GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On the right side is a List with Sub-List Controls. The Sub-List Control will appear depending on the item selected in the List.
Preparing the Options scene
Importing Images
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group node into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
      Target Name
      Position X
      Position Y
      Connection
      78.00
      58.00
      Devices
      551.00
      58.00
      Target Name
      Position X
      Position Y
      Dial
      72.00
      163.00
      Property
      Path
      Knob Image
      StateImages
      Image Path
      BackgroundImages 1
      BackgroundImages 2
      Target Name
      Pivot Hint Y
      88,00
      130,50
      130,50
      130,50 130,50
      130,50 130,50
      Text Position X Position Y
      TextNode_Cable Cable 20 200
      TextNode_Other Other 315 200
  1. From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
  2. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
  3. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
  4. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
  5. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
    • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
Configure MyList Control
  1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
  2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
  5. In the "Delete Item" dialog press [ OK ].
    • The List node is deleted.
  6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
  7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
Customize MyList's Scrollbar
      Thumb Images
      Image Path
      VerticalPrevItem Images
      Image Path
      VerticalNextItem Images
      Image Path
Configure MyList's Main Item
  2. From the Toolbar's [ 2D Nodes ] section drag an OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
  3. From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
  4. In the Scene Tree panel rename the nodes created in the previous steps rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
      Initial Name
      New Name
      OverlayLayout MainItem
      TextNode EntryName
      RenderNode FocusImage
  5. In the Scene Tree panel select the List (Group2D). In the Properties panel  [ Transformation ] section configure the position and size according to the following table.
    • Size X and Size Y properties are initially set to "Automatic" and greyed out. Clicking onto the "A" next to the greyed-out input field allows you to edit these properties.
      Target Item
      Transformation
      Layout
      List (Group2D)
      58
      134
      300
      300
  3. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
      Target Item
  4. In the Properties panel click on the Color rectangle next to the Color property.
    • The "Color Palette" dialog will be opened.
  5. In the "Color Palette" dialog change the Color value by entering new values for "Red", "Green" and "Blue" according to the table below.
      Target Item
      Color
      Red
      Green
      Blue
      0.62
      0.00
  6. In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
    • In the Scene Tree panel the FocusImage RenderNode will appear with an orange outline.
      Target Item
      Layout > StretchBehavior
      Fill
Create MyList's Sub-List
  1. From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
  2. From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
  3. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
  4. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
      Target Item
      Transformations
      Layout
      Scale X
      Scale Y
      Margin Left
      TextButton
      0,75
      0,75
      12
  5. In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
  6. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
  7. Repeat steps 5 and 6 for "Pressed Image" and "Focused Image".
      Target Item
      Image Path
      Normal Image
      Pressed Image
      Focused Image
  10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
      Target Item
      New Name
      Control - Text
Setting up MyList's Behaviors
Focus Handling Behaviors
  1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
  2. From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
    • In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
    • In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
  3. From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
    • In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
    • Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
  4. From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
    • In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
  5. In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
    • The property "Visible" for both EnableRendering behaviors are configured.
  6. In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
    • The Properties panel is locked.
  7. From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
    • In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
  8. In the Properties panel click on the padlock icon in the top right corner a second time.
    • The Properties panel is unlocked again.
  9. Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
    • Whenever the MainItem looses the focus, the FocusImage will get invisible.
      Behavior
      Visible
      Target Node
      Focus - EnableRendering
      FocusLeave - EnableRendering
  1. From the Toolbox panel's [ Behaviors ] section under "Control" drag an "Event Handler" behavior into the Scene Tree panel directly onto the MainItem Group2D node.
    • In the Scene Tree panel's right side you can see the "Event Handler" behavior with Condition and Actions slots.
  2. From the Toolbox panel's [ Behaviors ] section under "Condition - Logic" drag a "Check Logic Condition" into the Scene Tree panel's right side directly on the Event Handler's Condition slot.
    • In the Scene Tree panel's right side you can see the "Check Logic Condition" behavior configured as the EventHandler's condition.
  3. From the Toolbox panel's [ Behaviors ] section under "Condition - Input" drag a "Check Click" behavior and a "Check Key Input" behavior onto the "Check Logic Condition" behavior's "Conditions" slot.
    • In the Scene Tree panel's right side you can see the Check Click behavior and the Check Key Input behavior configured as the Check Logic Condition behavior's Conditions.
  4. From the Toolbox panel's [ Behaviors ] section under "Action  - Property" drag a "Send Value As Event" behavior into the Scene Tree panel's right side directly onto the Event Handler's "Actions" slot.
    • In the Scene Tree panel's right side you can see that "Send Value As Event" is configured as the Event Handler's action
  5. In the Scene Tree panel's right side select "Check Logic Condition". In the Properties panel set the property "Operation" to "Or" according to the table below.
    • The Check Logic Condition's Operation is configured to combine its Conditions with an OR operation.
    • The Check Logic Condition will evaluate to TRUE if either the Check Click condition or the Check Key Input condition is TRUE.
  6. In the Scene Tree panel's right side select "Check Key Input". In the Properties panel configure the KeyCode to Key_Enter according to the table below.
    • The Check Key Input condition is configured to evaluate to TRUE when the enter key on the keyboard is pressed.
      Behavior
      Property
      Value
      Check Logic Condition Operation Or
  7. In the Scene Tree panel's right side select the Event Handler's action "Send Value As Event". In the Properties panel configure the Target Node, Value and Value Change property as in the table below.
    • Send Value As Event is configured according to the table.
    • On every click or enter key press a boolean value will be sent to the Sub-List control.
    • To easily set the Target Node lock the Properties panel using the pad lock icon in the top right corner. From the Scene Tree panel drag the Sub-List node into the Properties panel directly onto the input field next to "TargetNode". Finally, don't forget to unlock the Properties panel clicking the pad lock icon once again.
      Behavior
      Property
      Value
      Value Bool - TRUE
      Change Value
      Relative
  1. From the Toolbox panel's [ Behaviors ] section under "Value Processing" drag a Value behavior into the Scene Tree panel directly onto MyList's Sub-List node.
    • In the Scene Tree panel the Sub-List node got marked a yellow square, indicating that a behavior is attached to it.
    • In the Scene Tree panel's right side you can see the Value behavior.
  2. In the Scene Tree panel's right side select the Sub-List node's Value behavior. In the Properties panel change the Variant to "Bool". Don't check the nearby checkbox.
    • The Value behavior's type has been changed to Bool.
  3. From the Toolbox panel's [ Behaviors ] section  under "Value Processing" drag an Action On Value behavior into the Scene Tree's right side directly onto the Value behavior's Receivers slot.
    • In the Scene Tree panel you can see that an Action On Value behavior is configured as Receiver of the Value Processing behavior.
    • Action On Value can now be used to configure an action that will be executed when a new value has been received and the visibility of the Sub-List is toggled.
  4. From the Toolbox panel's [ Behaviors ] section under "Condition - Control" drag a Check Processed Value behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Condition.
    • In the Scene Tree panel's right side you can see that the Check Processed Value behavior is configured as condition for the Action On Value behavior.
  5. In the Scene Tree panel's right side select the Check Processed Value behavior. In the Properties panel configure the properties ConditionOperator and ConditionValue as in the table below.
    • The Check Processed Value behavior's properties have been configured.
    • Only if the the value received from "MainItem/SendValue as Event" is TRUE, an action (which will be defined in later steps) shall be performed.
      Behavior
      Property
      Value
      ConditionOperator Equal
      ConditionValue Bool, TRUE
  6. From the Toolbox panel's [ Behaviors ] section under "Action - Control" drag a "Set Control State" behavior into the Scene Tree panel's right side directly onto the Action On Value behavior's Action slot.
    • In the Scene Tree panel's right side you can see that the Set Control State behavior is configured as the Action On Value behavior's action.
  7. In the Scene Tree panel's right side select the Set Control State behavior. In the Properties panel configure the properties State and Change To according to the table below.
    • The Set Control State behavior is configured as in the table below.
    • The Sub-List will be enabled whenever the condition Check Processed Value evaluates to TRUE.
      Behavior
      Property
      Value
      Set Control State
      State Enabled
      ChangeTo TRUE
  8. Repeat steps 3 to 7: Add a new Action On Value behavior as Value behavior's Receiver, configure another Check Processed Value condition and another Set Control State according to the table and image below.
    • In the Scene Tree panel's right side you can see the behaviors are configured as in the table and image below.
    • All behaviors for MyList's Sub-List have been configured.
      Behavior
      Property
      Value
      Action On Value_1
      Check Processed Value_1
      ConditionValue Bool, FALSE
      Set Control State_1
      State Enabled
      ChangeTo
      FALSE
Test MyList in the Player
  1. Save your solution either via the menu "File - Save Solution" or via the keyboard <Ctrl + S>.
    • The solution has been saved.
  2. In the Scene Composer's Toolbar click on "Play selected scenario...".
    • The resources will be generated and the Player will be started.
  3. In the CGI Panel check Scenes#SceneOptions and uncheck SceneHome and SceneClimate
    • In the Player window SceneOptions will be displayed with the Connection Dial on the left side and the empty Devices List on the right side, displaying the scrollbar.
  4. In the Player window click into the empty Devices List, where you would expect the first list element.
    • In the Player window's empty Devices List an orange border will be displayed indicating the selected MainItem.
    • Additionally, the Sub-List with the TextButtons "Connect" and "Unpair" will be displayed below the selected MainItem.
  5. In the Player window click the selected MainItem again.
    • The TextButtons of the Sub-List will disappear.
  6. In the Scene Composer's Toolbar click the "Close the Player" button.
    • The Player and CGI Panel window will be closed.
  1. In the Scene Tree panel select the Main Item and the Sub-List. Copy and paste them to create 4 more instances. This can be done either via the context menu [ Copy ] and [ Paste ] or via the keyboard shortcuts <Ctrl + c> and <Ctrl + v>.
    • In the Scene Tree panel you can see that MyList's ListContentGroup now contains 5 MainItems and 5 Sub-Lists.
  2. In the Scene Tree panel select the MainItems individually. Then select their configured "Send Value As Event" behaviors. In the Properties panel adapt the TargetNodes to their respective MainItems. I.e. MainItem_4 will be configured as the TargetNode of MainItem_4's "Send Value As Event" behavior.
    • The "Send Value As Event" behaviors' TargetNodes are configured with the respective MainItems.
