GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On the right side is a List with Sub-List Controls. The Sub-List Control will appear depending on the item selected in the List.
Preparing the Options scene
Importing Images
  2. In the "Import Resources" dialog navigate to the path given in the table below. Select all 36 files and press [ Open ]
      Import Resources
      Path
Configuring the Background
  1. From the Toolbox panel's [ Node 2D ] section drag a 2D Group nodes into the Scene Tree directly onto the node "SceneOptions".
      Target Item Name
      Group
      Connection
        BitmapNode Background
      Group_1
      Devices
      Property
      Path
      Target Name
      Position X
      Position Y
      Connection
      78.00
      58.00
      Devices
      551.00
      58.00
      Target Name
      Position X
      Position Y
      Dial
      72.00
      163.00
      Property
      Path
      Knob Image
      StateImages
      Image Path
      BackgroundImages 1
      BackgroundImages 2
      Target Name
      Pivot Hint Y
      88,00
      130,50
      130,50
      130,50 130,50
      130,50 130,50
      Text Position X Position Y
      TextNode_Cable Cable 20 200
      TextNode_Other Other 315 200
Setting up the "Connection"Devices" Nodesnodes
Add 4 Text Nodes to "Connection" Group Node and move them below Background Node with Ctrl key dragging. Rename them as follows:
Configure
From the TextToolbox Nodespanel's with[ Control ] section under "Touchable" drag a List Control into the followingScene values:Tree Textpanel Styledirectly shouldonto bethe OpenSans25."Devices"
group
node.
In
the
MakeScene sureTree thatpanel a "List" node is visible directly under the "Background" node.
This list node contains a "ListContentGroupAnchor", that is visible in Scene Tree panel by expanding the firstList node via a click on the triangle on its left. In the Scene Tree panel right-click on the newly created List node and choose [ Expand Control Node ] from the context menu.
    In the Scene Tree panel the expanded List now shows a "ListContentGroup" and a "Scrollbar". In the Scene Tree panel right-click on the "Scrollbar" and once again choose [ Expand Control Node ] from the context menu.
      In the Scene Tree panel the expanded Scrollbar shows 6 sub-nodes.
      In the Scene Tree panel right-click on the List node and choose [ Save as Control... ] from the context menu.
        The "Add New Templates" dialog will be opened. In the "Add New Templates" dialog select the "/Controls" folder to store the new control in, enter "MyList" as name and click [ OK ].
          A new customizable control "MyList" has been created. It is visible in the Solution Explorer panel in the Controls folder and in the Toolbox panel's [ Controls ] section as last item of the list.
          The Scene Editor doesn't display SceneOptions any more, it displays the control MyList.
          The Scene Tree panel shows the structure of MyList.
          The Properties panel shows the properties of "MyList (top)Control)".
            In the Solution Explorer right-click on the newly created control "MyList" and choose [ Control Properties... ] from the context menu.
              The "Configure Public Control Properties" dialog will be opened.
              In the "Configure Public Control Properties" dialog's tree on the left side select the following item MyList > List > Scrollbar > Behaviors > ScrollbarBehavior. In the dialog's centered panel "Internal properties" find property "ScrollbarVisibility", check the "Is Public" checkbox and click [ OK ].
                The "Configure Public Control Properties" dialog will be closed. For every instance of the MyList control, there will be a property available to configure the visibility of the scrollbar.
                In the Scene Tree navigate back to SceneOptions by pressing the arrow in the top left corner.
                  The Scene Tree panel navigates back to SceneOptions and displays SceneOptions and its nodes. The Scene Editor displays SceneOptions.
                  In the Scene Tree delete the List node.
                    The "Delete Item" dialog will be opened. In the "Delete Item" dialog press [ OK ].
                      The List node is deleted. From the Toolbox panel's [ Control ] section drag and drop a MyList control into the Scene Tree panel directly onto the Devices group.
                        In the Scene Tree panel, a new MyList node will be visible. In the Scene Tree panel select "MyList". In the Properties panel's [ Control ] section set the "Scrollbar Visibility" to "Visible".
                          In the Scene Editor a small blue scrollbar becomes visible.
                            In the Scene Tree panel double-click on the MyList node.
                              Scene Tree panel will switch from displaying SceneOptions to displaying the MyList template. In the Scene Tree panel select the "Thumb" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and selecting the appropriate image in the "Connection"Select groupItem" indialog. order
                                New images for the scrollbar's "Thumb" have been defined.
                                Thumb Images
                                Image Path
                                Normal Image /Resources/Options/ThumbNormalBmp2Bmp Pressed Image /Resources/Options/ThumbPressedBmp2Bmp Focused Image /Resources/Options/ThumbNormalBmp2Bmp In the Scene Tree panel select the "VerticalPrevItem" button node. In the Properties panel change the button's image properties according to appearthe table below by clicking the magnifying glass icon and selecting the appropriate image in the background"Select andItem" notdialog. cover
                                otherNew nodes.images
                                Atfor thisthe point,scrollbar's you will now"VerticalPrevItem" have createdbeen defined.
                                   MyList > List > Scrollbar > PrevItem > VerticalPrevItem VerticalPrevItem Images
                                Image Path
                                Normal Image /Resources/Options/ArrowUpNormalBmp2Bmp Pressed Image /Resources/Options/ArrowUpPressedBmp2Bmp Focused Image /Resources/Options/ArrowUpNormalBmp2Bmp In the ConnectionScene optionsTree Dial:panel
                                Setting upselect the "Devices"VerticalNextItem" button node. In the Properties panel change the button's image properties according to the table below by clicking the magnifying glass icon and selecting the appropriate image in the "Select Item" dialog.
                                  New images for the scrollbar's "VerticalNextItem" have been defined.
                                     MyList > List > Scrollbar > NextItem > VerticalNextItem VerticalNextItem Images
                                  Image Path
                                  Normal Image /Resources/Options/ArrowDownNormalBmp2Bmp Pressed Image /Resources/Options/ArrowDownPressedBmp2Bmp Focused Image /Resources/Options/ArrowDownNormalBmp2Bmp In the Scene Tree navigate back to SceneOptions by pressing the arrow in the top left corner.
                                    The Scene Tree displays SceneOptions. In the Scene Editor the scroll bar is now rendered with the new images in orange color.
                                    Create Sub-List
                                        Scene Tree panel switches from SceneOptions to MyList. You are now able to edit the MyList template. From the Toolbar's [ 2D Nodes ] section drag a OverlayLayout into the Scene Tree panel directly onto the List's "ListContentGroup" (MyList > List > ListContentGroup).
                                          In the Scene Tree panel there is an OverlayLayout inside of "ListContentGroup". From the Toolbar's [ 2D Nodes ] section drag a RenderNode and a TextNode into the Scene Tree panel directly onto the OverlayLayout that was created in the previous step.
                                            In the Scene Tree panel there are a RenderNode and a TextNode inside the OverlayLayout that was created in the previous step. In the Scene Editor the TextNode is visible displaying the TextNode's default text "Text".
                                            In the Scene Tree panel rename the nodes created in the previous steps rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard according to the table below.
                                              In the Scene Tree panel the nodes are renamed according to the following table.
                                                 Initial Name
                                              New Name
                                              OverlayLayout MainItem TextNode FocusImage RenderNode EntryName In the Scene Tree panel select the List (Group2D). In the Properties panel  [ Transformation ] section configure the position and size according to the following table.
                                                In Scene Editor the Position and size of the selected rectangle is adjusted according to the new settings.
                                                      Target Item
                                                Transformation
                                                Layout
                                                Position X Position Y Size X Size Y List (Group2D)
                                                58
                                                134
                                                300
                                                300
                                                Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
                                                Select [ Expand Control Node ] from the context menu of List in Scene Tree panel.
                                                Open List and select [ Expand Control Node ] from the context menu of the Scrollbar.
                                                Select the List in Scene Tree and choose [ Save as Control... ] from List context menu. Then Add New Templates dialog will appear and press [ OK ] button. As the result of that, you can add the control as a customizable control in Solution Explorer's Solution > Controls. After confirming this addition, delete List group node in Scene Tree panel.
                                                You have now created a customizable List control.
                                                Select [ Control Properties... ] from List context menu of Solution Explorer's Solution > Controls. The Configure Public Control Properties dialog will appear, check Is Public for ScrollbarVisibility under Internal properties, and press [ OK ] button.
                                                Delete the expanded List Control from SceneOptions in the Scene Tree Panel. Drag and drop the newly created List from Solution Explorer's Solution > Controls to Scene Tree panel's SceneOptions > Devices.
                                                Set Scrollbal Visibility (Properties > Control) of List to "Visible."
                                                Double-click on the List in the Devices group to customize it on Scene Tree.
                                                Select the "Thumb" button and replace its images as follows:
                                                Then select the "VerticalPrevItem" button from inside the PrevItem group node and replace the images as follows:
                                                Lastly, select the "VerticalNextItem" button from inside the NextItem group node and replace the images as follows:
                                                We want a main list with a sub-list that will expand when an item in the main list is clicked.
                                                To do that, first we need a Group Node with an OverlayLayout which will contain the device entry name and the focus image. Therefore, drag a Render Node and a TextNode from the ToolBox "Nodes 2D" into the OverlayLayout.
                                                Rename the OverlayLayout to "MainItem".
                                                Rename the RenderNode to "FocusImage".
                                                Rename the TextNode to "EntryName".
                                                The "MainItem" you have now assembled will be the main list item that will be visible.
                                                Set the position of the GroupNode List to X:58 and Y:134 and configure its size to X:300 and Y:300.
                                                In our list the currently selected main list item shall be highlighted with an orange outline.
                                                Therefore drag a BitmapBrushColorBlend effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side of the Scene Tree Panel and set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
                                                Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
                                                In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox to the List's ListContentGroup.
                                                The Sub-List control has a SublistAnchor. Drag a StackLayout onto this SubListAnchor. Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".
                                                The resulting structure should look like this:
                                                The next step is to configure the TextButton:
                                                • Scale: X:0.75 and Y:0.75.
                                                • Margin Left: 12
                                                • Text: "Connect".
                                                The TextButton's images (Normal Image, Pressed Image and Focused Image) need to be adjusted:
                                                Copy and paste the TextButton to make another copy. Rename the other as "TextButton_Unpair", and set its Text property to "Unpair". Resulting structure should look like this:
                                                Setting up the "Devices" List behaviors
                                                Focus Handling behaviors
                                                For the Devices entry items, we need to set the behaviors for focus handling. We want the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
                                                Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
                                                Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
                                                Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
                                                This is what the configured Behaviors look like now:
                                                As soon as the MainItem gets the focus, the FocusImage shall be visible. Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
                                                As soon as the MainItem loses the focus, the FocusImage shall be made invisible again. Therefore you have to configure the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
                                                If you run CGI Player and click on a list item, an orange highlight should indicate that this item is in focus.
                                                Sub-List Handling behaviors
                                                In the "Check Logic Condition" properties, set the Operation to "Or", since we want the condition to be either a click or a key input.
                                                The "Check Key Input" condition, checks if the enter key is pressed. Therefore the KeyCode property will be set to "Key_Enter".
                                                The action that shall be performed is a "Set Control State" behavior, which will actually enable the Sub-List when the condition above is met. Please drag it onto the Actions part of the "Action on Value" behavior and configure it as depicted below.
                                                Add another "Action on Value" behavior with a "Check processed Value" condition and "Set Control State" action, same as above. But this time, set the ConditionValue property of "Check processed Value" condition to false (Bool + unchecked). And set the "ChangeTo" property of "Set Control State" to false (unchecked).
