GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On the right side is a List with Sub-List Controls. The Sub-List Control will appear depending on the item selected in the List.
Preparing the Options scene
Importing Images
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group nodes into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
      Target Name
      Position X
      Position Y
      Connection
      78.00
      58.00
      Devices
      551.00
      58.00
      Target Name
      Position X
      Position Y
      Dial
      72.00
      163.00
      Property
      Path
      Knob Image
      StateImages
      Image Path
      BackgroundImages 1
      BackgroundImages 2
      Target Name
      Pivot Hint Y
      88,00
      130,50
      130,50
      130,50 130,50
      130,50 130,50
      Text Position X Position Y
      TextNode_Cable Cable 20 200
      TextNode_Other Other 315 200
  1. From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
  2. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
  3. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
  4. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
  5. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
    • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
Configure MyList Control
  1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
  2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
  5. In the "Delete Item" dialog press [ OK ].
    • The List node is deleted.
  6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
  7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
Customize MyList's Scrollbar
      Thumb Images
      Image Path
      VerticalPrevItem Images
      Image Path
      VerticalNextItem Images
      Image Path
Configure MyList's Main Item
  2. From the Toolbar's [ 2D Nodes ] section drag a OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
  3. From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
  4. In the Scene Tree panel rename the nodes created in the previous steps rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
      Initial Name
      New Name
      OverlayLayout MainItem
      TextNode EntryName
      RenderNode FocusImage
  5. In the Scene Tree panel select the List (Group2D). In the Properties panel  [ Transformation ] section configure the position and size according to the following table.
    • Size X and Size Y properties are initially set to "Automatic" and greyed out. Clicking onto the "A" next to the greyed-out input field allows you to edit these properties.
      Target Item
      Transformation
      Layout
      List (Group2D)
      58
      134
      300
      300
  3. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
      Target Item
  4. In the Properties panel click on the Color rectangle next to the Color property.
    • The "Color Palette" dialog will be opened.
  5. In the "Color Palette" dialog change the Color value by entering new values for "Red", "Green" and "Blue" according to the table below.
      Target Item
      Color
      Red
      Green
      Blue
      0.62
      0.00
  6. In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
    • In the Scene Tree panel the FocusImage RenderNode will appear with an orange outline.
      Target Item
      Layout > StretchBehavior
      Fill
Create MyList's Sub-List
  1. From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
  2. From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
  3. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
  4. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
      Target Item
      Transformations
      Layout
      Scale X
      Scale Y
      Margin Left
      TextButton
      0,75
      0,75
      12
  5. In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
  6. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
  7. Repeat steps 5 and 6 for "Pressed Image" and "Focused Image".
      Target Item
      Image Path
      Normal Image
      Pressed Image
      Focused Image
  10. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
      Target Item
      New Name
      Control - Text
Setting up MyList's Behaviors
Focus Handling Behaviors
  1. In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
  2. From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
    • In the Scene Tree panel an orange square appears indicating that this node has a behavior attached.
    • In the Scene Tree panel's right side the attached behavior HandleControlState is visible.
  3. From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
    • In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible.
    • Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs.
  4. From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
    • In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
  5. In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
    • The property "Visible" for both EnableRendering behaviors are configured.
  6. In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
    • The Properties panel is locked.
  7. From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
    • In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode.
  8. In the Properties panel click on the padlock icon in the top right corner a second time.
    • The Properties panel is unlocked again.
  9. Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
    • Wenever the MainItem looses the focus, the FocusImage will get invisible.
      Target Name
      Visible
      Target Node
      Focus - EnableRendering
      FocusLeave - EnableRendering
Sub-List Handling behaviors
In the "Check Logic Condition" properties, set the Operation to "Or", since we want the condition to be either a click or a key input.
The "Check Key Input" condition, checks if the enter key is pressed. Therefore the KeyCode property will be set to "Key_Enter".
The action that shall be performed is a "Set Control State" behavior, which will actually enable the Sub-List when the condition above is met. Please drag it onto the Actions part of the "Action on Value" behavior and configure it as depicted below.
Add another "Action on Value" behavior with a "Check processed Value" condition and "Set Control State" action, same as above. But this time, set the ConditionValue property of "Check processed Value" condition to false (Bool + unchecked). And set the "ChangeTo" property of "Set Control State" to false (unchecked).
