GettingStartedControls Part 3
In
depending
(Phoneon Connection)the Optionsitem Scene
selected in the List.
OurAnd this is what the final scene will look like this:like:
Our
Preparing is to create a Phone Connectionthe Options scene
Name
Importing Images
The
Configuring scenethe isBackground
Group
Connection BitmapNode Background Group_1
Devices BitmapNode Background
Path
/Resources/Options/ConnectionOptionsENBOSBmp In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
Position X
Position Y
Connection
78.0058.00
Devices
58.00
Position X
Position Y
Dial
163.00
Path
Knob Image
/Resources/Options/NewDial_arrow_middleBmp In the Properties panel's [ Control ] section click on the the "BackgroundImages" section.
Image Path
BackgroundImages 0 /Resources/Options/NewDial_background_leftBmp BackgroundImages 1
/Resources/Options/NewDial_background_middleBmp BackgroundImages 2
Pivot Hint Y
88,00
NewDial_background_leftBmp true130,50
130,50 NewDial_background_middleBmp true
130,50 130,50 NewDial_Background_rightBmp true
130,50 130,50
Before
First, drag two Group Nodes from the Toolbox into the Scene Tree.
Select oneresult of the BitmapConnection Nodepart can be seen in the Scene Tree Panel. Then, select the BitmapBrushBlend Effect and set the Image property to the recently imported background image as shown below: And do the same for the other Bitmap Node.
Change the Position property of "Connection" to X: 78 and Y: 58. Change the Position property of "Devices" to X: 551 and Y: 58. Now we have two background images for Connection group and Devices group.
Setting up the "Connection" Nodes
Drag a Dial Control to the "Connection" Group Node. Set the Position property to X: 72.00 and Y: 163.00.
Replace the default background images to images from recent import, as follows:
In order to arrange the images of the Dial correctly, the "Pivot Hint" property of each image should be set. This step is necessary for images like the Dial image, which need to rotate. To do this, go to the Solution Explorer panel, and select each of the following images:
For the knob image "NewDial_arrow_middleBmp", enable the "Pivot Hint" property and set the values as follows:
As you can see the knob needs to be repositioned to be in the center of the Dial.
Select the three other background images (multiple selection), enable the "Pivot Hint" property and set the pivot hint as follows:
Add 4 Text Nodes to "Connection" Group Node and move them below Background Node with Ctrl key dragging. Rename them as follows:
Configure the Text Nodes with the following values: Text Style should be OpenSans25.
| TextNode Name | 2D Text Node |
Make sure that the "Background" is the first (top) item in the "Connection" group in order to appear in the background and not cover other nodes.
At this point, you will now have created the Connection options Dial:
Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
Select [ Expand Control Node ] from the context menu of List in Scene Tree panel.
Open List and select [ Expand Control Node ] from the context menu of the Scrollbar.
Select the List in Scene Tree and choose [ Save as Control... ] from List context menu. Then Add New Templates dialog will appear and press [ OK ] button. As the result of that, you can add the control as a customizable control in Solution Explorer's Solution > Controls. After confirming this addition, delete List group node in Scene Tree panel.
You have now created a customizable List control.
Select [ Control Properties... ] from List context menu of Solution Explorer's Solution > Controls. The Configure Public Control Properties dialog will appear, check Is Public for ScrollbarVisibility under Internal properties, and press [ OK ] button.
Delete the expanded List Control from SceneOptions in the Scene Tree Panel. Drag and drop the newly created List from Solution Explorer's Solution > Controls to Scene Tree panel's SceneOptions > Devices.
Set Scrollbal Visibility (Properties > Control) of List to "Visible."
Double-click on the List in the Devices group to customize it on Scene Tree.
Select the "Thumb" button and replace its images as follows:
Then select the "VerticalPrevItem" button from inside the PrevItem group node and replace the images as follows:
Lastly, select the "VerticalNextItem" button from inside the NextItem group node and replace the images as follows:
We want a main list with a sub-list that will expand when an item in the main list is clicked.
To do that, first we need a Group Node with an OverlayLayout which will contain the device entry name and the focus image. Therefore, drag a Render Node and a TextNode from the ToolBox "Nodes 2D" into the OverlayLayout.
Rename the OverlayLayout to "MainItem".
Rename the RenderNode to "FocusImage".
Rename the TextNode to "EntryName".
The "MainItem" you have now assembled will be the main list item that will be visible.
Set the position of the GroupNode List to X:58 and Y:134 and configure its size to X:300 and Y:300.
In our list the currently selected main list item shall be highlighted with an orange outline.
Therefore drag a BitmapBrushColorBlend effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side of the Scene Tree Panel and set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox to the List's ListContentGroup.
The Sub-List control has a SublistAnchor. Drag a StackLayout onto this SubListAnchor. Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".
The resulting structure should look like this:
The next step is to configure the TextButton:
- Scale: X:0.75 and Y:0.75.
- Margin Left: 12
- Text: "Connect".
Copy and paste the TextButton to make another copy. Rename the other as "TextButton_Unpair", and set its Text property to "Unpair". Resulting structure should look like this:
Setting up the "Devices" List behaviors
Focus Handling behaviors
For the Devices entry items, we need to set the behaviors for focus handling. We want the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
This is what the configured Behaviors look like now:
As soon as the MainItem gets the focus, the FocusImage shall be visible. Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
As soon as the MainItem loses the focus, the FocusImage shall be made invisible again. Therefore you have to configure the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
If you run CGI Player and click on a list item, an orange highlight should indicate that this item is in focus.
Sub-List Handling behaviors
