GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. The right side displays a List of devices. When a device gets selected, an associated Sub-List Control with two TextButtons will be shown.
Preparing the Options scene
A scene will be created and the camera will be configured in the Render Targets panel.
    In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [ Camera ] section change the sequence number to 2.
    Importing Images
    2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 16 files and press [ Open ]
        Import Resources
        Path
    Configuring the Background
    This scene is composed of two parts: Connection and Devices. For each of these parts a 2D Group node will be created. To position the background image a BimapNode will be configured with one of the images imported in the previous section.
    1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
        Target Item Name
        Group
        Connection
          BitmapNode Background
        Group_1
        Devices
        Property
        Path
        Target Name
        Position X
        Position Y
        Connection
        78.00
        58.00
        Devices
        551.00
        58.00
    The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
        Target Name
        Position X
        Position Y
        Dial
        72.00
        163.00
    The following steps show how to configure the Dial control with new images.
        Property
        Path
        Knob Image
        StateImages
        Image Path
        BackgroundImages 1
        BackgroundImages 2
        Target Name
        Pivot Hint Y
        88,00
        130,50
        130,50
        130,50 130,50
        130,50 130,50
    TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
        Text Position X Position Y
        TextNode_Cable Cable 20 200
        TextNode_Other Other 315 200
    The right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
    1. In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy"  or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
      • In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group.
      • In the Scene Editor another Textnode with "Connection" is visible.
    2. In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
      • In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D.
    3. In the Scene Tree panel select TextNode_Devices. In the Properties panel's [ 2D Text Node ] section change the TextNode's Text property and in the [ Transformation ] section adapt its Position according to the table below.
      • Text and position of the TextNode are configured.
      • In the Scene Editor you can see that the devices part has got a headline.
        TextNode_Devices Devices 145 61
    4. From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
    5. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
    6. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
    7. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
    8. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
      • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
    Configure MyList Control
    Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
    1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
    2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
    5. In the "Delete Item" dialog press [ OK ].
      • The List node is deleted.
    6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
    7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
    Customize MyList's Scrollbar
    Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
        Thumb Images
        Image Path
        VerticalPrevItem Images
        Image Path
        VerticalNextItem Images
        Image Path
    Configure MyList's Main Item
    Our MyList control will be composed of MainItems. Whenever a certain MainItem gets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
    2. From the Toolbar's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
    3. From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
    4. In the Scene Tree panel select the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
        Initial Name
        New Name
        OverlayLayout MainItem
        TextNode EntryName
        RenderNode FocusImage
    5. In the Scene Tree panel select the List (Group2D). In the Properties panel's  [ Transformation ] section configure the position and size according to the following table.
        Target Item
        Transformation
        Layout
        List (Group2D)
        58
        134
        300
        300
    6. In the Scene Tree panel select the TextNode2D (MainItem > EntryName). In the Properties panel's [ TextNode2D ] section click on the magnifying glass icon to the right of the Style property.
      • The Text Style Palette dialog will be opened.
    7. In the Text Style Palette dialog select "OpenSans25" and click [ OK ].
      • The Text Style Palette will be closed.
      • In the Scene Editor the EntryName's text will be displayed in a smaller font.
        Target Item
        Style
        MainItem > EntryName OpenSans25
    In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
    3. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
        Target Item
    4. In the Properties panel change the Color property by entering new values for "Red", "Green" and "Blue" according to the table below.
        Target Item
        Color
        Red
        Green
        Blue
        0.62
        0.00
    5. In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
      • In the Scene Editor the FocusImage RenderNode will appear highlighted with an orange outline.
        Target Item
        Layout > StretchBehavior
        Fill
    Create MyList's Sub-List
    A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
    1. From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
    2. From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
    3. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
    4. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
        Target Item
        Transformations
        Layout
        Scale X
        Scale Y
        Margin Left
        TextButton
        0,75
        0,75
        12
    5. In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
    6. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
    7. Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
        Target Item
        Image Path
        Normal Image
        Pressed Image
        Focused Image
    10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
      • The texts of the TextButtons have been changed.
        Target Item
        New Name
        Control - Text
    Configure Behaviors for the Focus Handling of MyList's MainItem
    Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus and FocusLeave behaviors are used to enable or disable the rendering of the FocusImage.
    1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
    2. From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
      • In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
      • In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
    3. From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
      • In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
      • Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
    4. From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
      • In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
    5. In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
      • The property "Visible" for both EnableRendering behaviors are configured.
    6. In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
      • The Properties panel is locked.
    7. From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
      • In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
    8. In the Properties panel click on the padlock icon in the top right corner a second time.
      • The Properties panel is unlocked again.
    9. Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
      • Whenever the MainItem looses the focus, the FocusImage will get invisible.
        Behavior
        Visible
        Target Node
        Focus - EnableRendering
        FocusLeave - EnableRendering
    1. From the Toolbox panel's [ Behaviors ] section under "Control" drag an "Event Handler" behavior into the Scene Tree panel directly onto the MainItem Group2D node.
      • In the Scene Tree panel's right side you can see the "Event Handler" behavior with Condition and Actions slots.
    2. From the Toolbox panel's [ Behaviors ] section under "Condition - Logic" drag a "Check Logic Condition" into the Scene Tree panel's right side directly on the Event Handler's Condition slot.
      • In the Scene Tree panel's right side you can see the "Check Logic Condition" behavior configured as the EventHandler's condition.
    3. From the Toolbox panel's [ Behaviors ] section under "Condition - Input" drag a "Check Click" behavior and a "Check Key Input" behavior onto the "Check Logic Condition" behavior's "Conditions" slot.
      • In the Scene Tree panel's right side you can see the Check Click behavior and the Check Key Input behavior configured as the Check Logic Condition behavior's Conditions.
    4. From the Toolbox panel's [ Behaviors ] section under "Action  - Property" drag a "Send Value As Event" behavior into the Scene Tree panel's right side directly onto the Event Handler's "Actions" slot.
      • In the Scene Tree panel's right side you can see that "Send Value As Event" is configured as the Event Handler's action
    5. In the Scene Tree panel's right side select "Check Logic Condition". In the Properties panel set the property "Operation" to "Or" according to the table below.
      • The Check Logic Condition's Operation is configured to combine its Conditions with an OR operation.
      • The Check Logic Condition will evaluate to TRUE if either the Check Click condition or the Check Key Input condition is TRUE.
    6. In the Scene Tree panel's right side select "Check Key Input". In the Properties panel configure the KeyCode to Key_Enter according to the table below.
      • The Check Key Input condition is configured to evaluate to TRUE when the enter key on the keyboard is pressed.
        Behavior
        Property
        Value
        Check Logic Condition Operation Or
    7. In the Scene Tree panel's right side select the Event Handler's action "Send Value As Event". In the Properties panel configure the Target Node, Value and Value Change property as in the table below.
      • Send Value As Event is configured according to the table.
      • On every click or enter key press a boolean value will be sent to the Sub-List control.
        Behavior
        Property
        Value
        Value Bool - TRUE
        Change Value
        Relative
    The visibility of the Sub-List shall be toggled by clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
    1. From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag a Value behavior into the Scene Tree panel directly onto MyList's Sub-List node.
      • In the Scene Tree panel the Sub-List node got marked a yellow square, indicating that a behavior is attached to it.
      • In the Scene Tree panel's right side you can see the Value behavior.
    2. In the Scene Tree panel's right side select the Sub-List node's Value behavior. In the Properties panel change the Variant to "Bool". Don't check the nearby checkbox.
      • The Value behavior's type has been changed to Bool.
    3. From the Toolbox panel's [ Behaviors ] section  under "Value Processing" drag an Action On Value behavior into the Scene Tree's right side directly onto the Value behavior's Receivers slot.
      • In the Scene Tree panel you can see that an Action On Value behavior is configured as Receiver of the Value Processing behavior.
      • Action On Value can now be used to configure an action that will be executed when a new value has been received and the visibility of the Sub-List is toggled.
    4. From the Toolbox panel's [ Behaviors ] section under "Condition - Control" drag a Check Processed Value behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Condition.
      • In the Scene Tree panel's right side you can see that the Check Processed Value behavior is configured as condition for the Action On Value behavior.
    5. In the Scene Tree panel's right side select the Check Processed Value behavior. In the Properties panel configure the properties ConditionOperator and ConditionValue as in the table below.
      • The Check Processed Value behavior's properties have been configured.
      • Only if the the value received from "MainItem/SendValue as Event" is TRUE, an action (which will be defined in later steps) shall be performed.
        Behavior
        Property
        Value
        ConditionOperator Equal
        ConditionValue Bool, TRUE
    6. From the Toolbox panel's [ Behaviors ] section under "Action - Control" drag a "Set Control State" behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Action slot.
      • In the Scene Tree panel's right side you can see that the Set Control State behavior is configured as the Action On Value behavior's action.
    7. In the Scene Tree panel's right side select the Set Control State behavior. In the Properties panel configure the properties State and Change To according to the table below.
      • The Set Control State behavior is configured as in the table below.
      • The Sub-List will be enabled whenever the condition Check Processed Value evaluates to TRUE.
        Behavior
        Property
        Value
        Set Control State
        State Enabled
        ChangeTo TRUE
    8. Repeat steps 3 to 7: Add a new Action On Value behavior as Value behavior's Receiver, configure another Check Processed Value condition and another Set Control State according to the table and image below.
      • In the Scene Tree panel's right side you can see the behaviors are configured as in the table and image below.
      • All behaviors for MyList's Sub-List have been configured.
        Behavior
        Property
        Value
        Action On Value_1
        Check Processed Value_1
        ConditionValue Bool, FALSE
        Set Control State_1
        State Enabled
        ChangeTo
        FALSE
    Test MyList in the Player
    Let's test if the configured behaviors of MyList control are functional.
    1. Save your solution either via the menu "File - Save Solution" or via the keyboard <Ctrl + S>.
      • The solution has been saved.
    2. In the Scene Composer's Toolbar click on "Play selected scenario...".
      • The resources will be generated and the Player will be started.
    3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
      • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
    4. In the Player window click the first item of the Devices List, the text of which is "Text".
      • In the Player window's Devices List an orange border will be displayed indicating the selected MainItem.
      • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
    5. In the Player window click the selected MainItem again.
      • The TextButtons of the Sub-List will disappear.
    6. In the Scene Composer's Toolbar click the "Close the Player" button.
      • The Player and CGI Panel window will be closed.
    So far we have been working on our MyList control with only one single list entry. Now that this first list entry is fully configured, we can create more of them.
    1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
      • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
    2. In the Scene Tree panel select the MainItems individually. Then, in the Scene Tree panel's right side, select their configured "Send Value As Event" behaviors. In the Properties panel adapt the TargetNodes to their respective MainItems. I.e. MainItem_4 will be configured as the TargetNode of MainItem_4's "Send Value As Event" behavior.
      • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
        SendValueAsEvent of
        TargetNode
        MainItem /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List
        MainItem_1 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1
        MainItem_2 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2
        MainItem_3
        /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3
        MainItem_4
        /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
    3. In the Scene Tree panel select MainItem's EntryName. In the Properties panel's [ 2D Render Node ] section change the property "Text" according to the table below.
      • In the Scene Editor you can see the changed texts.
        TextNode2D
        Text
        Phone (Private)
        MainItem_1 > EntryName Phone (Work)
        MainItem_2 > EntryName New Device
        MainItem_3 > EntryName
        New Device
        MainItem_4 > EntryName
        New Device
    4. In the Scene Tree panel select the MainItem's EntryNames individually. In the Properties panel's [ 2D Text Node ]
    Check the Options Scene
    The Options scene is now finished.
    1. To check the result of configuring the first scene, open the display view. This view represents the final rendered result and can be opened via the menu: View - Display - Display-0.
    2. In the Scene Composer's Toolbar make sure that the item "Generate and Play" is selected in the drop-down menu and click the [ > ] button to the left.
    3. In the CGI Panel tick the checkbox next to "Scenes#SceneClimate" and uncheck "Scenes#SceneHome".
      • SceneClimate will become visible in the Player.
    4. You can now play around with the configured Options Controls in the scene and watch the results.
      • Grab the Connection Dial Control and switch between Cable, Bluetooth and Other.
      • Click into the Devices List to open the Sub-List.
      • Click on the Sub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects.
      • Click on several devices in the Devices List to make multiple Sub-Lists visible. Now you can test the scrollbar.
