Scene Composer 3.13
New Feature
Fusion
Fusion allows you to structure your scene logic easily in a visual node designer
Vector Graphics
Support for vector graphics is added, which can be created in Scene Composer or imported via SVG files.
State Machine
State machine editor functionality for annotations added. Annotations with text nodes without interaction to state machine and nodes can be colored and annotated with an image.
UML pseudostate functionality added
Smart Importer
Support for Figma design files is added
Requirement tracking
For easier requirement tracking an URI, next to annotation and description, can be defined by the user. If the URI is valid a clickable link is available to directly access the resource (e.g. a link to your requirement tool).
Display rotation support
Rotation of Scene can be configured, in case your HMI is physically rotated build into your product.
Referencing external resource functionality (Android Platform only)
Changes
Smart Importer
AI for control detection is directly integrated in Scene Composer
Additional UI/UX improvements
Automatic import feature improved
Automatic import was improved to support new use cases and the handling was improved.
Improved Properties panel
Improved HMI Report function
HMI report doesn't require Python anymore and is executed faster.
Display Preview support
