GettingStartedControls Part 3
In Part 3 of the GettingStartedControls Sample we will create a (Phone Connection) Options scene. This scene offers the possibility to choose the connection type (Cable, Bluetooth and other) from a Dial Control on the left side. On the right side is a List with Sub-List Controls. The Sub-List Control will appear depending on the item selected in the List.
Preparing the Options scene
- Create a new scene via the menu "Scene" - "New 2D Scene" or press < Ctrl+2 > on your keyboard
- The "Add New Scene 2D" dialog will be opened.
- In the first row select "/Scenes" from the drop-down menu. Enter "SceneOptions" as name and press [ OK ]. We use the prefix "Scene" to have all scenes listed next to each other in the Solution Explorer panel.
- A new scene "SceneOptions" is created and visible in the Solution Explorer panel in folder "Scenes".
- The new scene is opened in the Scene Editor and in the Scene Tree panel.
- In the Scene Tree panel you can see that the scene already has a camera.
- In the Render Targets panel you can see that the camera is already added to the RenderTarget.
- In the Render Targets panel check the checkbox of "SceneOptions\Camera" in order to enable rendering.
- In the Render Targets panel select the SceneOptions\Camera. In the Properties panel's [ Camera ] section change the sequence number to 2.
- The camera's sequence number is set to 2.
- In the Scene Tree panel the red Information/Warning/Error square disappears.
Importing Images
Configuring the Background
- From the Toolbox panel's [ Node 2D ] section drag a 2D Group nodes into the Scene Tree directly onto the node "SceneOptions".
- In the Scene Tree panel you can see a 2D Group node.
- From the Toolbox panel's [ Node 2D ] section drag a BitmapNodes onto the 2D Group node.
- In the Scene Tree panel you can see that a BitmapNodes has been created.
- In the Scene Tree panel select the 2D Group and create a copy either via the context menu entries "Copy" and "Paste" or via the keyboard <Ctrl>+C and <Ctrl>+V.
- A copy of the 2D Group with its BitmapNode has been created.
- In Scene Tree panel the name of the copy is "Group_1".
- In the Scene Tree panel select the nodes added in the steps before one after the other and rename them either via the context menu entry "Rename" or by pressing <F2> on your keyboard. Apply the names provided in the table below.
- In the Scene Tree panel you can see that the nodes have been renamed.
Target Item Name Group Connection BitmapNode Background Group_1 Devices BitmapNode Background
- In the Scene Tree panel select both BitmapNodes called "Background". This can be achieved by selecting one BitmapNode, holding down the <Ctrl> key and keeping it pressed while clicking on the second BitmapNode. In Scene Tree panel's right side select the "BitmapBrushBlend" effect. In the Properties panel's [ Effect ] section click on the magnifying glass icon next to the Image property.
- In the Properties panel you can now edit the BitmapBrushBlend effect for both BitmapNodes.
- The "Choose Item" dialog will be opened.
- In the "Choose Item" dialog select the image as in the table below and click [ OK ].
- The Choose Item dialog will be closed.
- In the Scene Editor a background image is visible displaying a vertical grey-black gradient.
Property Path Image /Resources/Options/ConnectionOptionsENBOSBmp
- In the Scene Tree panel select the "Connection" group. In the Properties panel's [ Transformations ] section adjust the "Position" property according to the table below. Repeat this step with the "Devices" group.
- In Scene Editor two rectangles with a gradient background are visible.
Target Name Position X Position Y Connection
78.00 58.00 Devices
551.00 58.00
- From the Toolbox panel's [ Controls ] section under Touchable drag a Dial control into the Scene Tree panel directly onto the "Connection" group.
- In the Scene Tree panel a Dial control has been added into the "Connection" group.
- In the Scene Editor the Dial control is visible in the top left corner of the left gradient image.
- In the Scene Tree panel select the Dial control. In the Properties panel's [ Transformation ] section adjust its position according to the table below.
- In the Scene Editor the Dial control is positioned in the lower center of the gradient image.
Target Name Position X Position Y Dial
72.00 163.00
- In the Properties panel's [ Control ] section click on the magnifying glass icon next to property "Knob Image".
- In the Scene Editor an orange ring will become visible.
Property Path Knob Image /Resources/Options/NewDial_arrow_middleBmp
- In the Properties panel's [ Control ] section click on the the "BackgroundImages" section.
- In the Properties panel the "BackgroundImages" section will be expanded.
- In the Properties panel click on the magnifying glass next to "BackgroundImages 0".
- In the Choose Item dialog navigate to "/Resources/Options/NewDial_background_leftBmp", select this image and click [ OK ].
- In the Properties panel the first BackgroundImage has been configured.
- Repeat steps 4 and 5 to configure the remaining BackgroundImages as in the table below.
- In Properties panel all BackgroundImages are configured.
- In Scene Editor you can see the newly configured images.
StateImages Image Path BackgroundImages 0 /Resources/Options/NewDial_background_leftBmp BackgroundImages 1 /Resources/Options/NewDial_background_middleBmp BackgroundImages 2 /Resources/Options/NewDial_background_rightBmp
- In the Solution Explorer panel select the new Knob Image "/Resources/Options/NewDial_arrow_middleBmp". In the Properties panel's [ Bitmap ] section enable "Pivot Hint" by checking the respective checkbox.
- A new property "Pivot Hint" becomes visible.
- Configure the "Pivot Hint" as in the table below.
- The Pivot Hint for the Knob Image is configured correctly.
- In the Solution Explorer select the three images that were configured as BackgroundImages. In the Properties panel proceed similar to steps 10 and 11, enabling and configuring the Pivot Hint of these three images according to the table below.
- The Pivot Hint is configured correctly.
- In Scene Editor the Dial's images are neatly aligned. The images have a common center.
Target Name Enable Pivot Hint Pivot Hint X Pivot Hint Y NewDial_arrow_middleBmp true 84,50 88,00
NewDial_background_leftBmp true 130,50 130,50 NewDial_background_middleBmp true 130,50 130,50 NewDial_Background_rightBmp true 130,50 130,50
- From the Toolbox panel's [ Nodes 2D ] drag and drop a TextNode into the Scene Tree panel directly onto the "Connection" group node.
- In the Scene Tree panel a TextNode will become visible.
- In the Scene Editor the text "Text" will appear.
- In the Scene Tree panel select the new TextNode. In the Properties panel's [ 2D Text Node ] section click on the magnifying glass icon next to property "Style".
- The "Text Style Palette" dialog will be opened.
- In the "Text Style Palette" dialog select "OpenSans25" and click [ OK ].
- In Scene Editor the Text Style of the TextNode will change.
- In the Scene Tree panel right click onto Connection and select "Clone..." from the context menu.
- The "Clone Item" dialog will be opened.
- In the "Clone Item" dialog change to the "Multiple Clone" tab. Configure "Number of Copies" to "3" and click [ OK ].
- In the Scene Tree panel 4 TextNodes are now available inside the "Connection" group.
- In the Scene Tree panel select the newly created TextNodes one after the other and configure their names in the Scene Tree panel and the remaining properties in the Properties panel as in the table below.
- The TextNodes are fully configured.
- The final result of the Connection part can be seen in the images below.
TextNode Name 2D Text Node Transformations Text Position X Position Y TextNode_Connection Connection 141 61 TextNode_Bluetooth Bluetooth 149 134 TextNode_Cable Cable 20 200 TextNode_Other Other 315 200
Setting up the "Connection" Nodes
Add 4 Text Nodes to "Connection" Group Node and move them below Background Node with Ctrl key dragging. Rename them as follows:
Configure the Text Nodes with the following values: Text Style should be OpenSans25.
Make sure that the "Background" is the first (top) item in the "Connection" group in order to appear in the background and not cover other nodes.
At this point, you will now have created the Connection options Dial:
Next step is to customize an existing List control and set its color of the Scrollbar to orange (original color is blue). At first, drag and drop List Control from ConstructionKit > Controls in Solution Explorer onto SceneOptions in Scene Tree panel.
Select [ Expand Control Node ] from the context menu of List in Scene Tree panel.
Open List and select [ Expand Control Node ] from the context menu of the Scrollbar.
Select the List in Scene Tree and choose [ Save as Control... ] from List context menu. Then Add New Templates dialog will appear and press [ OK ] button. As the result of that, you can add the control as a customizable control in Solution Explorer's Solution > Controls. After confirming this addition, delete List group node in Scene Tree panel.
You have now created a customizable List control.
Select [ Control Properties... ] from List context menu of Solution Explorer's Solution > Controls. The Configure Public Control Properties dialog will appear, check Is Public for ScrollbarVisibility under Internal properties, and press [ OK ] button.
Delete the expanded List Control from SceneOptions in the Scene Tree Panel. Drag and drop the newly created List from Solution Explorer's Solution > Controls to Scene Tree panel's SceneOptions > Devices.
Set Scrollbal Visibility (Properties > Control) of List to "Visible."
Double-click on the List in the Devices group to customize it on Scene Tree.
Select the "Thumb" button and replace its images as follows:
Then select the "VerticalPrevItem" button from inside the PrevItem group node and replace the images as follows:
Lastly, select the "VerticalNextItem" button from inside the NextItem group node and replace the images as follows:
We want a main list with a sub-list that will expand when an item in the main list is clicked.
To do that, first we need a Group Node with an OverlayLayout which will contain the device entry name and the focus image. Therefore, drag a Render Node and a TextNode from the ToolBox "Nodes 2D" into the OverlayLayout.
Rename the OverlayLayout to "MainItem".
Rename the RenderNode to "FocusImage".
Rename the TextNode to "EntryName".
The "MainItem" you have now assembled will be the main list item that will be visible.
Set the position of the GroupNode List to X:58 and Y:134 and configure its size to X:300 and Y:300.
In our list the currently selected main list item shall be highlighted with an orange outline.
Therefore drag a BitmapBrushColorBlend effect from the ToolBox onto the FocusImage node. Now select the BitmapBrushColorBlend Effect on the right side of the Scene Tree Panel and set its Image to the BorderFocusedBmp image (which is part of the ConstructionKit) and its Color properties as follows:
Now, select the FocusImage node and change its layout properties: Set the StretchBehavior to "Fill".
In the following steps we will create a sub-list. Drag a Sub-List control from the Toolbox to the List's ListContentGroup.
The Sub-List control has a SublistAnchor. Drag a StackLayout onto this SubListAnchor. Now, drag a TextButton into the StackLayout and change its name to "TextButton_Connect".
The resulting structure should look like this:
The next step is to configure the TextButton:
- Scale: X:0.75 and Y:0.75.
- Margin Left: 12
- Text: "Connect".
Copy and paste the TextButton to make another copy. Rename the other as "TextButton_Unpair", and set its Text property to "Unpair". Resulting structure should look like this:
Setting up the "Devices" List behaviors
Focus Handling behaviors
For the Devices entry items, we need to set the behaviors for focus handling. We want the item to be highlighted only when it is focused. So first, we need to disable Rendering of the FocusImage by default. In the FocusImage properties, uncheck "Enable Rendering":
Next, in order for the "MainItem" Group Node to send events such as Focus Event when clicked, we have to add a "Handle Control State" behavior (Behaviors > Control > Internal) to MainItem Group Node.
Then, to handle these events received, add a "Focus" and "FocusLeave" Event Handler from the Toolbox under Behaviors > Control onto the MainItem Group Node.
Under each "Actions" of each Focus Event Handler, add an "Enable Rendering" behavior from the Toolbox under Behaviors > Action > Property.
This is what the configured Behaviors look like now:
As soon as the MainItem gets the focus, the FocusImage shall be visible. Therefore you have to configure the "EnableRendering" behavior of the "Focus" Event Handler as follows: Set the "Visible" property to TRUE and configure the scene's "FocusImage" as TargetNode. To do this, click the magnifying glass icon and selecting the "FocusImage" in the Choose Item dialog.
As soon as the MainItem loses the focus, the FocusImage shall be made invisible again. Therefore you have to configure the "EnableRendering" behavior of the "FocusLeave" Event Handler as follows: Set the "Visible" property to FALSE. The scene's "FocusImage" has to be configured as TargetNode similar to the steps above.
If you run CGI Player and click on a list item, an orange highlight should indicate that this item is in focus.
Sub-List Handling behaviors
