length Checker
Added a rendering-based Text Length Checker to verify length of texts.
Easy Mode
Configuration of Easy Mode is not possible via Scene Composer preferences.
