Part 2: Configuring State Machine
Creating a new State Machine
The solution created in Part 1 (created based on the Empty solution) includes a GlobalStateMachine by default. In this part, we will delete this existing Global State Machine and create a new State Machine to deepen our understanding of custom settings.
Deleting the existing Global State Machine
- Select the GlobalStateMachine in the [ State Machines ] folder in the Solution Explorer, and then select [ Delete ] from the context menu.
- The [ Delete Items ] dialog will appear.
- Click the [ OK ] button in the dialog to delete the item.
- Select [ State Machines > New State Machine ] from the menu bar.
- The [ New State Machine ] dialog will appear.
- Click [ Browse ] at the top of the dialog.
- The [ Select Location ] dialog will appear.
- Select StateMachines and click [ OK ].
- The location “/State Machines” is selected as the save location for the new State Machine.
- Set [ Name ] in the dialog to "Main_StateMachine" and click the [ OK ] button.
- The Main_StateMachine is newly created in the [ State Machines ] folder in the Solution Explorer.
Setting the Global State Machine
- Select the Main_StateMachine in the [ State Machines ] folder in the Solution Explorer.
- The Main_StateMachine properties will be displayed in the Properties panel.
- Enable the [ Is Global ] checkbox in the [ General ] category of the properties.
- The Main_StateMachine will be set as a Global State Machine.
Basic Structure
Using the Main_StateMachine we created earlier, we will add a State to configure the initial state of the Main Menu scene, and then set the appropriate rendering settings. In addition, when the Main Menu State is entered, the Main Menu scene will be activated, and the Clear and Swap scenes will also be activated so that they are rendered correctly.
Initial State and State Addition for Main Menu
- Double-click on the Main_StateMachine in the [ State Machines ] folder in the Solution Explorer.
- The State Machine Editor panel will be displayed.
- There is already an Initial State and one State.
- Select the State on the State Machine Editor.
- The properties of the selected State will be displayed in the Properties Panel.
- Change the [ Name ] in the [ General ] category of the Properties Panel to MainMenu.
- The State name on the State Machine Editor will change to MainMenu.
Adding an OnEntry Action
This completes the settings for the OnEntry action for the MainMenu State. When you transition to the MainMenu State, the Clear and Swap scenes will be activated in addition to the Main Menu scene, so things like clearing the render will be executed at the same time.
Main Menu State Structure
Adding a State
- Double-click on Main_StateMachine in the [ State Machines ] folder in the Solution Explorer.
- The State Machine Editor will appear.
- After selecting the MainMenu State, drag the resizing handles displayed in the four corners of the state with the mouse to expand the size of the MainMenu State.
- Place one Initial State and three States in the MainMenu State from the toolbar at the top right of the State Machine Editor.
- Change the names of the three added States to Navigation, Phone and Media respectively.
- For instructions on how to change State names, please refer to here.
OnEntry/OnExit settings
When transitioning to each State (entering and exiting States), it is necessary to activate and deactivate the corresponding scenes. In addition, when each scene is activated or deactivated, it is necessary to set the Main Menu scene text to be displayed or hidden in conjunction with this.
Scene display settings
Text Display Settings
Adding a Transition
We will now create a transition between the states we have created so far.
Setting the Initial State
We will set the transition from the Initial State to the Navigation State, which is the initial state.
- Drag and drop [ Transition ] from the toolbar at the top of the panel to the Initial State in the MaiMenu State.
- The Transition will be connected to the Initial State, and it will be ready to be placed.
- While the Transition is ready to be placed, click on the Navigation State.
- The Initial State and Navigation State will be connected by the Transition.
- The direction of the Transition connection is from the Initial State to the Navigation State.
With this setting, the transition to the Navigation State has been configured as the initial state of the MainMenu State.
Next, we will set up the transitions between each State (Navigation, Phone, Media).
- From the toolbar at the top right of the State Machine Editor, drag the Transition and drop it onto the Navigation State (the starting side of the transition).
- The Transition (arrow) will appear on the State Machine Editor and be ready to be dragged.
- Extend the Transition (arrow) to the Media State (end of transition) and click.
- The two states, Navigation and Media, will be connected by an arrow.
- With the added Transition selected, click [ Fusion... ] at the bottom left of the State Machine Editor panel.
- The Fusion panel will open, and the Fusion diagram for the Transition will be displayed.
- The Check Click Fusion node is connected to the connector (Condition) at the top right of the Transition Fusion node.
- Select the Check Click Fusion node that is connected by default, and press the Delete key.
- The Check Click Fusion node will be deleted.
- Drag the connector (Condition) at the upper right of the Transition Fusion node, move the mouse, and release the left mouse button at the any location.
- The [Select Behavior] dialog will open.
- Enter “Check Key Input” in the search field at the top of the dialog.
- The list of behaviors in the dialog will be narrowed down, and Condition > Input > Check Key Input will be displayed.
- Double-click Check Key Input.
- The Check Key Input Fusion node will be linked to the Condition connector of the Transition Fusion node.
- Drag the connector (Actions) at the bottom right of the Transition Fusion node, move the mouse, and release the left mouse button at the any location.
- Enter “Transition Request” in the search field at the top of the dialog.
- The list of behaviors in the dialog will be narrowed down, and Action > Transition > Transition Request will be displayed.
- Double-click Transition Request.
- The Transition Request Fusion node will be linked to the Actions connector of the Transition Fusion node.
- Make the following settings for the Transition Request Fusion node.
- Clicking the upward-pointing arrow icon in the upper right of the Fusion panel will switch the display to the State.
Check Key Input KeyCode Key_RightArrow Transition Request RequestType Activate Identifier Scenes>Media Menu
- Repeat the above steps 1 to 11 to set the following five transitions.
- The RequestType for all of these is Activate (default).
Transition
Check Key Input>KeyCode Transition Request>Identifier Media to Phone
Key_RightArrowScenes>Phone Phone to Navigation Scenes>Navigation Navigation to Phone
Key_LeftArrowScenes>Phone
Phone to Media Scenes>Media Menu Media to Navigation Scenes>Navigation
- When all settings are complete, the screen will look like the one below.
With the above settings, the scene that is displayed when a transition occurs from each scene has been set.
Checking the transition state
Starting the Player
To start the Player, click the [ Play selected scenario ] icon in the toolbar.
If you have not saved the solution before performing this operation, a dialog box will appear prompting you to save the solution. In this case, click the [ OK ] button in the dialog box. The asset file will be automatically generated and opened in the CGI Player.
- Click the [ Play selected scenario ] icon on the toolbar to start the Player.
- Three windows will open, and you can see that the simulation display, one of the windows, displays the “Navi Title” and “Navigation” text, and that the initial transition has occurred to the Main Menu and Navigation scenes.
- By pressing the left and right arrow keys on the keyboard, you can switch the text on the screen and see that you have transitioned to the specified scene.
- Close the CGI Panel and exit the Player.
- All three windows that were open will close.
Create a Global State Machine
When creating a new solution in SceneComposer, it already contains a Global StateMachine called "GlobalStateMachine". For training purposes I suggest to delete this existing StateMachine and create a new one.
A new StateMachine is created through the menu "State Machine" – "New State Machine…". This will open a dialog to configure the StateMachine's location to "/State Machines" and its name to "Main_StateMachine".
Select the Main_StateMachine in the Solution Explorer and make it a global StateMachine by checking the checkbox in the properties panel.
CGI Studio SceneComposer 3.10 only supports one global State Machine. For certain usecases multiple global State Machines are necessary.
Multiple global State Machines would be necessary to e.g. add an incoming call to the State Machine sample described here.
Add an Initial State and State for the Main Menu
Double-click the Main_StateMachine to open it in the State Machine Editor.
Drag and drop an Initial State and a single State for the MainMenu into the State Machine (if this hasn't been created automatically). Change the State's name to "MainMenu".
Connect the Initial State and the MainMenu State with a Transition. To do this, drag and drop the Transition Arrow onto the Initial State. Then you can draw an arrow to the MainMenu State. To create this transition, click onto the MainMenu State.
On the left side in State Machine Editor you can see the single Transition beneath the Initial State as well as beneath the MainMenu State.
When entering the MainMenu State, the MainMenu Scene has to be activated. To ensure that everything is rendered correctly, the Clear and Swap Scenes have to be activated too.
To configure activation of these scenes, select the MainMenu State. In the Properties panel click the "+" button next to "OnEntry" to create another OnEntry action. Select the action TransitionRequest. Click the magnifying glass icon to configure the Identifier.
Clicking the magnifying glass icon will open the Choose Item dialog, where you can choose the MainMenu Scene as Identifier.
Activate the Swap and Clear Scene by adding two additional OnEntry actions.
The final configuration will look like this.
Resize MainMenu State
Add States for Navigation, Phone and Media
Drag and drop an initial State and 3 States (for Navigation, Phone and Media) onto the MainMenu State in the StateMachine Editor window. Name the States accordingly: Navigation, Phone, Media.
Configure the States - OnEntry and OnExit Actions
Similar steps are necessary for the OnExit action: Add an OnExit action by pressing the "+" on "OnExit", choose a Transition Request Action and select the Navigation Scene. However unlike the OnEntry action, the OnExit action shall Deactivate the Scene, which has to be configured too. To select the Identifier you can also copy the text from the OnEntry Identifier input field and paste it into the OnExit Identifier input field.
Additionally, when entering the Navigation State, the TextNode for Navigation has to be set to visible in the MainMenu Scene. We need to make it invisible again when exiting the Navigation State.
The screenshot below will help you locate the TextNode for the OnEntry1 and OnExit1 actions.
It is necessary to configure these OnEntry and OnExit actions for all three States in a similar way: The Media State has to configure TransitionRequests for the Media Scene, the Phone State has to configure TransitionRequests for the Phone Scene. The same applies for the EnableRendering actions.
Insert Transitions
Now, we need to establish the transitions between these states: One Transition goes from the initial state to the Navigation state, which will be the default entry point.
Between the 3 states Navigation, Media and Phone we need transitions in both directions:
It does make sense to start create the transitions into one direction (e.g. clockwise) and give them readable names (e.g. Navi_next). In a second step, create the transition into the other direction (counter-clockwise) and assign readable names (e.g. Navi_prev).
The diagram may get confusing with more transitions. To keep things in perspective, please be careful to choose meaningful names. You can also enlarge the states and move transitions around.
Configure State Transitions
The user should be able to navigate from one scene to the other using the left and right arrow key. This will be configured in the transitions.
All clockwise transitions (named *_next) will be configured for Key_RightArrow and all counter-clockwise transitions (named *_prev) will be configured for Key_LeftArrow.
You can select the Transition from within the State Machine Editor or from the list in the panel on the left.
Test the Configuration - Start the Player
The first part of our IVI configuration is done, it's time to save your solution and start the player.
Once the Player window is opened, the State Machine transitions to the Navigation State. Press Key_RightArrow to transition to the Media State. Press Key_RightArrow again to transition to the Phone State. You can also transition through the States in the other direction by pressing Key_LeftArrow.
