GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. The right side displays a List of devices. When a device gets selected, an associated Sub-List Control with two TextButtons will be shown.
Preparing the Options scene
A scene will be created and the camera will be configured in the Render Targets panel.
  1. Create a new scene via the menu bar "Scene" - "New 2D Scene" or press < Ctrl+2 > on your keyboard
Importing Images
  1. In the menu bar select Import > Import Resources...
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 16 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
This scene is composed of two parts: Connection and Devices. For each of these parts a 2D Group node will be created. To position the background image a BimapNodeBitmapNode will be configured with one of the images imported in the previous section.
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
    • In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
        Target Name
        Position X
        Position Y
        Connection
        78.00
        58.00
        Devices
        551.00
        58.00
    The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
        Target Name
        Position X
        Position Y
        Dial
        72.00
        163.00
    The following steps show how to configure the Dial control with new images.
    2. In the "Choose Item" dialog select the image as in the table below and click [ OK ]OK].
      • The "Choose ItemItem" dialog will be closed.
        Property
        Path
        Knob Image
    4. In the Properties panelpanel's [BackgroundImages] section click on the magnifying glass next to "BackgroundImages 0".
    5. In the "Choose ItemItem" dialog navigate to "/Resources/Options/NewDial_background_leftBmp", select thisthe image as in the table below and click [ OK ]OK].
      • In the Properties panel the first BackgroundImageone of the BackgroundImages has been configured.
        Property
        Path
        BackgroundImages 0
      • Repeat steps 4 and 5 to configure the remaining BackgroundImages. After this step the BackgroundImages asare inconfigured according to the table below.
          StateImages
          Image Path
          BackgroundImages 1
          BackgroundImages 2
      • In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [ Bitmap ] section enable "Pivot Hint" by checking the respective checkbox.
      • Configure the "Pivot Hint" as in the table below.
          Target Name
          Pivot Hint Y
          88,00
      • In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 107 and 11,8, enabling and configuring the Pivot Hint of these three images according to the table below.
          Target Name
          Pivot Hint Y
          88,00
          130,50
          130,50 NewDial_background_middleBmp true
          130,50 130,50 NewDial_Background_rightBmp true
          130,50 130,50
      TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
      4. In the Scene Tree panel right click onto Connectionthe TextNode and select "Clone..." from the context menu.
          Text Position X Position Y
          TextNode_Cable Cable 20 200
          TextNode_Other Other 315 200
      The right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
      1. In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy"  or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
        • In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group.
        • In the Scene Editor another Textnode with "Connection" is visible.
      2. In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
        • In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D.
      3. In the Scene Tree panel select TextNode_Devices. In the Properties panel's [ 2D Text Node ] section change the TextNode's Text property and in the [ Transformation ] section adapt its Position according to the table below.
        • Text and position of the TextNode are configured.
        • In the Scene Editor you can see that the devices part has got a headline.
          TextNode_Devices Devices 145 61
      4. From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
      5. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
      6. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
      7. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
      8. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
        • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
      Configure MyList Control
      Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
      1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
      2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
      5. In the "Delete Item" dialog press [ OK ].
        • The List node is deleted.
      6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
      7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
      Customize MyList's Scrollbar
      Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
          Thumb Images
          Image Path
          VerticalPrevItem Images
          Image Path
          VerticalNextItem Images
          Image Path
      Configure MyList's Main Item
      Our MyList control will be composed of MainItems. Whenever a certain MainItem gets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
      2. From the Toolbar'Toolbox panel's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
      3. From the Toolbar'Toolbox panel's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
      4. In the Scene Tree panel select the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
          Initial Name
          New Name
          OverlayLayout MainItem
          TextNode EntryName
          RenderNode FocusImage
      5. In the Scene Tree panel select the List (Group2D). In the Properties panel's  [ Transformation ] section configure the position and size according to the following table.
          Target Item
          Transformation
          Layout
          List (Group2D)
          58
          134
          300
          300
      6. In the Scene Tree panel select the TextNode2D (MainItem > EntryName). In the Properties panel's [ TextNode2D ] section click on the magnifying glass icon to the right of the Style property.
        • The Text Style Palette dialog will be opened.
        In the Text Style Palette dialog select "OpenSans25" and click [ OK ].
          The Text Style Palette will be closed. In the Scene Editor the EntryName's text will be displayed in a smaller font.
          Target Item
          Style
          MainItem > EntryName OpenSans25
          In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
          3. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
              Target Item
          4. In the Properties panel change the Color property by entering new values for "Red", "Green" and "Blue" according to the table below.
              Target Item
              Color
              Red
              Green
              Blue
              0.62
              0.00
          5. In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
            • In the Scene Editor the FocusImage RenderNode will appear highlighted with an orange outline.
              Target Item
              Layout > StretchBehavior
              Fill
          Create MyList's Sub-List
          A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
          1. From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
          2. From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
          3. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
          4. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
              Target Item
              Transformations
              Layout
              Scale X
              Scale Y
              Margin Left
              TextButton
              0,75
              0,75
              12
          5. In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
          6. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
          7. Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
              Target Item
              Image Path
              Normal Image
              Pressed Image
              Focused Image
          10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
            • The texts of the TextButtons have been changed.
              Target Item
              New Name
              Control - Text
          Configure Behaviors for the Focus Handling of MyList's MainItem
          Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus and FocusLeave behaviors are used to enable or disable the rendering of the FocusImage. The behaviors are configured using Fusion.
          A detailed explanation about Fusion, how to operate Fusion (how to add Fusion Nodes) and a configuration example can be found in the documentation about Fusion.
          1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
          2. In the Scene Tree panel select the MainItem GroupNode. Then press the [Fusion...] button on the right side of the Scene Tree.
            • Fusion panel is opened displaying the Fusion diagram with the MainItem'sMainItem Fusion Node.
            • The MainItem Fusion node has a Behaviors connector on its right side.
          3. DragAdd Fusion Nodes to the MainMenu Fusion Node using its Behaviors connector to the right and then release the mouse button.
            • The [Select Behavior] dialog will be opened, which displays a list of behaviors.
            The behaviors are organized in groups similaraccording to the behaviorstable list in the Toolbox panel. There is an input field just above the behaviors list. Click into the input field and start typing "Handle Control State".below.
            • While typing the list of behaviors will be narrowed down.
            When you find the behavior "Handle Control State" double-click it.
              AThree new Fusion node will be added to the Fusion diagram: [Handle Control State].State, Focus, FocusLeave. UsingFocus theFusion same mechanism add a [Focus]Node and [FocusLeave] behavior to the MainItem's Behaviors connector.
                Two newFocusLeave Fusion nodes will be added to the Fusion diagram: [Focus] and [FocusLeave].
                These two new nodesNode can be configured with actions using their [Actions]Action] connectors.
                Connect to
                Connector
                Add Fusion Nodes
                Behaviors
                Behaviors
                Focus
                Behaviors
                FocusLeave Add [EnableRendering]Fusion actionsNodes to the Focus Fusion nodes [Focus]Node and [FocusLeave].the FocusLeave Fusion Node using their Actions connectors according to the table below.
                • TwoAn newEnableRendering Fusion nodesNode will be addedconnected to the Focus Fusion diagram:Node.
                anAn [EnableRendering]EnableRendering attachedFusion Node will be connected to the [Focus]FocusLeave nodeFusion anNode. another
                [EnableRendering] attached Connect to
                theConnector
                [FocusLeave]Add node.Fusion Nodes
                Focus Fusion Node
                Actions EnableRendering FocusLeave Fusion Node
                Actions EnableRendering Configure the properties "Visible" and "TargeTarget Node" for both [EnableRendering]EnableRendering Fusion Nodes nodes according to the table below.
                • Whenever the MainItem looses the focus, the FocusImage will get invisible.
                  Behavior
                  Visible
                  Target Node
                  Focus - EnableRendering
                  FocusLeave - EnableRendering
                1. In the Scene Tree panel select item MyList > List > ListContentGroup > MainItem. Then press the [Fusion...] button on the right side of the Scene Tree.
                  • Fusion is opened displaying the Fusion diagram with the MainItem'sMainItem Fusion Node.
                  • The MainItem Fusion nodeNode has a Behaviors connector on its right side.
                2. DragAdd Fusion Nodes to the MainItem Fusion Node using its Behaviors connector to the right and then release the mouse button.
                  The behaviors are organized in groups similaraccording to the behaviorstable list in the Toolbox panel. There is an input field just above the behaviors list. Click into the input field and start typing "Event Handler".
                    While typing the list of behaviors will be narrowed down. When you find the behavior "Event Handler" double-click it.below.
                    • A new Fusion node will be added to the Fusion diagram: [Event Handler].Handler Fusion Node.
                    • The [Event Handler]Handler Fusion node has 2 connectors on its right: a Condition connector and an Action connector.
                      Connect to Fusion Node
                      Connector
                      Add Fusion Nodes
                      MainItem
                      Behaviors
                      Event Handler
                    DragAdd theFusion Condition connectorNodes to the rightEvent andHandler releaseFusion Node according to the mousetable button.
                      The [Select Behaviors] dialog will be opened displaying a list of suitable behaviors. Find the condition "Check Logic Condition" by starting to type into the input field. Double-click [Check Logic Condition].below.
                      • A new Fusion node will be added to the Fusion diagram: [Check Logic Condition].
                      Condition Fusion Node.
                      With the [Check Logic Condition]Condition you can combine 2 conditions with a configurable logic operation (And, Or, Xor).
                      Connector
                      Add Fusion Nodes
                      Event Handler
                      Condition
                      InAdd two Fusion Nodes to the [Check Logic Condition]Condition configureFusion Node using its Conditions connector according to the Operationtable below.
                        2 new Fusion Nodes will be added to "Or"the Fusion diagram: Check Key Input Fusion Node and addCheck twoClick conditionsFusion usingNode.
                        Connector
                        Add Fusion Nodes
                        Condition
                        Check Key Input
                        Condition
                        Check Click Configure the [Conditions]Condition connector.Fusion SeeNodes configurationaccording details into the table below.
                        • [Check Click]Click and [Check Key Input]Input condition are logically combined through [Check Logic Condition].condition.
                        • [The Check Logic Condition]condition will evaluate to TRUE if either the [Check Click]Click condition or the [Check Key Input]Input condition is TRUE.
                          Condition
                          Property
                          Value
                          Operation
                          Or
                          Check Click  - -
                        FromAdd a Fusion Node the [Event Handler]Handler Fusion nodeNode dragusing theits [Actions]Action connector according to the righttable and release the mouse button to open the [Select Behavior] dialog. Find "Send Value as Event" and double-click it.below.
                        • A new Fusion nodeNode [will be added to the Fusion diagram: Send Value as Event]Event willFusion beNode. created
                          that is connectedConnect to theFusion [EventNode
                          Handler]Connector
                          Add Fusion node.Nodes
                          Event Handler
                          Action
                          Send Value As Event
                        Configure the [Send Value as Event] Fusion node according to the table below.
                        • Send Value As Event is configured according to the table.
                        • On every click or enter key press a boolean value will be sent to the Sub-List control.
                          To configure the TargetNode click on the magnifying glass icon to open the [Choose Item] dialog. Navigate to the desired object and press [OK].
                          Behavior
                          Property
                          Value
                          Value Bool - TRUE
                          Change Value
                          Relative
                        The visibility of the Sub-List shall be toggled by clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
                        1. In the Scene Tree panel select item MyList > List > ListContentGroup > Sub-List node. Then click the [Fusion...] button on the right side of the Scene Tree.
                          • Fusion is opened displaying the Fusion diagram with the Sub-List's Fusion Node.
                          • The Fusion node has a Behaviors connector on its right side.
                        2. DragAdd a Fusion Node the Sub-List Fusion Node using its Behaviors connector according to the righttable and then release the mouse button. In the opened [Select Behavior] dialog find the [Value] behavior and double-click it.below.
                          • A new Fusion nodeNode will be added to the Fusion diagram: [Value].
                        3. The [Value]Value Fusion nodeNode. has
                          a [Receivers] connectorsConnect onto itsFusion rightNode
                          side.Connector
                          Add Fusion Nodes
                          Sub-List
                          Behaviors
                          Value
                        4. Configure the [Value]Value nodeFusion Node according to the table below.
                          • The Value behavior's type has been changed to Bool.
                            Behavior
                            Property
                            Value
                            Value
                            Variant Bool - FALSE
                        5. Add ana [ActionFusion OnNode Value]the behaviorValue Fusion Node using its Receivers connector according to the [Value]table node's [Receivers] connector. To do this, drag the [Receivers] connector to the right and release the mouse button. In the [Select Behavior] dialog find the behavior [Action On Value] and double-click it.below.
                          • A new Fusion nodeNode [Actionwill Onbe Value]added appears into the Fusion diagram.diagram: Action On Value Fusion Node.
                            Connector
                            Add Fusion Nodes
                            Value
                            Receivers
                            Action On Value
                        6. Add atwo [CheckFusion ProcessedNode Value]the behaviorAction On Value Fusion Node according to the [Actiontable Onbelow.
                          Value]
                          node's
                        7. 2 [Condition]new connector.Fusion AddNodes awill [Setbe Control State] behavioradded to the [Fusion diagram: Check Processed Value Fusion Node and Set Control State Fusion Node.
                          Connector
                          Add Fusion Nodes
                          Action On Value]Value
                          node'sCondition
                          [Actions]Check connectorProcessed andValue
                          configure them
                          Actions
                          Set Control State
                        Configure the newly added Fusion Nodes according to the table below.
                        • [The Action On Value]Value Fusion Node is configured with an action that will be executed whenwhenever a new value is received. In orour case the Sub-List's Control State is set to enabled when the Bool value "TRUE" is received.
                          Behavior
                          Property
                          Value
                          ConditionOperator Equal
                          ConditionValue Bool, TRUE
                          Set Control State
                          State Enabled
                          ChangeTo TRUE
                        Repeat steps 4 and 5 to configure another [Actionset Onof Value]Fusion Nodes to the [Value]Value behavior'sFusion [Receiver]Node connector.using Configureits Receivers connector according to the table below.
                          3 new [ActionFusion OnNodes Value]will withbe anotheradded [Check Processed Value] condition and another [Set Control State] action. Setto the Fusion nodes'diagram: propertiesAction On Value_1 Fusion Node, Check Processed Value_1 Fusion Node and Set Control State_1 Fusion Node.
                          Connector
                          Add Fusion Nodes
                          Value
                          Receivers
                          Action On Value_1
                          Action On Value
                          Condition
                          Actions
                          Set Control State_1
                          • [The Action On Value]Value_1 Fusion Node is configured with an action that will be executed whenwhenever a new value is received. In orour case the Sub-List's Control State is set to disabled (enabled = FALSE) when the Bool value "FALSE" is received.
                            Behavior
                            Property
                            Value
                            Action On Value_1
                            ConditionOperator Equal ConditionValue Bool, FALSE Set Control State_1
                            State Enabled ChangeTo FALSE
                          Test MyList in the Player
                          Let's test if the configured behaviors of MyList control are functional.
                          1. Save your solution either via the menu bar "File - Save Solution" or via the keyboard <Ctrl + S>.
                            • The solution has been saved.
                          2. In the Scene Composer's Toolbar click on "Play selected scenario...".
                            • The resources will be generated and the Player will be started.
                          3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
                            • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
                          4. In the Player window click the first item of the Devices List, the text of which is "Text".
                            • In the Player window's Devices List an orange border will be displayed indicating the selected MainItem.
                            • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
                          5. In the Player window click the selected MainItem again.
                            • The TextButtons of the Sub-List will disappear.
                          6. In the Scene Composer's Toolbar click the "Close the Player" button.
                            • The Player and CGI Panel window will be closed.
                          So far we have been working on our MyList control with only one single list entry. Now that this first list entry is fully configured, we can create more of them.
                          1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
                            • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
                          2. In the Scene Tree panel select the MainItems individually. Use Fusion to configure the appropriate TargetNode for the [Send Value As Event] Fusion nodes (see table below).
                            • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
                              SendValueAsEvent of
                              TargetNode
                              MainItem /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List
                              MainItem_1 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1
                              MainItem_2 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2
                              MainItem_3
                              /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3
                              MainItem_4
                              /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
                          3. In the Scene Tree panel select MainItem's EntryName. In the Properties panel's [ 2D Render Node ] section change the property "Text" according to the table below.
                            • In the Scene Editor you can see the changed texts.
                              TextNode2D
                              Text
                              Phone (Private)
                              MainItem_1 > EntryName Phone (Work)
                              MainItem_2 > EntryName New Device
                              MainItem_3 > EntryName
                              New Device
                              MainItem_4 > EntryName
                              New Device
                          In the Scene Tree panel select the MainItem's EntryNames individually. In the Properties panel's [ 2D Text Node ]
                          Check the Options Scene
                          The Options scene is now finished.
                          1. To check the result of configuring the first scene, open the display view. This view represents the final rendered result and can be opened via the menu bar: View - Display - Display-0.
                          2. In the Scene Composer's Toolbar make sure that the item "Generate and Play" is selected in the drop-down menu and click the [ > ] button to the left.
                          3. In the CGI Panel tick the checkbox next to "Scenes#SceneClimate"Scenes#SceneOptions" and uncheck "Scenes#SceneHome".
                            • SceneClimateSceneOptions will become visible in the Player.
                          4. You can now play around with the configured Options Controls in the scene and watch the results.
                            • Grab the Connection Dial Control and switch between Cable, Bluetooth and Other.
                            • Click into the Devices List to open the Sub-List.
                            • Click on the Sub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects.
                            • Click on several devices in the Devices List to make multiple Sub-Lists visible. Now you can test the scrollbar.
