GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On the right side is a List with Sub-List Controls. The Sub-List Control will appear depending on the item selected in the List.
Preparing the Options scene
Importing Images
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group nodes into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
    • In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
        Target Name
        Position X
        Position Y
        Connection
        78.00
        58.00
        Devices
        551.00
        58.00
        Target Name
        Position X
        Position Y
        Dial
        72.00
        163.00
        Property
        Path
        Knob Image
        StateImages
        Image Path
        BackgroundImages 1
        BackgroundImages 2
        Target Name
        Pivot Hint Y
        88,00
        130,50
        130,50
        130,50 130,50
        130,50 130,50
        Text Position X Position Y
        TextNode_Cable Cable 20 200
        TextNode_Other Other 315 200
    1. From the Toolbox panel's [ Control ] section under "Touchable" drag a List Control into the Scene Tree panel directly onto the "Devices" group node.
    2. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
    3. In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
    4. In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
    5. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
      • A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
    Configure MyList Control
    1. In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
    2. In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
    5. In the "Delete Item" dialog press [ OK ].
      • The List node is deleted.
    6. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
    7. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
    Customize MyList's Scrollbar
        Thumb Images
        Image Path
        VerticalPrevItem Images
        Image Path
        VerticalNextItem Images
        Image Path
    Create
    Configure Sub-List
    MyList's Main Item
    2. From the Toolbar's [ 2D Nodes ] section drag a OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
    3. From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
    4. In the Scene Tree panel rename the nodes created in the previous steps rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
        Initial Name
        New Name
        OverlayLayout MainItem
        TextNode FocusImageEntryName
        RenderNode EntryNameFocusImage
    5. In the Scene Tree panel select the List (Group2D). In the Properties panel  [ Transformation ] section configure the position and size according to the following table.
      • Size X and Size Y properties are initially set to "Automatic" and greyed out. Clicking onto the "A" next to the greyed-out input field allows you to edit these properties.
        Target Item
        Transformation
        Layout
        List (Group2D)
        58
        134
        300
        300
      From the Toolbox panel's [Effects] section drag a BitmapBrushColorBlend effect into the Scene Tree panel directly onto the MainItem's FocusImage.
        In the Scene Tree panel's right side you can see BitmapBrushColorBlend effect under "Effects" when FocusImage is selected. In the Scene Tree panel select FocusImage. In the Scene Tree panel's right side select the BitmapBrushColorBlend effect. In the Properties panel click on the magnifying glass icon next to the "Image" property.
          The "Choose Item" dialog will be opened. In the "Choose Item" dialog select the image as in the table below and click [ OK ].
            The "Choose Item" dialog will be closed.
            Target Item
            MyList > List > >ListContentGroup > MainItem > FocusImage > BitmapBrushColorBlend //ConstructionKit/ConstructionKit/Controls/Images/Common/BorderFocusedBmp In the Properties panel click on the Color rectangle next to the Color property.
              The "Color Palette" dialog will be opened. In the "Color Palette" dialog change the Color value by entering new values for "Red", "Green" and "Blue" according to the table below.
                In the Properties panel the configured orange color will be visible.
                Target Item
                Color
                Red
                Green
                Blue
                0.62
                0.00
                In the Scene Tree panel select the FocusImage node. In the Properties panel's [ Layout ] section set the StretchBehavior to "Fill" according to the table below.
                  In the Scene Tree panel the FocusImage RenderNode will appear with an orange outline.
                  Target Item
                  Layout > StretchBehavior
                  Fill
                  Create MyList's Sub-List
                    From the Toolbox panel's [ Controls ] section under "Touchable" drag a Sub-List into the Scene Tree panel directly onto the List's ListContentGroup
                      In the Scene Tree panel the Sub-List node is positioned inside of ListContentGroup just below the MainItem. The Sub-List has a SubListAnchor.
                      From the Toolbox panel's [ Node2D ] section drag a StackLayout into the Scene Tree panel directly onto the Sub-List's SubListAnchor.
                        In the Scene Tree panel the StackLayout appears beneath the Sub-List's SubListAnchor. From the Toolbox panel's [ Controls ] section under "Touchable" drag a TextButton Into the Scene Tree panel directly onto the StackLayout you added in the step before.
                          In the Scene Tree panel the TextButton appears beneath the StackLayout. In the Scene Tree panel select the StackLayout. In the Properties panel's [ Transformation ] and [ Layout ] section configure the properties as in the table below.
                            In the Scene Editor the dashed line of the TextButton's boundings will decrease.
                            Target Item
                            Transformations
                            Layout
                            Scale X
                            Scale Y
                            Margin Left
                            TextButton
                            0,75
                            0,75
                            12
                            In the Properties panel's [ Control ] section click on the magnifying glass icon next to the TextButton's "Normal Image" property.
                              The "Choose Item" dialog will be opened. In the "Choose Item" dialog select the image according to the table below and click [ OK ].
                                A new image for "Normal Image" has been configured. Repeat steps 5 and 6 for "Pressed Image" and "Focused Image".
                                  New images are configured for the TextButton.
                                  Target Item
                                  Image Path
                                  Normal Image
                                  Pressed Image
                                  /Resources/Options/ButtonNorma_Prss_OreBmp Focused Image
                                  /Resources/Options/NOTBorderFocusedBmp In the Scene Tree panel select the TextButton and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
                                    A copy of the TextButton has been created. In Scene Tree panel the name of the copy is "TextButton_1". In Scene Tree panel rename the TextButtons according to the table below. Renaming can be done either via the context menu "Rename" or pressing <F2> on your keyboard.
                                      In Scene Tree panel the TextButtons are renamed. In Scene Tree panel select the TextButtons individually and change the text they are displaying in the Properties panel's [ Control ] section according to the table below.
                                        Target Item
                                        New Name
                                        Control - Text
                                        TextButton TextButton_Connect Connect TextButton_1 TextButton_Unpair Unpair
                                        Setting up MyList's Behaviors
                                        Focus Handling Behaviors
                                          In the Scene Tree panel select the MainItem's FocusImage. In the Properties panel's [ Item ] section uncheck "Enable Rendering".
                                            In the Scene Editor FocusImage (the orange rectangle) is not visible any more. In the Scene Tree panel an icon indicates the FocusImage node's disabled rendering.
                                            From the Toolbox panel's [ Behaviors ] section under "Control - Internal" drag a "Handle Control State" behavior into the Scene Tree panel directly onto the MainItem GroupNode.
                                              In the Scene Tree panel an orange square appears indicating that this node has a behavior attached. In the Scene Tree panel's right side the attached behavior HandleControlState is visible. From the Toolbox panel's [ Behaviors ] section under "Control" drag a Focus behavior and a FocusLeave behavior into the Scene Tree panel directly onto the MainItem GroupNode.
                                                In the Scene Tree panel's right side the attached behaviors Focus and FocusLeave are visible. Both, Focus and FocusLeave offer the possibility to configure an Action, which will be executed when a Focus or a FocusLeave event occurs. From the Toolbox panel's [ Behaviors ] section under "Action - Property" drag an EnableRendering behavior into the Scene Tree panel's right side directly onto the Action entries of the Focus and FocusLeave behavior.
                                                  In the Scene Tree panel's right side it is visible that for each of Focus and FocusLeave behavior an EnableRendering behavior is configured as action.
                                                  In the Scene Tree panel's right side select the EnableRendering behaviors individually. In the Properties panel apply the settings for the property "Visible" as in the table below.
                                                    The property "Visible" for both EnableRendering behaviors are configured. In the Properties panel click on the padlock icon in the top right corner, while the EnableRendering behavior is selected.
                                                      The Properties panel is locked.
                                                      From the Scene Tree panel drag the FocusImage into the Properties panel directly onto the inputfield of the "TargetNode" property.
                                                        In the Properties panel FocusImage is configured as the EnableRendering behavior's TargetNode. In the Properties panel click on the padlock icon in the top right corner a second time.
                                                          The Properties panel is unlocked again.
                                                          Repeat steps 6 to 8 for the other EnableRendering behavior to configure its TargetNode.
                                                            MyList's behaviors for focus handling are configured. Whenever the MainItem gets the focus, the FocusImage will get visible. Wenever the MainItem looses the focus, the FocusImage will get invisible.
                                                            Target Name
                                                            Visible
                                                            Target Node
                                                            Focus - EnableRendering
                                                            FocusLeave - EnableRendering
                                                            Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
                                                            In our list the currently selected main list item shall be highlighted with an orange outline.
                                                            Therefore drag a BitmapBrushColorBlend effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side of the Scene Tree Panel and set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
                                                            Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
                                                            In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox to the List's ListContentGroup.
                                                            The Sub-List control has a SublistAnchor. Drag a StackLayout onto this SubListAnchor. Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".
                                                            The resulting structure should look like this:
                                                            The next step is to configure the TextButton:
                                                              Scale: X:0.75 and Y:0.75. Margin Left: 12 Text: "Connect".
                                                              The TextButton's images (Normal Image, Pressed Image and Focused Image) need to be adjusted:
                                                              Copy and paste the TextButton to make another copy. Rename the other as "TextButton_Unpair", and set its Text property to "Unpair". Resulting structure should look like this:
                                                              Setting up the "Devices" List behaviors
                                                              Focus Handling behaviors
                                                              For the Devices entry items, we need to set the behaviors for focus handling. We want the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
                                                              Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
                                                              Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
                                                              Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
                                                              This is what the configured Behaviors look like now:
                                                              As soon as the MainItem gets the focus, the FocusImage shall be visible. Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
                                                              As soon as the MainItem loses the focus, the FocusImage shall be made invisible again. Therefore you have to configure the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
                                                              If you run CGI Player and click on a list item, an orange highlight should indicate that this item is in focus.
                                                              Sub-List Handling behaviors
                                                              In the "Check Logic Condition" properties, set the Operation to "Or", since we want the condition to be either a click or a key input.
                                                              The "Check Key Input" condition, checks if the enter key is pressed. Therefore the KeyCode property will be set to "Key_Enter".
                                                              The action that shall be performed is a "Set Control State" behavior, which will actually enable the Sub-List when the condition above is met. Please drag it onto the Actions part of the "Action on Value" behavior and configure it as depicted below.
                                                              Add another "Action on Value" behavior with a "Check processed Value" condition and "Set Control State" action, same as above. But this time, set the ConditionValue property of "Check processed Value" condition to false (Bool + unchecked). And set the "ChangeTo" property of "Set Control State" to false (unchecked).
