Scene Composer 3.13
UI/UX Improvements
- Improved Zoom Display Preview in the display panel
- Toolbar improvements to reduce clutter (main screen, 2D/3D scene editor and animation timeline)
- Improved Text Style Editor feature
- Improved Search Panel UI
- Long path name support
- 64 bit support
Import feature improvements
- Improved import dialog UI
- Integrated file format import menu into [ Import Resources ] and improved UI transition when import is executed.
- Support for drag-and-drop glTF import into Solution Explorer
- Other minor modifications
Fusion
- Additional context menu on Fusion diagrams
- Diagram Bird's Eye feature support added
State Machine
- Added undo/redo functionality
- Additional context menu on State Machine Editor
- Priority setting for transitions
- Alignment of multiple items
- Added shortcut key features for fast state machine modifications
- Added zoom operation support
- Removed Telerik serialization in the solution file. Solution conversion will handle the state machine data conversion.
Text Size Report
Added a rendering-based Text Size Report to verify length of texts.
Easy Mode
Configuration of Easy Mode is possible via Scene Composer preferences.
