GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On theThe right side isdisplays a List withof devices. When a device gets selected, an associated Sub-List Controls.Control Thewith Sub-Listtwo ControlTextButtons will appearbe dependingshown. on the item selected in the List.
Preparing the Options scene
A scene will be created and the camera will be configured in the Render Targets panel.
Importing Images
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
This scene is composed of two parts: Connection and Devices. For each of these parts a 2D Group node will be created. To position the background image a BimapNode will be configured with one of the images imported in the previous section.
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
      Target Name
      Position X
      Position Y
      Connection
      78.00
      58.00
      Devices
      551.00
      58.00
The left side of the scene offers the possibility to choose the connection type. The Scene Composer's built-in Dial control will be customized with new images that fit to the scene's design. TextNodes will be added as labels.
      Target Name
      Position X
      Position Y
      Dial
      72.00
      163.00
The following steps show how to configure the Dial control with new images.
      Property
      Path
      Knob Image
      StateImages
      Image Path
      BackgroundImages 1
      BackgroundImages 2
      Target Name
      Pivot Hint Y
      88,00
      130,50
      130,50
      130,50 130,50
      130,50 130,50
TextNodes will be configured with an attractive font and positioned as labels for choosing the connection type.
      Text Position X Position Y
      TextNode_Cable Cable 20 200
      TextNode_Other Other 315 200
The right side of the scene displays a list of devices. Scene Composer's built-in List control will be expanded to facilitate customization later on. Based on the existing List control a new reusable MyList control template will be created.
    In the Scene Tree panel copy the TextNode_Connection from the Connection Group2D either via the context menu "Copy"  or via the keyboard shortcut <Ctrl + C>. Paste the TextNode into the Devices Group2D either via the context menu "Paste" or via the keyboard shortcut <Ctrl + V>.
      In the Scene Tree panel you can see that TextNode_Connection has been copied to the Devices group. In the Scene Editor another Textnode with "Connection" is visible. In the Scene Tree panel select the new TextNode_Connection from the Devices group and rename it to TextNode_Devices either via the context menu "rename" or via the keyboard shortcut <F2>.
        In the Scene Tree panel you can see a TextNode called TextNode_Devices inside of the Devices Group2D. In the Scene Tree panel select TextNode_Devices. In the Properties panel's [ 2D Text Node ] section change the TextNode's Text property and in the [ Transformation ] section adapt its Position according to the table below.
          Text and position of the TextNode are configured. In the Scene Editor you can see that the devices part has got a headline.
          TextNode Name 2D Text Node Transformations Text Position X Position Y TextNode_Devices Devices 145 61 From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
          In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
          In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
          In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
          In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
          • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
          Configure MyList Control
          Scene Composer's List internally holds a property for the scrollbar's visibility, which is not shown in the Properties panel by default. The following steps show how to access a list of hidden properties. For this sample solution we will make the scrollbar's visibility property publicly editable in the Properties panel.
          1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
          2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
          5. In the "Delete Item" dialog press [ OK ].
            • The List node is deleted.
          6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
          7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
          Customize MyList's Scrollbar
          Scene Composer's default scrollbar has a blue base color. For our orange based design the scrollbar will be customized in the steps below.
              Thumb Images
              Image Path
              VerticalPrevItem Images
              Image Path
              VerticalNextItem Images
              Image Path
          Configure MyList's Main Item
          Our MyList control will be composed of MainItems. Whenever a certain MainItem gets selected, the appropriate Sub-List will be displayed. The following steps explain how to build up a MainItem.
          2. From the Toolbar's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
          3. From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
          4. In the Scene Tree panel renameselect the nodes created in the previous steps and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
              Initial Name
              New Name
              OverlayLayout MainItem
              TextNode EntryName
              RenderNode FocusImage
          5. In the Scene Tree panel select the List (Group2D). In the Properties panelpanel's  [ Transformation ] section configure the position and size according to the following table.
          6. Size X and Size Y properties are initially set to "Automatic" and greyed out. Clicking onto the "A" next to the greyed-out input field allows you to edit these properties.
            Target Item
            Transformation
            Layout
            List (Group2D)
            58
            134
            300
            300
          7. In the Scene Tree panel select the TextNode2D (MainItem > EntryName). In the Properties panel's [ TextNode2D ] section click on the magnifying glass icon to the right of the Style property.
            • The Text Style Palette dialog will be opened.
            In the Text Style Palette dialog select "OpenSans25" and click [ OK ].
              The Text Style Palette will be closed. In the Scene Editor the EntryName's text will be displayed in a smaller font.
              Target Item
              Style
              MainItem > EntryName OpenSans25
              In a list it is useful to highlight the selected item. This will be done using a FocusImage drawing a border around the focused MainItem.
              3. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
                  Target Item
              4. In the Properties panel click on the Color rectangle next to the Color property.
                • The "Color Palette" dialog will be opened.
                In the "Color Palette" dialog change the Color valueproperty by entering new values for "Red", "Green" and "Blue" according to the table below.
                  Target Item
                  Color
                  Red
                  Green
                  Blue
                  0.62
                  0.00
                In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
                • In the Scene Tree panelEditor the FocusImage RenderNode will appear highlighted with an orange outline.
                  Target Item
                  Layout > StretchBehavior
                  Fill
                Create MyList's Sub-List
                A Sub-List will be used to display 2 TextButtons to "Connect" or "Unpair" the associated device. The TextButtons will be positioned by a StackLayout. New images for normal, pressed and focused image will be defined.
                1. From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
                2. From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
                3. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
                4. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
                    Target Item
                    Transformations
                    Layout
                    Scale X
                    Scale Y
                    Margin Left
                    TextButton
                    0,75
                    0,75
                    12
                5. In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
                6. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
                7. Repeat steps 5 and 6 for the TextButton's "Pressed Image" and "Focused Image".
                    Target Item
                    Image Path
                    Normal Image
                    Pressed Image
                    Focused Image
                10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
                  • InThe Scenetexts Tree panelof the TextButtons arehave renamed.been changed.
                    Target Item
                    New Name
                    Control - Text
                SettingConfigure upBehaviors for the Focus Handling of MyList's BehaviorsMainItem
                Whenever MyList's MainItem gets focused, an orange border shall be displayed. Focus Handlingand BehaviorsFocusLeave behaviors are used to enable or disable the rendering of the FocusImage.
                1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
                2. From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
                  • In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
                  • In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
                3. From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
                  • In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
                  • Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
                4. From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
                  • In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
                5. In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
                  • The property "Visible" for both EnableRendering behaviors are configured.
                6. In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
                  • The Properties panel is locked.
                7. From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
                  • In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
                8. In the Properties panel click on the padlock icon in the top right corner a second time.
                  • The Properties panel is unlocked again.
                9. Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
                  • Whenever the MainItem looses the focus, the FocusImage will get invisible.
                    Behavior
                    Visible
                    Target Node
                    Focus - EnableRendering
                    FocusLeave - EnableRendering
                1. From the Toolbox panel's [ Behaviors ] section under "Control" drag an "Event Handler" behavior into the Scene Tree panel directly onto the MainItem Group2D node.
                  • In the Scene Tree panel's right side you can see the "Event Handler" behavior with Condition and Actions slots.
                2. From the Toolbox panel's [ Behaviors ] section under "Condition - Logic" drag a "Check Logic Condition" into the Scene Tree panel's right side directly on the Event Handler's Condition slot.
                  • In the Scene Tree panel's right side you can see the "Check Logic Condition" behavior configured as the EventHandler's condition.
                3. From the Toolbox panel's [ Behaviors ] section under "Condition - Input" drag a "Check Click" behavior and a "Check Key Input" behavior onto the "Check Logic Condition" behavior's "Conditions" slot.
                  • In the Scene Tree panel's right side you can see the Check Click behavior and the Check Key Input behavior configured as the Check Logic Condition behavior's Conditions.
                4. From the Toolbox panel's [ Behaviors ] section under "Action  - Property" drag a "Send Value As Event" behavior into the Scene Tree panel's right side directly onto the Event Handler's "Actions" slot.
                  • In the Scene Tree panel's right side you can see that "Send Value As Event" is configured as the Event Handler's action
                5. In the Scene Tree panel's right side select "Check Logic Condition". In the Properties panel set the property "Operation" to "Or" according to the table below.
                  • The Check Logic Condition's Operation is configured to combine its Conditions with an OR operation.
                  • The Check Logic Condition will evaluate to TRUE if either the Check Click condition or the Check Key Input condition is TRUE.
                6. In the Scene Tree panel's right side select "Check Key Input". In the Properties panel configure the KeyCode to Key_Enter according to the table below.
                  • The Check Key Input condition is configured to evaluate to TRUE when the enter key on the keyboard is pressed.
                    Behavior
                    Property
                    Value
                    Check Logic Condition Operation Or
                7. In the Scene Tree panel's right side select the Event Handler's action "Send Value As Event". In the Properties panel configure the Target Node, Value and Value Change property as in the table below.
                  • Send Value As Event is configured according to the table.
                  • On every click or enter key press a boolean value will be sent to the Sub-List control.
                8. To easily set the Target Node lock the Properties panel using the pad lock icon in the top right corner. From the Scene Tree panel drag the Sub-List node into the Properties panel directly onto the input field next to "TargetNode". Finally, don't forget to unlock the Properties panel clicking the pad lock icon once again.
                  Behavior
                  Property
                  Value
                  Value Bool - TRUE
                  Change Value
                  Relative
                The visibility of the Sub-List shall be toggled by clicking the MainItem. Let's configure the necessary behaviors to the Sub-List.
                1. From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag a Value behavior into the Scene Tree panel directly onto MyList's Sub-List node.
                  • In the Scene Tree panel the Sub-List node got marked a yellow square, indicating that a behavior is attached to it.
                  • In the Scene Tree panel's right side you can see the Value behavior.
                2. In the Scene Tree panel's right side select the Sub-List node's Value behavior. In the Properties panel change the Variant to "Bool". Don't check the nearby checkbox.
                  • The Value behavior's type has been changed to Bool.
                3. From the Toolbox panel's [ Behaviors ] section  under "Value Processing" drag an Action On Value behavior into the Scene Tree's right side directly onto the Value behavior's Receivers slot.
                  • In the Scene Tree panel you can see that an Action On Value behavior is configured as Receiver of the Value Processing behavior.
                  • Action On Value can now be used to configure an action that will be executed when a new value has been received and the visibility of the Sub-List is toggled.
                4. From the Toolbox panel's [ Behaviors ] section under "Condition - Control" drag a Check Processed Value behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Condition.
                  • In the Scene Tree panel's right side you can see that the Check Processed Value behavior is configured as condition for the Action On Value behavior.
                5. In the Scene Tree panel's right side select the Check Processed Value behavior. In the Properties panel configure the properties ConditionOperator and ConditionValue as in the table below.
                  • The Check Processed Value behavior's properties have been configured.
                  • Only if the the value received from "MainItem/SendValue as Event" is TRUE, an action (which will be defined in later steps) shall be performed.
                    Behavior
                    Property
                    Value
                    ConditionOperator Equal
                    ConditionValue Bool, TRUE
                6. From the Toolbox panel's [ Behaviors ] section under "Action - Control" drag a "Set Control State" behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Action slot.
                  • In the Scene Tree panel's right side you can see that the Set Control State behavior is configured as the Action On Value behavior's action.
                7. In the Scene Tree panel's right side select the Set Control State behavior. In the Properties panel configure the properties State and Change To according to the table below.
                  • The Set Control State behavior is configured as in the table below.
                  • The Sub-List will be enabled whenever the condition Check Processed Value evaluates to TRUE.
                    Behavior
                    Property
                    Value
                    Set Control State
                    State Enabled
                    ChangeTo TRUE
                8. Repeat steps 3 to 7: Add a new Action On Value behavior as Value behavior's Receiver, configure another Check Processed Value condition and another Set Control State according to the table and image below.
                  • In the Scene Tree panel's right side you can see the behaviors are configured as in the table and image below.
                  • All behaviors for MyList's Sub-List have been configured.
                    Behavior
                    Property
                    Value
                    Action On Value_1
                    Check Processed Value_1
                    ConditionValue Bool, FALSE
                    Set Control State_1
                    State Enabled
                    ChangeTo
                    FALSE
                Test MyList in the Player
                Let's test if the configured behaviors of MyList control are functional.
                1. Save your solution either via the menu "File - Save Solution" or via the keyboard <Ctrl + S>.
                  • The solution has been saved.
                2. In the Scene Composer's Toolbar click on "Play selected scenario...".
                  • The resources will be generated and the Player will be started.
                3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
                  • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
                4. In the Player window click intothe first item of the empty Devices List, where you would expect the firsttext listof element.which is "Text".
                  • In the Player window's empty Devices List an orange border will be displayed indicating the selected MainItem.
                  • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
                5. In the Player window click the selected MainItem again.
                  • The TextButtons of the Sub-List will disappear.
                6. In the Scene Composer's Toolbar click the "Close the Player" button.
                  • The Player and CGI Panel window will be closed.
                So far we have been working on our MyList control with only one single list entry. Now that this first list entry is fully configured, we can create more of them.
                1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
                  • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
                2. In the Scene Tree panel select the MainItems individually. ThenThen, in the Scene Tree panel's right side, select their configured "Send Value As Event" behaviors. In the Properties panel adapt the TargetNodes to their respective MainItems. I.e. MainItem_4 will be configured as the TargetNode of MainItem_4's "Send Value As Event" behavior.
                  • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
                3. To easily set the Target Node lock the Properties panel using the pad lock icon in the top right corner. From the Scene Tree panel drag the Sub-List node into the Properties panel directly onto the input field next to "TargetNode". Finally, don't forget to unlock the Properties panel clicking the pad lock icon once again.
                  SendValueAsEvent of
                  TargetNode
                  MainItem /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List MainItem_1 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_1 MainItem_2 /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_2 MainItem_3
                  /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_3 MainItem_4
                  /Controls/MyList/Group2D:List/Group2D:ListContentGroup/CompositeNode2D:Sub-List_4
                4. In
                the
                First,Scene addTree apanel TextNodeselect MainItem's EntryName. In the Properties panel's [ 2D Render Node ] section change the property "Text" according to the GroupNodetable "Devices"below.
                for
                  In the "Devices"Scene label.Editor
                  Renameyou itcan tosee TextNode_Devicesthe andchanged settexts.
                  its
                  text to "Devices"TextNode2D
                  andText
                  set its positionMainItem to> X:145EntryName
                  Y:Phone 61.(Private) MainItem_1 > EntryName Phone (Work) MainItem_2 > EntryName New Device MainItem_3 > EntryName
                  New Device MainItem_4 > EntryName
                  New Device In the Scene Tree panel select the MainItem's EntryNames individually. In the Properties panel's [ 2D Text Node ]
                  Check the Options Scene
                  The Options scene is now finished.
                  To
                  Make sure to updatecheck the "Send Value as Event" behavior's "TargetNode" property for each MainItem so that it will enable/disable the appropriate sub-lists.
                  As final step, set the Textresult of configuring the first 2scene, listopen itemsthe display view. This view represents the final rendered result and can be opened via the menu: View - Display - Display-0.
                    The display panel will be opened in a floating way displaying the scene configured in the steps above.
                    In the Scene Composer's Toolbar make sure that the item "Generate and Play" is selected in the drop-down menu and click the [ > ] button to the left.
                      This will generate the asset so it is available as input for the Player. After that the CGI Panel will be started.
                      In the CGI Panel tick the checkbox next to "Phone(Private)"Scenes#SceneClimate" and uncheck "Phone(Work)"Scenes#SceneHome". and
                        SceneClimate will become visible in the last 3 items as "New Device".Player.
                        You have finished the (Phone Connection) Options Scene tutorial. Generate an asset file as described at the end of Step 1. Load the generated asset into the Player and select the Options scene.
                        You can now play around with the controls.configured TurnOptions Controls in the scene and watch the results.
                          Grab the Connection Dial Control and switch between Cable, Bluetooth and Other. Click into the Devices List to selectopen the typeSub-List. of Connection. Click on anthe itemSub-List's "Connect" and "Unpair" TextButtons and watch the configuredhover and click effects. Click on several devices in the Devices listList to make multiple Sub-Lists visible. Now you can test the sub-listscrollbar. buttons appear and disappear.
