Recommended PSD Layers Structure for Smart Importer
When creating PSD files using Adobe Photoshop, it is recommended that the naming and structure of the Photoshop layer controls be pre-matched to SceneComposer. This will allow for smooth application of controls and their properties when importing with SmartImporter. The list below shows the Controls that will be assigned in Scene Composer via Smart Importer. Press the links on each Control to jump to the page showing the recommended layer structure in detail.
It is important to note that the Smart Importer cannot process effects, masks, filters in Photoshop. Therefore, if you want to use these features, please rasterize the images in advance.
 Some Controls are included in the sample file "IVI_Sample.psd" and are explained with specific examples.
Contents List
    Control name
    Control name
    AnalogClock
    Breadcrumb
    Button
    CheckBox CircularSlider Gauge GroupBox IconButton InputField Menu Icon Menu Item Menu Screen
    Breadcrumb
    Mesh2D
    Button
    MultiStateButton
    CheckBox
    PageIndicator
    CircularSlider
    RadioButton
    Gauge
    Roll
    GroupBox
    SpinBox
    IconButton
    TextButton
    InputField
    ToggleButton
    Menu Icon
    TouchIndication
    Menu Item
    PSD layer settings for Control
    In this section, the recommended layer configuration in PSD file is described for each control. And, you can confirm its configuration in the sample file about CheckBox, Gauge, IconButton, RadioButton, and TextButton.
    • Setting Group name is optional, but it is recommended to use the Control name (as seen in Scene Composer)
    • It is also recommended to use the property names (as seen in Scene Composer) as layer names (in Photoshop), but please don't use spaces in the layer names.
     CheckBox
    Back to List
    The CheckBox Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.
    Group name
    CheckBox
    Layer
    SelectedImage
    SelectedPressedImage
    NormalImage
    PressedImage
    1.2.     Gauge
    Back to List
    The Gauge allows to rotate a needle on a background according to its input value.
    Example of this Control
    Group name
    Gauge
    Layer
    NeedleImage
    BackgroundImage
    Layer structure in PSD
    Properties on Scene Composer
    1.3.     IconButton
    Back to List
    IconButton has similar functionality as the standard button, but in addition an icon (image) is placed on top of the button.
    Group name
    IconButton
    Layer
    NormalImage
    PressedImage
    FocusedImage
    IconNormalImage
    IconPressedImage
    1.4.     RadioButton
    Back to List
    The RadioButton Control can easily be configured with a text, images for a normal and a pressed state as well as for a selected and a selected pressed state.
    Group name
    RadioButton
    Layer
    NormalImage
    PressedImage
    SelectedImage
    FocusedImage
    RadioButton (In the image, it is RadioButton_Outside_air to distinguish it.)
    1.5.     TextButton
    Back to List
    The TextButton Control offers an easy way to define all different states of a button and an action that is performed when clicking it.
    Group name
    TextButton
    Layer
    NormalImage
    PressdImage
    FocusedImage
    1.6.     AnalogClock
    Back to List
    An analog clock with images for the certain needles (hours, minutes, seconds).
    Example of a default Control view
    Group name
    AnalogClock
    Layer
    SecondsNeedleImage
    MinutesNeedleImage
    HoursNeedleImage
    FaceImage
    1.7.     Breadcrumb
    Back to List
    A Breadcrumb shows the history/flow through the screen hierarchy and allows user, for example, to navigate between scenes using breadcrumb's elements.
    Group name
    Breadcrumb
    Layer
    Name
    EllipsisText
    1.8.     Button
    Back to List
    The Button Control offers an easy way to define all different states of a button and an action that is performed when clicking it.
    Group name
    Button
    Layer
    NormalImage
    PressedImage
    FocusImage
    1.9.     CircularSlider
    Back to List
    Group name
    CircularSlider
    Layer
    BackgroundImage
    ActiveImage
    ThumbImage
    ThumbImagePressed
    FocusImage
    1.10.         GroupBox
    Back to List
    The GroupBox offers an easy way to combine RadioButtons to a RadioButtonGroup.
    Group name
    GroupBox
    Layer
    BackgroundImage
    1.11.         InputField
    Back to List
    The InputField contains an editable text.
    Group name
    InputField
    Layer
    CaretImage
    BackgroundImage
    FocusedImage
    1.12.         Menu Icon
    Back to List
    The MenuIcon Control is an “icon” like in graphical environments of most known operating systems.
    Group name
    MenuIcon
    Layer
    BackgroundImage
    1.13.         Menu Item
    Back to List
    A MenuItem is a basic building block of MenuScreens. It can represent for example an application or a deeper level in a menu hierarchy.
    Group name
    MenuItem
    Layer
    FocusImageOnSelection
    FocusImageOnDragging
    DeleteButtonNormalImage
    DeleteButtonPressedImage
    1.14.         Menu Screen
    Back to List
    The Control represents a menu in the form of a grid of icons (instances of the Menu Item Control).
    Group name
    MenuScreen
    Layer
    BackgroundImage
    FocusBorderImage
    1.15.         Mesh2D
    Back to List
    Performs a perspective projection of a 3D rotated effect based on the configured origin, rotation and field of view.
    Group name
    Mesh2D
    Layer
    1.16.         MultiStateButton
    Back to List
    The MultiStateButton Control offers an easy way to define all different states of a button.
    Group name
    MultiStateButton
    Layer
    ButtonState1Bmp
    ButtonState2Bmp
    ButtonState3Bmp
    ButtonState4Bmp
    FocusedImage
    1.17.         PageIndicator
    Back to List
    A Page Indicator is a control that indicates currently visible page of set and provides method to switch to another page directly by click or if focused on a stepping manner using rotary action input.
    Group name
    PageIndicator
    Layer
    PressedImage
    SelectedIndicatorImage
    IndicatorImage
    SelectedIndicatorPressedImage
    1.18.         Roll
    Back to List
    The Control represents a vertical list of numeric values from a specified range with a specified step.
    Group name
    Roll
    Layer
    DecorationImage
    TextEditBackground
    SpinBox
    Back to List
    A spin box or spin button is a control that enables users to increase or decrease the number value by a specific increment via clicking an up or down arrow button.
    Group name
    SpinBox
    Layer
    BackgroundImage
    ArrowUpNormalImage
    ArrowUpPressedImage
    ArrowDownNormalImage
    ArrowDownPressedImage
     ToggleButton
    Back to List
    The ToggleButton Control offers an easy way to define all different states of a toggle button and an action that is performed when clicking it.
    Group name
    ToggleButton
    Layer
    FirstImage
    FirstPressedImage
    SecondImage
    SecondPressedImage
    FocusedImage
    TouchIndication
    Back to List
    The TouchIndication indicates the location of touch events.
    Group name
    TouchIndication
    Layer
