Recommended PSD Layers Structure for Smart Importer
When creating PSD files using Adobe Photoshop, it is recommended that the naming and structure of the Photoshop layer controls be pre-matched to SceneComposer. This will allow for smooth application of controls and their properties when importing with SmartImporter. The list below shows the Controls that will be assigned in Scene Composer via Smart Importer. Press the links on each Control to jump to the page showing the recommended layer structure in detail.
It is important to note that the Smart Importer cannot process effects, masks, filters in Photoshop. Therefore, if you want to use these features, please rasterize the images in advance.
 Some Controls are included in the sample file "IVI_Sample.psd" and are explained with specific examples.
Contents List
PSD layer settings for Control
In this section, the recommended layer configuration in PSD file is described for each control. And, you can confirm its configuration in the sample file about CheckBox, Gauge, IconButton, RadioButton, and TextButton.
  • Setting Group name is optional, but it is recommended to use the Control name (as seen in Scene Composer)
  • It is also recommended to use the property names (as seen in Scene Composer) as layer names (in Photoshop), but please don't use spaces in the layer names.
CheckBox
Back to List
The CheckBox Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.
Group name
CheckBox
Layer
SelectedImage
SelectedPressedImage
NormalImage
PressedImage
Gauge
Back to List
The Gauge allows to rotate a needle on a background according to its input value.
Group name
Gauge
Layer
NeedleImage
BackgroundImage
IconButton
Back to List
IconButton has similar functionality as the standard button, but in addition an icon (image) is placed on top of the button.
Group name
IconButton
Layer
NormalImage
PressedImage
FocusedImage
IconNormalImage
IconPressedImage
RadioButton
Back to List
The RadioButton Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.
Group name
RadioButton
Layer
NormalImage
PressedImage
SelectedImage
FocusedImage
RadioButton (In the image, it is RadioButton_Outside_air to distinguish it.)
TextButton
Back to List
The TextButton Control offers an easy way to define all different states of a button and an action that is performed when clicking it.
Group name
TextButton
Layer
NormalImage
PressdImage
FocusedImage
AnalogClock
Back to List
An analog clock with images for the certain needles (hours, minutes, seconds).
Group name
AnalogClock
Layer
SecondsNeedleImage
MinutesNeedleImage
HoursNeedleImage
FaceImage
Breadcrumb
Back to List
A Breadcrumb shows the history/flow through the screen hierarchy and allows user, for example, to navigate between scenes using breadcrumb's elements.
Group name
Breadcrumb
Layer
Name
EllipsisText
Button
Back to List
The Button Control offers an easy way to define all different states of a button and an action that is performed when clicking it.
Group name
Button
Layer
NormalImage
PressedImage
FocusImage
CircularSlider
Back to List
Group name
CircularSlider
Layer
BackgroundImage
ActiveImage
ThumbImage
ThumbImagePressed
FocusImage
GroupBox
Back to List
The GroupBox offers an easy way to combine RadioButtons to a RadioButtonGroup.
Group name
GroupBox
Layer
BackgroundImage
InputField
Back to List
The InputField contains an editable text.
Group name
InputField
Layer
CaretImage
BackgroundImage
FocusedImage
Menu Icon
Back to List
The MenuIcon Control is an “icon” like in graphical environments of most known operating systems.
Group name
MenuIcon
Layer
BackgroundImage
Menu Item
Back to List
A MenuItem is a basic building block of MenuScreens. It can represent for example an application or a deeper level in a menu hierarchy.
Group name
MenuItem
Layer
FocusImageOnSelection
FocusImageOnDragging
DeleteButtonNormalImage
DeleteButtonPressedImage
Menu Screen
Back to List
The Control represents a menu in the form of a grid of icons (instances of the Menu Item Control).
Group name
MenuScreen
Layer
BackgroundImage
FocusBorderImage
Mesh2D
Back to List
Performs a perspective projection of a 3D rotated effect based on the configured origin, rotation and field of view.
Group name
Mesh2D
Layer
MultiStateButton
Back to List
The MultiStateButton Control offers an easy way to define all different states of a button.
Group name
MultiStateButton
Layer
ButtonState1Bmp
ButtonState2Bmp
ButtonState3Bmp
ButtonState4Bmp
FocusedImage
PageIndicator
Back to List
A Page Indicator is a control that indicates currently visible page of set and provides method to switch to another page directly by click or if focused on a stepping manner using rotary action input.
Group name
PageIndicator
Layer
PressedImage
SelectedIndicatorImage
IndicatorImage
SelectedIndicatorPressedImage
Roll
Back to List
The Control represents a vertical list of numeric values from a specified range with a specified step.
Group name
Roll
Layer
DecorationImage
TextEditBackground
SpinBox
Back to List
A spin box or spin button is a control that enables users to increase or decrease the number value by a specific increment via clicking an up or down arrow button.
Group name
SpinBox
Layer
BackgroundImage
ArrowUpNormalImage
ArrowUpPressedImage
ArrowDownNormalImage
ArrowDownPressedImage
ToggleButton
Back to List
The ToggleButton Control offers an easy way to define all different states of a toggle button and an action that is performed when clicking it.
Group name
ToggleButton
Layer
FirstImage
FirstPressedImage
SecondImage
SecondPressedImage
FocusedImage
TouchIndication
Back to List
The TouchIndication indicates the location of touch events.
Group name
TouchIndication
Layer
