GettingStartedControls Part 3
be
shown. (Phone Connection) Options Scene
OurAnd this is what the final scene will look like this:like:
Our
goalPreparing is to create a Phone Connectionthe Options scene
withA ascene Dialwill Controlbe created and athe List with a Sub-List Control, thatcamera will appearbe and disappear when an itemconfigured in the ListRender isTargets clicked.panel.
Create a new scene
usingvia the
Scenemenu menu's"Scene" - "New 2D
Scene…Scene" or press < Ctrl+2 > on your keyboard
The "
Add menuNew item.Scene
Name
In the
newfirst scenerow select "/Scenes" from the drop-down menu. Enter "SceneOptions"
as name and press [ OK ]. We
always use the prefix "Scene" to have all scenes listed
nearnext to each other in the Solution Explorer
view.panel.
A new scene "SceneOptions" is created and visible in the Solution Explorer panel in folder "Scenes".
The new scene is opened in the Scene Editor and in the Scene Tree panel.
In the Scene Tree panel you can see that the scene already has a camera.
In the Render Targets panel you can see that the camera is already added to the RenderTarget.
In the Render Targets panel check the checkbox of "SceneOptions\Camera" in order to enable rendering.
Rendering of the scene is enabled.
In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [ Camera ] section change the sequence number to 2.
The camera's sequence number is set to 2.
In the Scene Tree panel the red Information/Warning/Error square disappears.
Importing Images
In the main menu select Import > Import Resources...
The "Import Resources" dialog will be opened.
In the "Import Resources" dialog navigate to the path given in the table below. Select all 16 files and press [ Open ]
The "Import Images" dialog will be opened.
Import Resources
Path
In the "Import Images" dialog select folder "/Resources", make sure to create a new folder "Options" for the imported images and click [ OK ].
In the Solution Explorer you can see that there is a new folder "Options" in folder "Resources" that contains the 16 imported images.
The images have been imported and can be used in the Scene Composer solution.
Configuring the Background
TheThis scene is nowcomposed createdof two parts: Connection and alreadyDevices. openedFor insideeach of these parts a 2D Group node will be created. To position the background image a BimapNode will be configured with one of the images imported in the previous section.
From the Toolbox panel's [ Node 2D ] section drag a 2D Group node into the Scene Tree
panel.directly Itonto alreadythe containsnode "SceneOptions".
In the Scene Tree panel you can see a
standard2D camera.Group Thenode.
Viewport
size
From the Toolbox panel's [ Node 2D ] section drag a BitmapNodes onto the 2D Group node.
In the Scene Tree panel you can see that a BitmapNodes has been created.
In the Scene Tree panel select the 2D Group and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
A copy of the
camera2D followsGroup with its BitmapNode has been created.
In Scene Tree panel the
sizename of the
Rendercopy is "Group_1".
In the Scene Tree panel select the nodes added in the steps before one after the other and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard. Apply the names provided in the table below.
In the Scene Tree panel you can see that the nodes have been renamed.
Target (1024x768)Item
Name
Group
Connection
BitmapNode
Background
Group_1
Devices
BitmapNode
Background
In the Scene Tree panel select both BitmapNodes called "Background".
TheThis new scene's camera should automaticallycan be
connectedachieved by selecting one BitmapNode, holding down the <Ctrl> key and keeping it pressed while clicking on the second BitmapNode. In Scene Tree panel's right side select the "BitmapBrushBlend" effect. In the Properties panel's [ Effect ] section click on the magnifying glass icon next to the
RenderImage Target.property.
IfitIn isn't,the pleaseProperties panel you can now edit the BitmapBrushBlend effect for both BitmapNodes.
The "Choose Item" dialog will be opened.
In the "Choose Item" dialog select the image as in the table below and click [ OK ].
The Choose Item dialog will be closed.
In the Scene Editor a background image is visible displaying a vertical grey-black gradient.
Property
Path
In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
In Scene Editor two rectangles with a gradient background are visible.
Target Name
Position X
Position Y
Connection
78.00
58.00
Devices
551.00
58.00
The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
From the Toolbox panel's [ Controls ] section under Touchable drag
a Dial control into the
CameraScene Tree panel directly onto the
default"Connection" RenderTargetgroup.
In the Scene Tree panel a Dial control has been added into the "Connection" group.
In the Scene Editor the Dial control is visible in the
Rendertop Targetsleft panel.corner Changeof the
Sequenceleft Numbergradient image.
In the Scene Tree panel select the Dial control. In the Properties panel's [ Transformation ] section adjust its position according to
the table below.
In the Scene Editor the Dial control is positioned in the lower center of the gradient image.
Target Name
Position X
Position Y
Dial
72.00
163.00
The following steps show how to configure the Dial control with new images.
In the Properties panel's [ Control ] section click on the magnifying glass icon next to property "Knob Image".
In the Scene Editor an orange ring will become visible.
Property
Path
Knob Image
In the Properties panel's [ Control ] section click on the the "BackgroundImages" section.
In the Properties panel the "BackgroundImages" section will be expanded.
In the Properties panel click on the magnifying glass next to "BackgroundImages 0".
In the Choose Item dialog navigate to "/Resources/Options/NewDial_background_leftBmp", select this image and click [ OK ].
In the Properties panel the first BackgroundImage has been configured.
Repeat steps 4 and 5 to configure the remaining BackgroundImages as in the table below.
In Properties panel all BackgroundImages are configured.
In Scene Editor you can see the newly configured images.
StateImages
Image Path
BackgroundImages 0
BackgroundImages 1
BackgroundImages 2
In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [ Bitmap ] section enable "Pivot Hint" by checking the respective checkbox.
A new property "Pivot Hint" becomes visible.
Configure the "Pivot Hint" as in the table below.
The Pivot Hint for the Knob Image is configured correctly.
In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 10 and 11, enabling and configuring the Pivot Hint of these three images according to the table below.
The Pivot Hint is configured correctly.
In Scene Editor the Dial's images are neatly aligned. The images have a common center.
Target Name
Enable Pivot Hint
Pivot Hint X
Pivot Hint Y
true
84,50
88,00
true
130,50
130,50
true
130,50
130,50
NewDial_Background_rightBmp
true
130,50
130,50
TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
From the Toolbox panel's [ Nodes 2D ] drag and drop a TextNode into the Scene Tree panel directly onto the "Connection" group node.
In the Scene Tree panel a TextNode will become visible.
In the Scene Editor the text "Text" will appear.
In the Scene Tree panel select the new TextNode. In the Properties panel's [ 2D Text Node ] section click on the magnifying glass icon next to property "Style".
The "Text Style Palette" dialog will be opened.
In the "Text Style Palette" dialog select "OpenSans25" and click [ OK ].
In Scene Editor the Text Style of the TextNode will change.
In the Scene Tree panel right click onto Connection and select "Clone..." from the context menu.
The "Clone Item" dialog will be opened.
In the "Clone Item" dialog change to the "Multiple Clone" tab. Configure "Number of Copies" to "3" and click [ OK ].
In the Scene Tree panel 4 TextNodes are now available inside the "Connection" group.
In the Scene Tree panel select the newly created TextNodes one after the other and configure their names in the Scene Tree panel and the remaining properties in the Properties panel
soas that this scene will be rendered abovein the
SceneClimate.table below.
Before
anything else, let's import a few images for the Options scene by clicking (Import > Import Resources) and selecting the files in /cgi_studio_content/Resources/GettingStartedControls/Options:
First, drag two Group Nodes from the Toolbox into the Scene Tree.
The
firstTextNodes groupare willfully representconfigured.
theThe "Connection"final Dial and the second group will be for the "Devices" List. Rename the first Group Node to "Connection" and the second Group Node to "Devices". Under each group, add a Bitmap Node from the Toolbox and rename it to "Background".
Select oneresult of the BitmapConnection Nodepart can be seen in the Scene Tree Panel. Then, select the BitmapBrushBlend Effect and set the Image property to the recently imported background image as shown below: And do the same for the other Bitmap Node.
Change the Position property of "Connection" to X: 78 and Y: 58. Change the Position property of "Devices" to X: 551 and Y: 58. Now we have two background images for Connection group and Devices group.
Setting up the "Connection" Nodes
Drag a Dial Control to the "Connection" Group Node. Set the Position property to X: 72.00 and Y: 163.00.
Replace the default background images to images from recent import, as follows:
In order to arrange the images of the Dial correctly, the "Pivot Hint" property of each image should be set. This step is necessary for images like the Dial image, which need to rotate. To do this, go to the Solution Explorer panel, and select each of the following images:
For the knob image "NewDial_arrow_middleBmp", enable the "Pivot Hint" property and set the values as follows:
As you can see the knob needs to be repositioned to be in the center of the Dial.
Select the three other background images (multiple selection), enable the "Pivot Hint" property and set the pivot hint as follows:
Add 4 Text Nodes to "Connection" Group Node and move them below Background Node with Ctrl key dragging. Rename them as follows:
Configure the Text Nodes with the following values: Text Style should be OpenSans25.
below.
| TextNode Name |
| 2D Text Node |
- Text
Transformations
Text
Position X
Position Y
TextNode_Connection
Connection
141
61
TextNode_Bluetooth
Bluetooth
149
134
TextNode_Cable
Cable
20
200
TextNode_Other
Other
315
200
Make
sure that the "Background" is the first (top) item in the "Connection" group in order to appear in the background and not cover other nodes.
At this point, you will now have created the Connection options Dial:
Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
SelectThe right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy" or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group.
In the Scene Editor another Textnode with "Connection" is visible.
In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D.
In the Scene Tree panel select TextNode_Devices. In the Properties panel's [ 2D Text Node ] section change the TextNode's Text property and in the [ Transformation ] section adapt its Position according to the table below.
Text and position of the TextNode are configured.
In the Scene Editor you can see that the devices part has got a headline.
TextNode Name
2D Text Node
Transformations
Text
Position X
Position Y
TextNode_Devices
Devices
145
61
From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
In the Scene Tree panel a "List" node is visible directly under the "Background" node.
This list node contains a "ListContentGroupAnchor", that is visible in Scene Tree panel by expanding the List node via a click on the triangle on its left.
In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context
menumenu.
ofListIn inthe Scene Tree
panel.panel the
Openexpanded List now shows a "ListContentGroup" and selecta "Scrollbar".
In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context
menumenu.
of
In the
Scrollbar.Scene Tree panel the expanded Scrollbar shows 6 sub-nodes.
the SelectScene Tree panel right-click on the List in Scene Treenode and choose [ Save as Control... ] from Listthe context menu.
Then
- The "Add New
TemplatesTemplates" dialog will appearbe opened.
In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and
pressclick [ OK ]
. button.
As
A new customizable control "MyList" has been created. It is visible in the
resultSolution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of
that,the youlist.
can
addThe Scene Editor doesn't display SceneOptions any more, it displays the control asMyList. a
customizable
control
in Solution Explorer's Solution > Controls. After confirming this addition, delete List group node inThe Scene Tree panel shows the structure of MyList.
The Properties panel shows the properties of "MyList (Control)".
Configure MyList Control
Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
right-click Youon havethe nownewly created acontrol customizable"MyList" Listand control.
Selectchoose [ Control Properties... ] from Listthe context menumenu.
of
Solution Explorer's Solution > Controls. The
"Configure Public Control
PropertiesProperties" dialog will
appear,be opened.
In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check
the "Is
Public" checkbox and click [ OK ].
The "Configure Public
forControl ScrollbarVisibilityProperties" underdialog Internalwill properties,be closed.
For every instance of the MyList control, there will be a property available to configure the visibility of the scrollbar.
In the Scene Tree navigate back to SceneOptions by pressing the arrow in the top left corner.
The Scene Tree panel navigates back to SceneOptions and
displays SceneOptions and its nodes.
The Scene Editor displays SceneOptions.
In the Scene Tree delete the List node.
The "Delete Item" dialog will be opened.
In the "Delete Item" dialog press [ OK ]
button.The List
Delete
From the
expandedToolbox Listpanel's [ Control
from] SceneOptionssection indrag and drop a MyList control into the Scene Tree
Panel.panel Dragdirectly and droponto the
newlyDevices createdgroup.
ListfromIn Solution Explorer's Solution > Controls tothe Scene Tree
panel, a new MyList node will be visible.
In the Scene Tree panel select "MyList". In the Properties panel's
SceneOptions[ >Control Devices.]
Set Scrollbal Visibility (Properties > Control) of ListVisibility" to "Visible."Visible".
In the Scene Editor a small blue scrollbar becomes visible.
Customize MyList's Scrollbar
Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
Double-double-click on the ListMyList innode.
Scene Tree panel will switch from displaying SceneOptions to displaying the
DevicesMyList grouptemplate.
to
customize
itIn onthe Scene
Tree.Tree
Selectselect the "Thumb" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and replaceselecting itsthe appropriate image in the "Select Item" dialog.
New images
asfor follows:the scrollbar's "Thumb" have been defined.
Then
Thumb Images
Image Path
Normal Image
/Resources/Options/ThumbNormalBmp2Bmp
Pressed Image
/Resources/Options/ThumbPressedBmp2Bmp
Focused Image
In the Scene Tree panel select the "VerticalPrevItem" button
fromnode. insideIn the
PrevItemProperties grouppanel nodechange the button's image properties according to the table below by clicking the magnifying glass icon and
replaceselecting the
New images
asfor follows:the scrollbar's "VerticalPrevItem" have been defined.
VerticalPrevItem Images
Image Path
Lastly,
Normal Image
/Resources/Options/ArrowUpNormalBmp2Bmp
Pressed Image
/Resources/Options/ArrowUpPressedBmp2Bmp
Focused Image
In the Scene Tree panel select the "VerticalNextItem" button
NextItemProperties grouppanel nodechange the button's image properties according to the table below by clicking the magnifying glass icon and
imagesappropriate as follows:
We want a main list with a sub-list that will expand when an itemimage in the main"Select listItem" dialog.
New images for the scrollbar's "VerticalNextItem" have been defined.
VerticalNextItem Images
Image Path
Normal Image
/Resources/Options/ArrowDownNormalBmp2Bmp
Pressed Image
/Resources/Options/ArrowDownPressedBmp2Bmp
Focused Image
The Scene Tree displays SceneOptions.
In the Scene Editor the scroll bar is
clicked.now rendered with the new images in orange color.To
do
that,
first
we
need
Configure MyList's Main Item
Our MyList control will be composed of MainItems. Whenever a Groupcertain NodeMainItem withgets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
In the Scene Tree panel double-click on the MyList node.
Scene Tree panel switches from SceneOptions to MyList.
You are now able to edit the MyList template.
From the Toolbar's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
In the Scene Tree panel there is an OverlayLayout
whichinside willof contain"ListContentGroup".
From the
deviceToolbar's entry[ name2D andNodes the] focus image. Therefore,section drag a
RenderRenderNode Nodeand a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
In the Scene Tree panel there are a RenderNode and a TextNode
frominside the
ToolBoxOverlayLayout that was created in the previous step.
In the Scene Editor the TextNode is visible displaying the TextNode's default text "
NodesText".
2D"
In the Scene Tree panel select the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
In the Scene Tree panel the nodes are renamed according to the following table.
Initial Name
New Name
OverlayLayout
MainItem
TextNode
EntryName
RenderNode
FocusImage
In the Scene Tree panel select the List (Group2D). In the Properties panel's [ Transformation ] section configure the position and size according to the following table.
In Scene Editor the Position and size of the selected rectangle is adjusted according to the new settings.
Target Item
Transformation
Layout
Position X
Position Y
Size X
Size Y
List (Group2D)
58
134
300
300
In the Scene Tree panel select the TextNode2D (MainItem > EntryName). In the Properties panel's [ TextNode2D ] section click on the magnifying glass icon to the right of the Style property.
The Text Style Palette dialog will be opened.
In the Text Style Palette dialog select "OpenSans25" and click [ OK ].
The Text Style Palette will be closed.
In the Scene Editor the EntryName's text will be displayed in a smaller font.
Target Item
Style
OpenSans25
In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
From the Toolbox panel's [Effects] section drag a BitmapBrushColorBlend effect into the
OverlayLayout.Scene RenameTree panel directly onto the
OverlayLayoutMainItem's FocusImage.
In the Scene Tree panel's right side you can see BitmapBrushColorBlend effect under "Effects" when FocusImage is selected.
In the Scene Tree panel select FocusImage. In the Scene Tree panel's right side select the BitmapBrushColorBlend effect. In the Properties panel click on the magnifying glass icon next to
"MainItem".Rename the
RenderNode"Image" toproperty.
"FocusImage".Renamethe TextNode to "EntryName".
The "
MainItem"Choose youItem" have now assembleddialog will be
opened.
In the
main"Choose listItem" itemdialog thatselect the image as in the table below and click [ OK ].
The "Choose Item" dialog will be closed.
Target Item
MyList > List > >ListContentGroup > MainItem > FocusImage > BitmapBrushColorBlend
//ConstructionKit/ConstructionKit/Controls/Images/Common/BorderFocusedBmp
In the Properties panel change the Color property by entering new values for "Red", "Green" and "Blue" according to the table below.
In the Properties panel the configured orange color will be visible.
SetThe Color property can also be edited in the positionColor ofPalette window, which can be opened by clicking on the GroupNodecolor preview rectangle next to the Color property.
Target Item
Color
Red
Green
Blue
MyList > List
to> X:58>ListContentGroup and> Y:134MainItem and> configureFocusImage its> sizeBitmapBrushColorBlend
1.0
0.62
0.00
In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to
X:300"Fill" andaccording Y:300.
In our listto the currentlytable selectedbelow.
main
listIn itemthe shallScene beEditor the FocusImage RenderNode will appear highlighted with an orange outline.
Target Item
Therefore
Layout > StretchBehavior
Fill
Create MyList's Sub-List
A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
From the Toolbox panel's [ Controls ] section under "Touchable" drag a
BitmapBrushColorBlendSub-List effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side ofinto the Scene Tree
Panelpanel anddirectly set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox toonto the List's ListContentGroup.
ListContentGroup
panel the Sub-List node is positioned inside of ListContentGroup just below the MainItem.
The Sub-List
control has a
SublistAnchor. Drag a StackLayout onto this SubListAnchor.
Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".The resulting structure should look like this:
The next step is to configure the TextButton:
Scale: X:0.75 and Y:0.75.
Margin Left: 12
Text: "Connect".
From the TheToolbox TextButton'panel's images[ (NormalNode2D Image,] Pressedsection Imagedrag anda FocusedStackLayout Image)into needthe toScene beTree adjusted:
panel directly onto the Sub-List's SubListAnchor.
In the Scene CopyTree andpanel pastethe StackLayout appears beneath the Sub-List's SubListAnchor.
From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
In the Scene Tree panel the TextButton
appears beneath the StackLayout.
In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
In the Scene Editor the dashed line of the TextButton's boundings will decrease.
Target Item
Transformations
Layout
Scale X
Scale Y
Margin Left
TextButton
0,75
0,75
12
makethe anotherTextButton's copy."Normal RenameImage" property.
In the "Choose Item" dialog select the image according to the table below and click [ OK ].
A new image for "Normal Image" has been configured.
Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
New images are configured for the TextButton.
Target Item
Image Path
Normal Image
Pressed Image
Focused Image
In the Scene Tree panel select the TextButton and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
A copy of the TextButton has been created.
In Scene Tree panel the name of the copy is "TextButton_1".
In Scene Tree panel rename the TextButtons according to the table below. Renaming can be done either via the context menu "Rename" or pressing <F2> on your keyboard.
In Scene Tree panel the TextButtons are renamed.
In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
The texts of the TextButtons have been changed.
Target Item
New Name
Control - Text
TextButton
TextButton_Connect
Connect
TextButton_1
TextButton_Unpair
Unpair
Configure Behaviors for the Focus Handling of MyList's MainItem
Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus and FocusLeave behaviors are used to enable or disable the rendering of the FocusImage.
In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
In the Scene Editor FocusImage (the orange rectangle) is not visible any more.
In the Scene Tree panel an icon indicates the FocusImage node's disabled rendering.
From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
The property "Visible" for both EnableRendering behaviors are configured.
In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
The Properties panel is locked.
From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
In the Properties panel click on the padlock icon in the top right corner a second time.
The Properties panel is unlocked again.
Repeat steps 6 to 8 for the other
asEnableRendering "TextButton_Unpair",behavior andto setconfigure its
TextTargetNode.
propertyto "Unpair". Resulting structure should look like this:
Setting up the "Devices" List behaviors
Focus Handling behaviors
For the Devices entry items, we need to set the
MyList's behaviors for focus
handling.handling Weare wantconfigured.
the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
This is what the configured Behaviors look like now:
As soon as
Whenever the MainItem gets the focus, the FocusImage
shallwill beget visible.
Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
As soon as
loseslooses the focus, the FocusImage
shallwill beget madeinvisible.
invisibleagain.
Therefore
youBehavior
haveVisible
toTarget configureNode
Focus - EnableRendering
True
MyList > List > ListContentGroup > MainItem > FocusImage
FocusLeave - EnableRendering
False
When an item in the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
If you run CGI Player and click on aDevices list item, an orange highlight should indicate that this item is in focus.
Sub-List Handling behaviors
Next, we will set the behaviors so that when a Device entry item ("MainItem") is clicked, a sub-list containing buttonsSub-List will bebecome visible. TheseThis Sub-List contains buttons are for connecting/disconnectingdisconnecting.
From the
phoneToolbox devicepanel's to[ another.Behaviors Drag] section under "Control" drag an "Event Handler" behavior into the Scene Tree panel directly onto the MainItem Group2D node.
In the Scene Tree panel's right side you can see the "Event Handler" behavior
(underwith Condition and Actions slots.
>] Control)section onto theunder "
MainItem"Condition Group- Node.Logic" Then, adddrag a "
Check Logic Condition"Condition" tointo the
ConditionScene ofTree thispanel's right side directly on the Event
HandlerHandler's sinceCondition weslot.
wanttoIn putthe 2Scene conditionsTree together.panel's Underright side you can see the "Check Logic Condition"
addbehavior configured as the EventHandler's condition.
From the Toolbox panel's [ Behaviors ] section under "Condition - Input" drag a "
Check Click"Click" conditionbehavior and
anothera "
Check Key Input"Input" condition.behavior
Inonto the "Check Logic Condition"
properties,behavior's "Conditions" slot.
In the Scene Tree panel's right side you can see the Check Click behavior and the Check Key Input behavior configured as the Check Logic Condition behavior's Conditions.
From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag a "Send Value As Event" behavior into the Scene Tree panel's right side directly onto the Event Handler's "Actions" slot.
In the Scene Tree panel's right side you can see that "Send Value As Event" is configured as the Event Handler's action
In the Scene Tree panel's right side select "Check Logic Condition". In the Properties panel set the
Operationproperty "Operation" to "Or"
, sinceaccording we wantto the
conditiontable below.
The Check Logic Condition's Operation is configured to
becombine its Conditions with an OR operation.
The Check Logic Condition will evaluate to TRUE if either
athe clickCheck Click condition or
athe keyCheck input.Key Input condition is TRUE.
Scene TheTree panel's right side select "Check Key Input"
. condition,In checksthe ifProperties panel configure the KeyCode to Key_Enter according to the table below.
The Check Key Input condition is configured to evaluate to TRUE when the enter key
on the keyboard is pressed.
Therefore
Behavior
Property
Value
Operation
Or
Check Key Input
KeyCode
Key_Enter
In the
KeyCodeScene propertyTree willpanel's beright setside toselect "Key_Enter". the Event Handler's
Add aaction "Send Value As Event". In the Properties panel configure the Target Node, Value and Value Change property as Event"in behaviorthe table below.
Send Value As Event is configured according to the
"Actions"table.
sectionOn ofevery theclick "Eventor Handler".enter
For this action behavior, we want to sendpress a boolean value to the Sub-List as a signal that it should toggle its visibility. So please set the properties of "Send Value as Event" behavior as follows:
The value that will be sent to the Sub-List controlcontrol.
will
Behavior
Property
Value
Send Value As Event
Target Node
/Controls/MyList/List/ListContentGroup/Sub-List
Value
Bool - TRUE
Change Value
Relative
The visibility of the Sub-List shall be oftoggled typeby clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
Bool",Value soProcessing" drag a Value behavior into the Scene Tree panel directly onto MyList's Sub-List node.
In the Scene Tree panel the Sub-List node got marked a yellow square, indicating that a behavior is attached to it.
In the Scene Tree panel's right side you can see the Value behavior.
In the Scene Tree panel's right side select the Sub-List node's Value behavior. In the Properties panel change the Variant
to "Bool". Don't check the nearby checkbox.
The Value behavior's type
has been changed to Bool.
From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag an Action On Value behavior into the Scene Tree's right side directly onto the Value behavior's Receivers slot.
In the Scene Tree panel you can see that an Action On Value behavior is configured as Receiver of the Value
behaviorProcessing hasbehavior.
Action On Value can now be used to
be changed to "Bool" as well:
To configure thean action that iswill performedbe executed when a new value has been received and the visibility of the Sub-List is toggled,toggled.
we
have
toFrom addthe anToolbox panel's [ Behaviors ] section under "
ActionCondition on- Value"Control" drag a Check Processed Value behavior
tointo the
Scene Tree panel's right side directly onto the Action On Value behavior's
receivers.Condition.
panel's right side you can see that the Check Processed Value behavior is configured as condition for the Action On Value behavior.
In the Scene Tree panel's right side select the Check Processed Value behavior. In the Properties panel configure the properties ConditionOperator and ConditionValue as in the table below.
The Check Processed Value behavior's properties have been configured.
Only if
the the value received from "MainItem/
Send ValueSendValue as Event" is TRUE, an action (which will be defined in later steps) shall be performed.
Therefore,we
will
addBehavior
Property
Value
ConditionOperator
Equal
ConditionValue
Bool, TRUE
From the Toolbox panel's [ Behaviors ] section under "Action - Control" drag a "
Set Control State" behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Action slot.
In the Scene Tree panel's right side you can see that the Set Control State behavior is configured as the Action On Value behavior's action.
In the Scene Tree panel's right side select the Set Control State behavior. In the Properties panel configure the properties State and Change To according to the table below.
The Set Control State behavior is configured as in the table below.
The Sub-List will be enabled whenever the condition Check
processedProcessed Value"Value evaluates to TRUE.
Behavior
Property
Value
Set Control State
State
Enabled
ChangeTo
TRUE
Repeat steps 3 to 7: Add a new Action On Value behavior as Value behavior's Receiver, configure another Check Processed Value condition and
configureanother its properties as follows.
The action that shall be performed is a "Set Control
State"State behavior,according to the table and image below.
In the Scene Tree panel's right side you can see the behaviors are configured as in the table and image below.
All behaviors for MyList's Sub-List have been configured.
Behavior
Property
Value
Action On Value_1
Check Processed Value_1
ConditionOperator
Equal
ConditionValue
Bool, FALSE
Set Control State_1
State
Enabled
ChangeTo
FALSE
Test MyList in the Player
Let's test if the configured behaviors of MyList control are functional.
Save your solution either via the menu "File - Save Solution" or via the keyboard <Ctrl + S>.
The solution has been saved.
In the Scene Composer's Toolbar click on "Play selected scenario...".
The resources will be generated and the Player will be started.
In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
In the Player window click the first item of the Devices List, the text of which
is "Text".
In the Player window's Devices List an orange border will
actuallybe enabledisplayed indicating the selected MainItem.
Additionally, the Sub-List
whenwith the
conditionTextButtons above"Connect" and "Unpair" will be displayed below the selected MainItem.
In the Player window click the selected MainItem again.
The TextButtons of the Sub-List will disappear.
In the Scene Composer's Toolbar click the "Close the Player" button.
The Player and CGI Panel window will be closed.
So far we have been working on our MyList control with only one single list entry. Now that this first list entry is met.fully Pleaseconfigured, we can create more of them.
In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
In the Scene Tree panel select the MainItems individually. Then, in the Scene Tree panel's right side, select their configured "Send Value As Event" behaviors. In the Properties panel adapt the TargetNodes to their respective MainItems. I.e. MainItem_4 will be configured as the TargetNode of MainItem_4's "Send Value As Event" behavior.
The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
To easily set the Target Node lock the Properties panel using the pad lock icon in the top right corner. From the Scene Tree panel drag itthe Sub-List node into the Properties panel directly onto the Actionsinput partfield next to "TargetNode". Finally, don't forget to unlock the Properties panel clicking the pad lock icon once again.
SendValueAsEvent of
TargetNode
MainItem
/Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List
MainItem_1
/Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1
MainItem_2
/Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2
MainItem_3
/Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3
MainItem_4
/Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
In the
Scene Tree panel select MainItem's EntryName. In the Properties panel's [ 2D Render Node ] section change the property "
ActionText" onaccording Value"to behaviorthe and configure it as depictedtable below.
the Scene Editor you can see the changed texts.
TextNode2D
Text
Phone (Private)
MainItem_1 > EntryName
Phone (Work)
MainItem_2 > EntryName
New Device
MainItem_3 > EntryName
New Device
MainItem_4 > EntryName
New Device
In the Scene Tree panel select the MainItem's EntryNames individually. In the Properties panel's [ 2D Text Node ]
Check the Options Scene
The Options scene is now finished.
To Addcheck anotherthe "Actionresult onof Value"configuring behaviorthe withfirst scene, open the display view. This view represents the final rendered result and can be opened via the menu: View - Display - Display-0.
The display panel will be opened in a
"Checkfloating processedway Value" condition and "Set Control State" action, same as above. But this time, setdisplaying the
ConditionValuescene property of "Check processed Value" condition to false (Bool + unchecked). And set the "ChangeTo" property of "Set Control State" to false (unchecked).
Try to run your solutionconfigured in the CGIsteps Player.above.
When
you
click
a
mainIn the Scene Composer's Toolbar make sure that the item
"Generate and Play" is selected in the
list,drop-down menu and click the
sub-list[ should> appear.] Whenbutton clickingto the left.
This will generate the asset so it
ais secondavailable time,as itinput for the Player. After that the CGI Panel will
disappearbe again.started.
Copy
In the CGI Panel tick the checkbox next to "Scenes#SceneClimate" and
pasteuncheck "Scenes#SceneHome".
SceneClimate will become visible in the
"MainItem" Group nodes and Sub-List nodes onto the ListContentGroup to create 4 more instances.Player.
You have finished the (Phone Connection) Options Scene tutorial. Generate an asset file as described at the end of Step 1. Load the generated asset into the Player and select the Options scene.
You can now play around with the
controls.configured TurnOptions Controls in the
scene and watch the results.
Grab the Connection Dial
Control and switch between Cable, Bluetooth and Other.
Click into the Devices List to
selectopen the
typeSub-List.
of Connection. Click on
anthe itemSub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects.
Click on several devices in the Devices
listList to make
multiple Sub-Lists visible. Now you can test the
sub-listscrollbar.
buttons
appear
and
disappear.
