Scene Composer 3.13
UI/UX Improvements
Toolbar improvements to reduce clutter (main screen, 2D/3D scene editor and animation timeline)
Improved Text Style Editor feature Improved Search Panel UI
Long path name support
64 bit support
Import feature improvements
Integrated file format import menu into [ Import Resources ] and improved UI transition when import is executed.
Support for drag-and-drop glTF import into Solution Explorer
Disabled 3D model import on OpenGLES1.1 platforms
Other minor modifications
Fusion
State Machine
- Added undo/redo functionality
- Additional context menu on State Machine Editor
- Priority setting for transitions
- Alignment of multiple items
- Added shortcut key features for fast state machine modifications
- Added zoom operation support
- Diagram Bird's Eye feature support added
- Removed Telerik serialization in the solution file. Solution conversion will handle the state machine data conversion.
Monotype Version Upgrade
The version of Monotype iType and Monotype WT-Shaper have been upgraded to the following versions:
| Monotype iType |
6.2.2 |
| Monotype WT-Shaper |
5.0.0 |
Easy Mode
Configuration of Easy Mode is not possible via Scene Composer preferences.
