Part 5: Configure State Machine
State Machine feature is used for transitioning a screen to others. Here, the display is transitioned by pressing Music and Navigation buttons in the Menu section.
Click the triangular icon beside Solution > State Machines in Solution Explorer. Double-click GlobalStateMachine that is shown after expanding State Machines.
  • The State Machine Editor is shown.
  • Make sure the checkbox of Is Global on Properties is marked.
Click State on State Machine Editor, and change Name on Properties to Music. Set the Identifier property to Music scene. (see the below)
Add Handle Control State to TextButton_Music and TextButton_Navigatio node in Menu_button group by drag-and-drop operation.
Return to the State Machine Editor panel. Drag and drop a State from the upper right toolbar.
Click that State on State Machine Editor, and change Name on Properties to Navigation. Connect the two States in both directions with a Transition (see figure).
Select each Transition and set the displayed Properties as shown in the table below.
Navigation to Music
Transition
Sender Textbutton_Music EventSender ClickedTextbutton_Music ConditionEvent Check ClickClicked Condition Parameters Sender Textbutton_MusicCheck Click EventCondition Parameters AnyClick ConditionSender Textbutton_Music Event AnyClick Condition 0
Music to Navigation
Transition
Sender Textbutton_Navigation EventSender ClickedTextbutton_Navigation ConditionEvent Check ClickClicked Condition Parameters Sender Textbutton_NavigationCheck Click EventCondition Parameters AnyClick Sender Textbutton_Navigation Event AnyClick Condition 0
Select Music State and add Transition Request behavior to On Entry Action/On Exit Action. After adding, set each behavior as shown in the table below.
On Entry Action
Action Transition Request RequestTypeAction ActivateTransition Request IdentifilerRequestType Activate Identifiler /Scenes/IVI_Sample/Group2D:IVI_Sample/Group2D:Music On Exit Action Action Transition Request RequestTypeAction DeactivateTransition Request IdentifilerRequestType Deactivate Identifiler /Scenes/IVI_Sample/Group2D:IVI_Sample/Group2D:Music
Select Navigation State and take same operation.
On Entry Action
Action Transition Request RequestTypeAction ActivateTransition Request RequestType Activate Identifiler /Scenes/IVI_Sample/Group2D:IVI_Sample/Group2D:Navigation On Exit Action Action Transition Request RequestTypeAction DeactivateTransition Request RequestType Deactivate Identifiler /Scenes/IVI_Sample/Group2D:IVI_Sample/Group2D:Navigation
Click the Play button in the menu bar to run CGI Player. Click the either button of Music/Navigation on the upper part to transition to other image.
