GettingStartedControls Part 3
appear
depending (Phoneon Connection)the Optionsitem Scene
selected in the List.
OurAnd this is what the final scene will look like this:like:
Our
goalPreparing is to create a Phone Connectionthe Options scene
with
a Dial Control and a List with a Sub-List Control, that will appear and disappear when an item in the List is clicked.
Create a new scene
usingvia the
Scenemenu menu's"Scene" - "New 2D
Scene…Scene" or press < Ctrl+2 > on your keyboard
The "
Add menuNew item.Scene
Name
In the
newfirst scenerow select "/Scenes" from the drop-down menu. Enter "SceneOptions"
as name and press [ OK ]. We
always use the prefix "Scene" to have all scenes listed
nearnext to each other in the Solution Explorer
view.panel.
A new scene "SceneOptions" is created and visible in the Solution Explorer panel in folder "Scenes".
The new scene is opened in the Scene Editor and in the Scene Tree panel.
In the Scene Tree panel you can see that the scene already has a camera.
In the Render Targets panel you can see that the camera is already added to the RenderTarget.
In the Render Targets panel check the checkbox of "SceneOptions\Camera" in order to enable rendering.
In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [ Camera ] section change the sequence number to 2.
The camera's sequence number is set to 2.
In the Scene Tree panel the red Information/Warning/Error square disappears.
Importing Images
In the main menu select Import > Import Resources...
The "Import Resources" dialog will be opened.
In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
The "Import Images" dialog will be opened.
Import Resources
Path
In the "Import Images" dialog select folder "/Resources", make sure to create a new folder "Options" for the imported images and click [ OK ].
In the Solution Explorer you can see that there is a new folder "Options" in folder "Resources" that contains the 16 imported images.
The images have been imported and can be used in the Scene Composer solution.
The
Configuring scenethe isBackground
now
createdFrom andthe alreadyToolbox openedpanel's inside[ Node 2D ] section drag a 2D Group node into the Scene Tree
panel.directly Itonto alreadythe containsnode "SceneOptions".
In the Scene Tree panel you can see a
standard2D camera.Group Thenode.
Viewport
size
From the Toolbox panel's [ Node 2D ] section drag a BitmapNodes onto the 2D Group node.
In the Scene Tree panel you can see that a BitmapNodes has been created.
In the Scene Tree panel select the 2D Group and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
A copy of the
camera2D followsGroup with its BitmapNode has been created.
In Scene Tree panel the
sizename of the
Rendercopy is "Group_1".
In the Scene Tree panel select the nodes added in the steps before one after the other and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard. Apply the names provided in the table below.
In the Scene Tree panel you can see that the nodes have been renamed.
Target (1024x768)Item
Name
Group
Connection
BitmapNode
Background
Group_1
Devices
BitmapNode
Background
In the Scene Tree panel select both BitmapNodes called "Background".
TheThis new scene's camera should automaticallycan be
connectedachieved by selecting one BitmapNode, holding down the <Ctrl> key and keeping it pressed while clicking on the second BitmapNode. In Scene Tree panel's right side select the "BitmapBrushBlend" effect. In the Properties panel's [ Effect ] section click on the magnifying glass icon next to the
RenderImage Target.property.
IfitIn isn't,the pleaseProperties panel you can now edit the BitmapBrushBlend effect for both BitmapNodes.
The "Choose Item" dialog will be opened.
In the "Choose Item" dialog select the image as in the table below and click [ OK ].
The Choose Item dialog will be closed.
In the Scene Editor a background image is visible displaying a vertical grey-black gradient.
Property
Path
In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
In Scene Editor two rectangles with a gradient background are visible.
Target Name
Position X
Position Y
Connection
78.00
58.00
Devices
551.00
58.00
From the Toolbox panel's [ Controls ] section under Touchable drag
a Dial control into the
CameraScene Tree panel directly onto the
default"Connection" RenderTargetgroup.
In the Scene Tree panel a Dial control has been added into the "Connection" group.
In the Scene Editor the Dial control is visible in the
Rendertop Targetsleft panel.corner Changeof the
Sequenceleft Numbergradient image.
In the Scene Tree panel select the Dial control. In the Properties panel's [ Transformation ] section adjust its position according to
the table below.
In the Scene Editor the Dial control is positioned in the lower center of the gradient image.
Target Name
Position X
Position Y
Dial
72.00
163.00
In the Properties panel's [ Control ] section click on the magnifying glass icon next to property "Knob Image".
In the Scene Editor an orange ring will become visible.
Property
Path
Knob Image
In the Properties panel's [ Control ] section click on the the "BackgroundImages" section.
In the Properties panel the "BackgroundImages" section will be expanded.
In the Properties panel click on the magnifying glass next to "BackgroundImages 0".
In the Choose Item dialog navigate to "/Resources/Options/NewDial_background_leftBmp", select this image and click [ OK ].
In the Properties panel the first BackgroundImage has been configured.
Repeat steps 4 and 5 to configure the remaining BackgroundImages as in the table below.
In Properties panel all BackgroundImages are configured.
In Scene Editor you can see the newly configured images.
StateImages
Image Path
BackgroundImages 0
BackgroundImages 1
BackgroundImages 2
In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [ Bitmap ] section enable "Pivot Hint" by checking the respective checkbox.
A new property "Pivot Hint" becomes visible.
Configure the "Pivot Hint" as in the table below.
The Pivot Hint for the Knob Image is configured correctly.
In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 10 and 11, enabling and configuring the Pivot Hint of these three images according to the table below.
The Pivot Hint is configured correctly.
In Scene Editor the Dial's images are neatly aligned. The images have a common center.
Target Name
Enable Pivot Hint
Pivot Hint X
Pivot Hint Y
true
84,50
88,00
true
130,50
130,50
true
130,50
130,50
NewDial_Background_rightBmp
true
130,50
130,50
From the Toolbox panel's [ Nodes 2D ] drag and drop a TextNode into the Scene Tree panel directly onto the "Connection" group node.
In the Scene Tree panel a TextNode will become visible.
In the Scene Editor the text "Text" will appear.
In the Scene Tree panel select the new TextNode. In the Properties panel's [ 2D Text Node ] section click on the magnifying glass icon next to property "Style".
The "Text Style Palette" dialog will be opened.
In the "Text Style Palette" dialog select "OpenSans25" and click [ OK ].
In Scene Editor the Text Style of the TextNode will change.
In the Scene Tree panel right click onto Connection and select "Clone..." from the context menu.
The "Clone Item" dialog will be opened.
In the "Clone Item" dialog change to the "Multiple Clone" tab. Configure "Number of Copies" to "3" and click [ OK ].
In the Scene Tree panel 4 TextNodes are now available inside the "Connection" group.
In the Scene Tree panel select the newly created TextNodes one after the other and configure their names in the Scene Tree panel and the remaining properties in the Properties panel
soas that this scene will be rendered abovein the
SceneClimate.table below.
Before
anything else, let's import a few images for the Options scene by clicking (Import > Import Resources) and selecting the files in /cgi_studio_content/Resources/GettingStartedControls/Options:
First, drag two Group Nodes from the Toolbox into the Scene Tree.
The
firstTextNodes groupare willfully representconfigured.
theThe "Connection"final Dial and the second group will be for the "Devices" List. Rename the first Group Node to "Connection" and the second Group Node to "Devices". Under each group, add a Bitmap Node from the Toolbox and rename it to "Background".
Select oneresult of the BitmapConnection Nodepart can be seen in the Scene Tree Panel. Then, select the BitmapBrushBlend Effect and set the Image property to the recently imported background image as shown below: And do the same for the other Bitmap Node.
Change the Position property of "Connection" to X: 78 and Y: 58. Change the Position property of "Devices" to X: 551 and Y: 58. Now we have two background images for Connection group and Devices group.
Setting up the "Connection" Nodes
Drag a Dial Control to the "Connection" Group Node. Set the Position property to X: 72.00 and Y: 163.00.
Replace the default background images to images from recent import, as follows:
In order to arrange the images of the Dial correctly, the "Pivot Hint" property of each image should be set. This step is necessary for images like the Dial image, which need to rotate. To do this, go to the Solution Explorer panel, and select each of the following images:
For the knob image "NewDial_arrow_middleBmp", enable the "Pivot Hint" property and set the values as follows:
As you can see the knob needs to be repositioned to be in the center of the Dial.
Select the three other background images (multiple selection), enable the "Pivot Hint" property and set the pivot hint as follows:
Add 4 Text Nodes to "Connection" Group Node and move them below Background Node with Ctrl key dragging. Rename them as follows:
Configure the Text Nodes with the following values: Text Style should be OpenSans25.
below.
| TextNode Name |
| 2D Text Node |
- Text
Transformations
Text
Position X
Position Y
TextNode_Connection
Connection
141
61
TextNode_Bluetooth
Bluetooth
149
134
TextNode_Cable
Cable
20
200
TextNode_Other
Other
315
200
Make
sure that the "Background" is the first (top) item in the "Connection" group in order to appear in the background and not cover other nodes.
At this point, you will now have created the Connection options Dial:
From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
In the Scene Tree panel a "List" node is visible directly under the "Background" node.
This list node contains a "ListContentGroupAnchor", that is visible in Scene Tree panel by expanding the List node via a click on the triangle on its left.
In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
In the Scene Tree panel the expanded List now shows a "ListContentGroup" and a "Scrollbar".
In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
In the Scene Tree panel the expanded Scrollbar shows 6 sub-nodes.
In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
The "Add New Templates" dialog will be opened.
In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
The Scene Editor doesn't display SceneOptions any more, it displays the control MyList.
The Scene Tree panel shows the structure of MyList.
The Properties panel shows the properties of "MyList (Control)".
Configure MyList Control
In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
The "Configure Public Control Properties" dialog will be opened.
In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
The "Configure Public Control Properties" dialog will be closed.
For every instance of the MyList control, there will be a property available to configure the visibility of the scrollbar.
In the Scene Tree navigate back to SceneOptions by pressing the arrow in the top left corner.
The Scene Tree panel navigates back to SceneOptions and displays SceneOptions and its nodes.
The Scene Editor displays SceneOptions.
In the Scene Tree delete the List node.
The "Delete Item" dialog will be opened.
In the "Delete Item" dialog press [ OK ].
The List node is deleted.
From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
In the Scene Tree panel, a new MyList node will be visible.
In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
In the Scene Editor a small blue scrollbar becomes visible.
Customize MyList's Scrollbar
In the Scene Tree panel double-click on the MyList node.
Scene Tree panel will switch from displaying SceneOptions to displaying the MyList template.
In the Scene Tree panel select the "Thumb" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and selecting the appropriate image in the "Select Item" dialog.
New images for the scrollbar's "Thumb" have been defined.
Thumb Images
Image Path
Normal Image
/Resources/Options/ThumbNormalBmp2Bmp
Pressed Image
/Resources/Options/ThumbPressedBmp2Bmp
Focused Image
In the Scene Tree panel select the "VerticalPrevItem" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and selecting the appropriate image in the "Select Item" dialog.
New images for the scrollbar's "VerticalPrevItem" have been defined.
VerticalPrevItem Images
Image Path
Normal Image
/Resources/Options/ArrowUpNormalBmp2Bmp
Pressed Image
/Resources/Options/ArrowUpPressedBmp2Bmp
Focused Image
In the Scene Tree panel select the "VerticalNextItem" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and selecting the appropriate image in the "Select Item" dialog.
New images for the scrollbar's "VerticalNextItem" have been defined.
VerticalNextItem Images
Image Path
Normal Image
/Resources/Options/ArrowDownNormalBmp2Bmp
Pressed Image
/Resources/Options/ArrowDownPressedBmp2Bmp
Focused Image
The Scene Tree displays SceneOptions.
In the Scene Editor the scroll bar is now rendered with the new images in orange color.
Configure MyList's Main Item
Scene Tree panel switches from SceneOptions to MyList.
You are now able to edit the MyList template.
From the Toolbar's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
In the Scene Tree panel there is an OverlayLayout inside of "ListContentGroup".
From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
In the Scene Tree panel there are a RenderNode and a TextNode inside the OverlayLayout that was created in the previous step.
In the Scene Editor the TextNode is visible displaying the TextNode's default text "Text".
In the Scene Tree panel rename the nodes created in the previous steps rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
In the Scene Tree panel the nodes are renamed according to the following table.
Initial Name
New Name
OverlayLayout
MainItem
TextNode
EntryName
RenderNode
FocusImage
In the Scene Tree panel select the List (Group2D). In the Properties panel [ Transformation ] section configure the position and size according to the following table.
In Scene Editor the Position and size of the selected rectangle is adjusted according to the new settings.
Target Item
Transformation
Layout
Position X
Position Y
Size X
Size Y
List (Group2D)
58
134
300
300
From the Toolbox panel's [Effects] section drag a BitmapBrushColorBlend effect into the Scene Tree panel directly onto the MainItem's FocusImage.
In the Scene Tree panel's right side you can see BitmapBrushColorBlend effect under "Effects" when FocusImage is selected.
In the Scene Tree panel select FocusImage. In the Scene Tree panel's right side select the BitmapBrushColorBlend effect. In the Properties panel click on the magnifying glass icon next to the "Image" property.
The "Choose Item" dialog will be closed.
Target Item
MyList > List > >ListContentGroup > MainItem > FocusImage > BitmapBrushColorBlend
//ConstructionKit/ConstructionKit/Controls/Images/Common/BorderFocusedBmp
In the Properties panel click on the Color rectangle next to the Color property.
The "Color Palette" dialog will be opened.
In the "Color Palette" dialog change the Color value by entering new values for "Red", "Green" and "Blue" according to the table below.
In the Properties panel the configured orange color will be visible.
Target Item
Color
Red
Green
Blue
1.0
0.62
0.00
In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
In the Scene Tree panel the FocusImage RenderNode will appear with an orange outline.
Target Item
Layout > StretchBehavior
Fill
Create MyList's Sub-List
From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
In the Scene Tree panel the Sub-List node is positioned inside of ListContentGroup just below the MainItem.
The Sub-List has a SubListAnchor.
From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
In the Scene Tree panel the StackLayout appears beneath the Sub-List's SubListAnchor.
From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
In the Scene Tree panel the TextButton appears beneath the StackLayout.
In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
In the Scene Editor the dashed line of the TextButton's boundings will decrease.
Target Item
Transformations
Layout
Scale X
Scale Y
Margin Left
TextButton
0,75
0,75
12
In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
In the "Choose Item" dialog select the image according to the table below and click [ OK ].
A new image for "Normal Image" has been configured.
Repeat steps 5 and 6 for "Pressed Image" and "Focused Image".
New images are configured for the TextButton.
Target Item
Image Path
Normal Image
Pressed Image
Focused Image
In the Scene Tree panel select the TextButton and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
A copy of the TextButton has been created.
In Scene Tree panel the name of the copy is "TextButton_1".
In Scene Tree panel rename the TextButtons according to the table below. Renaming can be done either via the context menu "Rename" or pressing <F2> on your keyboard.
In Scene Tree panel the TextButtons are renamed.
In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
Target Item
New Name
Control - Text
TextButton
TextButton_Connect
Connect
TextButton_1
TextButton_Unpair
Unpair
Setting up MyList's Behaviors
Focus Handling Behaviors
In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
In the Scene Editor FocusImage (the orange rectangle) is not visible any more.
In the Scene Tree panel an icon indicates the FocusImage node's disabled rendering.
From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
The property "Visible" for both EnableRendering behaviors are configured.
In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
The Properties panel is locked.
From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
In the Properties panel click on the padlock icon in the top right corner a second time.
The Properties panel is unlocked again.
Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
MyList's behaviors for focus handling are configured.
Whenever the MainItem gets the focus, the FocusImage will get visible.
Whenever the MainItem looses the focus, the FocusImage will get invisible.
Behavior
Visible
Target Node
Focus - EnableRendering
True
MyList > List > ListContentGroup > MainItem > FocusImage
FocusLeave - EnableRendering
False
From the Toolbox panel's [ Behaviors ] section under "Control" drag an "Event Handler" behavior into the Scene Tree panel directly onto the MainItem Group2D node.
In the Scene Tree panel's right side you can see the "Event Handler" behavior with Condition and Actions slots.
From the Toolbox panel's [ Behaviors ] section under "Condition - Logic" drag a "Check Logic Condition" into the Scene Tree panel's right side directly on the Event Handler's Condition slot.
In the Scene Tree panel's right side you can see the "Check Logic Condition" behavior configured as the EventHandler's condition.
From the Toolbox panel's [ Behaviors ] section under "Condition - Input" drag a "Check Click" behavior and a "Check Key Input" behavior onto the "Check Logic Condition" behavior's "Conditions" slot.
In the Scene Tree panel's right side you can see the Check Click behavior and the Check Key Input behavior configured as the Check Logic Condition behavior's Conditions.
From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag a "Send Value As Event" behavior into the Scene Tree panel's right side directly onto the Event Handler's "Actions" slot.
In the Scene Tree panel's right side you can see that "Send Value As Event" is configured as the Event Handler's action
In the Scene Tree panel's right side select "Check Logic Condition". In the Properties panel set the property "Operation" to "Or" according to the table below.
The Check Logic Condition's Operation is configured to combine its Conditions with an OR operation.
The Check Logic Condition will evaluate to TRUE if either the Check Click condition or the Check Key Input condition is TRUE.
In the Scene Tree panel's right side select "Check Key Input". In the Properties panel configure the KeyCode to Key_Enter according to the table below.
The Check Key Input condition is configured to evaluate to TRUE when the enter key on the keyboard is pressed.
Behavior
Property
Value
Operation
Or
Check Key Input
KeyCode
Key_Enter
In the Scene Tree panel's right side select the Event Handler's action "Send Value As Event". In the Properties panel configure the Target Node, Value and Value Change property as in the table below.
Send Value As Event is configured according to the table.
On every click or enter key press a boolean value will be sent to the Sub-List control.
Behavior
Property
Value
Send Value As Event
Target Node
/Controls/MyList/List/ListContentGroup/Sub-List
Value
Bool - TRUE
Change Value
Relative
From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag a Value behavior into the Scene Tree panel directly onto MyList's Sub-List node.
In the Scene Tree panel the Sub-List node got marked a yellow square, indicating that a behavior is attached to it.
In the Scene Tree panel's right side you can see the Value behavior.
In the Scene Tree panel's right side select the Sub-List node's Value behavior. In the Properties panel change the Variant to "Bool". Don't check the nearby checkbox.
The Value behavior's type has been changed to Bool.
From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag an Action On Value behavior into the Scene Tree's right side directly onto the Value behavior's Receivers slot.
In the Scene Tree panel you can see that an Action On Value behavior is configured as Receiver of the Value Processing behavior.
Action On Value can now be used to configure an action that will be executed when a new value has been received and the visibility of the Sub-List is toggled.
From the Toolbox panel's [ Behaviors ] section under "Condition - Control" drag a Check Processed Value behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Condition.
In the Scene Tree panel's right side you can see that the Check Processed Value behavior is configured as condition for the Action On Value behavior.
In the Scene Tree panel's right side select the Check Processed Value behavior. In the Properties panel configure the properties ConditionOperator and ConditionValue as in the table below.
The Check Processed Value behavior's properties have been configured.
Only if the the value received from "MainItem/SendValue as Event" is TRUE, an action (which will be defined in later steps) shall be performed.
Behavior
Property
Value
ConditionOperator
Equal
ConditionValue
Bool, TRUE
From the Toolbox panel's [ Behaviors ] section under "Action - Control" drag a "Set Control State" behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Action slot.
In the Scene Tree panel's right side you can see that the Set Control State behavior is configured as the Action On Value behavior's action.
In the Scene Tree panel's right side select the Set Control State behavior. In the Properties panel configure the properties State and Change To according to the table below.
The Set Control State behavior is configured as in the table below.
The Sub-List will be enabled whenever the condition Check Processed Value evaluates to TRUE.
Behavior
Property
Value
Set Control State
State
Enabled
ChangeTo
TRUE
Repeat steps 3 to 7: Add a new Action On Value behavior as Value behavior's Receiver, configure another Check Processed Value condition and another Set Control State according to the table and image below.
In the Scene Tree panel's right side you can see the behaviors are configured as in the table and image below.
All behaviors for MyList's Sub-List have been configured.
Behavior
Property
Value
Action On Value_1
Check Processed Value_1
ConditionOperator
Equal
ConditionValue
Bool, FALSE
Set Control State_1
State
Enabled
ChangeTo
FALSE
Test MyList in the Player
Save your solution either via the menu "File - Save Solution" or via the keyboard <Ctrl + S>.
The solution has been saved.
In the Scene Composer's Toolbar click on "Play selected scenario...".
The resources will be generated and the Player will be started.
In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
In the Player window click into the empty Devices List, where you would expect the first list element.
In the Player window's empty Devices List an orange border will be displayed indicating the selected MainItem.
Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
In the Player window click the selected MainItem again.
The TextButtons of the Sub-List will disappear.
In the Scene Composer's Toolbar click the "Close the Player" button.
The Player and CGI Panel window will be closed.
In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
In the Scene Tree panel select the MainItems individually. Then select their configured "Send Value As Event" behaviors. In the Properties panel adapt the TargetNodes to their respective MainItems. I.e. MainItem_4 will be configured as the TargetNode of MainItem_4's "Send Value As Event" behavior.
The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
Select [ Expand Control Node ] from the context menu of List in Scene Tree panel.
Open List and select [ Expand Control Node ] from the context menu of the Scrollbar.
Select the List in Scene Tree and choose [ Save as Control... ] from List context menu. Then Add New Templates dialog will appear and press [ OK ] button. As the result of that, you can add the control as a customizable control in Solution Explorer's Solution > Controls. After confirming this addition, delete List group node in Scene Tree panel.
You have now created a customizable List control.
Select [ Control Properties... ] from List context menu of Solution Explorer's Solution > Controls. The Configure Public Control Properties dialog will appear, check Is Public for ScrollbarVisibility under Internal properties, and press [ OK ] button.
Delete the expanded List Control from SceneOptions in the Scene Tree Panel. Drag and drop the newly created List from Solution Explorer's Solution > Controls to Scene Tree panel's SceneOptions > Devices.
Set Scrollbal Visibility (Properties > Control) of List to "Visible."
Double-click on the List in the Devices group to customize it on Scene Tree.
Select the "Thumb" button and replace its images as follows:
Then select the "VerticalPrevItem" button from inside the PrevItem group node and replace the images as follows:
Lastly, select the "VerticalNextItem" button from inside the NextItem group node and replace the images as follows:
We want a main list with a sub-list that will expand when an item in the main list is clicked.
To do that, first we need a Group Node with an OverlayLayout which will contain the device entry name and the focus image. Therefore, drag a Render Node and a TextNode from the ToolBox "Nodes 2D" into the OverlayLayout.
Rename the OverlayLayout to "MainItem".
Rename the RenderNode to "FocusImage".
Rename the TextNode to "EntryName".
The "MainItem" you have now assembled will be the main list item that will be visible.
Set the position of the GroupNode List to X:58 and Y:134 and configure its size to X:300 and Y:300.
In our list the currently selected main list item shall be highlighted with an orange outline.
Therefore drag a BitmapBrushColorBlend effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side of the Scene Tree Panel and set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox to the List's ListContentGroup.
The Sub-List control has a SublistAnchor. Drag a StackLayout onto this SubListAnchor. Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".
The resulting structure should look like this:
The next step is to configure the TextButton:
Scale: X:0.75 and Y:0.75.
Margin Left: 12
Text: "Connect".
The TextButton's images (Normal Image, Pressed Image and Focused Image) need to be adjusted:
Copy and paste the TextButton to make another copy. Rename the other as "TextButton_Unpair", and set its Text property to "Unpair". Resulting structure should look like this:
Setting up the "Devices" List behaviors
Focus Handling behaviors
For the Devices entry items, we need to set the behaviors for focus handling. We want the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
This is what the configured Behaviors look like now:
As soon as the MainItem gets the focus, the FocusImage shall be visible. Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
As soon as the MainItem loses the focus, the FocusImage shall be made invisible again. Therefore you have to configure the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
If you run CGI Player and click on a list item, an orange highlight should indicate that this item is in focus.
Sub-List Handling behaviors
In the "Check Logic Condition" properties, set the Operation to "Or", since we want the condition to be either a click or a key input.
The "Check Key Input" condition, checks if the enter key is pressed. Therefore the KeyCode property will be set to "Key_Enter".
The action that shall be performed is a "Set Control State" behavior, which will actually enable the Sub-List when the condition above is met. Please drag it onto the Actions part of the "Action on Value" behavior and configure it as depicted below.
Add another "Action on Value" behavior with a "Check processed Value" condition and "Set Control State" action, same as above. But this time, set the ConditionValue property of "Check processed Value" condition to false (Bool + unchecked). And set the "ChangeTo" property of "Set Control State" to false (unchecked).
