Usage example (Importing and assigning Control)
In this section describes the Control assignment procedure when importing a PSD file with the layer structure described in the previous chapter. The file to be imported on Scene Composer is the IVI sample attached to this document.
- Depens on its Control usage and/or Solution to be created, will set on "Appearance" and "Basic Properties" tabs.
As described above, you can efficiently import operations in Scene Composer by configuring the layer structure in Photoshop according to Controls you want to use.
