CGI Studio Smart Importer
Use the Smart Importer to quickly and easily import digital assets to your solution. With AI assistance you can assign functional HMI controls to elements within your design in a straightforward manner. Several other useful features are included, such as layer merging or multiple scene support.
With the Smart Importer you can import Photoshop files or files in Candera’s “XML Scene Composer Intermediate Format” (xscil) into your Scene Composer solution.
The Smart Importer uses Artificial Intelligence (AI) to analyze the content of the imported PSD or XSCIL file. The AI, that classifies HMI controls, has been implemented as Windows Service – ControlsAIService. The tray application ControlsAIApp will help you monitor and control this service.
Setup the Environment for Smart Importer
Setting up the ControlsAIService
Before you can start using the Smart Importer, you have to register the ControlsAIService as a Windows Service. Once it is installed, the service can be started and managed via command shell or by using the Windows Service Interface. Lastly, ControlsAIApp needs the be run and started
Starting and stopping a service wil require Administrator rights on that computer since Windows 10.
Register ControlsAIService Using the Command Shell
To register the ControlsAIService using the command line, start the command shell as Administrator. To do this, type “cmd”into the Windows menu, right-click and choose “Rund as Administrator” from the shortcut menu or “cmd.exe”.
To create the ControlsAIService use the following command:
sc create "ControlsAIService" binPath= "<absolute_path>/ControlsAIService.exe"
You have to provide the absolute path to the executable to register a service, which can be found in folder bin/AI/ControlsAIService/.
To start the ControlsAIService you can use the following command in the command shell (as administrator). Alternatively, you can manage the service with the Windows Service Interface or using the provided ControlsAIApp.
sc start "ControlsAIService"
The ControlsAIService will start the actual AI application called ControlsClassification.exe. You can see this process in the Task Manager whenever the ControlsAIService is running.
To unregister the service (in case it is not needed anymore), please ruin the following command:
sc delete "ControlsAIService"
Manage the ControlsAIService Using the Windows Service Interface
After ControlsAIService is created, it can be started/stopped using Windows Services. Type “Services” into the Windows menu to start the “Services” application. You can start and stop the ControlsAIService from within this list with the links on the left, or buttons on the menu bar, or by using the shortcut menu.
Using the Properties entry of the shortcut menu, you can find more options for the Service. Here you can e.g. configure the service to be started on every system startup by setting the startup type to “Automatic”.
Start the ControlsAIApp tray application
After ControlsAIService is running, start the ControlsAIApp. Run the tray application in <CGI_STUDIO_ROOT>/bin/AI/ControlsAIApp/ControlsAIApp.exe with administrator privileges by right-clicking the ControlsAIApp.exe and selecting “Run as Administrator”. After starting the application, you can see a tray icon in the taskbar on the bottom right of the screen.
Right-clicking on the tray icon will open a menu that allows you to control the ControlsAIApp’s states. Select Start to start the AI. After a few seconds with a flashing yellow dot, the tray icon indicates that the AI is started, when the dot turns green.
How to Use the Smart Importer
Select File for Smart Importer
The Controls AI Service will analyze imported files to detect, propose and create controls for your Scene Composer solution. Use the Import > Smart Importer… option from the menu bar to open the dialog box for the Smart Importer.
After choosing “Smart Importer…” from the menu, select which file (.psd or .xscil) to import using the “Open” dialog box.
Smart Importer Windows
Once you have selected a file to import, the Smart Importer window will be opened.
The Smart Importer window consists of the following panels:
(1) Preview
The preview panel displays a preview of the graphics file o be imported. You can use the mouse wheel to zoom in and out, with the zoom percentage displayed in the lower left corner of the preview panel. By pressing the button displaying four arrows, you can modify the preview image’s size within the panel’s maximum available space.
By clicking within the preview panel, you can select design elements from the displayed image. The AI will then attempt to detect and define a suitable control for the selected element.
(2) Import Settings
The import settings panel will allow you to select a destination folder to import template solutions. You can choose to create a custom imports folder, which will be created inside the destination folder.
In the Scenes section below, you can edit template scenes you are configuring with the Smart Importer. Use the shortcut menu to add, clone, remove, or rename scenes. To make modifications to the content from a particular scene, select the scene in the import settings panel (2), then check or uncheck the checkboxes next to the desired layers and controls in the layer tree (3).
With the “Toggle Applied Controls Preview” checkbox enabled, you can verify which portions of the displayed graphic already have a control applied to them. Portions which already have a control applied will be marked with a green outline in the preview panel (1).
By checking the “Resize Display Resolution” checkbox, the imported design will automatically resize itself to fit within the display resolution configured for your solution.
The “Import State Machine” option allows you to import state machines from your design file directly to your CGI Studio solution. If a global state machine already exists within your solution, a prompt will be displayed in which you can choose whether or not to import the new state machines with the IsGlobal property enabled.
(3) Layer Tree
The layer tree panel will display the elements imported from your graphic file as a branching list. The list displayed within this panel is equivalent to the template scene’s Scene Tree within Scene Composer. You can select one or multiple items within this list to begin the AI detection process. The filter bar located on top of the layer tree will allow you to more easily identify a specific layer when dealing with multiple layers.
Using the checkboxes, you can decide if a layer is part of the scene that is currently selected in the import settings panel (2). If you uncheck a layer’s checkbox for all scenes, the layer will not be imported.
(4) Control List, Appearance and Basic Properties
By selecting a layer, the AI service will attempt to detect which controls are suitable for the selected elements. The result of this analysis will be displayed in the ControlList panel, listing the candidate control from greatest to least probability. The list of controls can also be filtered using the input field on the top. Use the “Apply” button in the control list to apply a control to the selected element. If the AI has detected only a weak probability for your selected control, you will be prompted to confirm your choice.
After applying a control to a design element, you can then configure the control’s properties using the Appearance Tab. For example, you could select two images to represent both TellTale states, or modify the position of the pivot point for the gauge’s needle image. You can modify additional properties in the Basic Properties tab.
The status of the AI Service is displayed below the control list panel as plain text unless it is started but idle.
(5) AI Settings
In the AI Settings you can change the Transparent Background Color for AI detection. The selected color is used by the AI to analyze the graphics to be improved. It pretty much depends on the content of the image, which transparent background color works best for detecting controls. IN case the AI is having problems in detection controls, you can try to change this setting.
(6) Revert & Revert All
You can select an item in the layer tree panel (3) and revert the already applied control using the “Revert” button. You can choose to revert all applied controls in the “Layer Tree” by pressing the Revert All button. You will be prompted to confirm this action in order to keep you safe.
Configure Scenes
In the Import Settings Panel you can manage the scenes you want to import into Scene Composer. Opening the shortcut menu, you will see the available options: Add Scene, Close Scene, Remove Scene, and Rename Scene. Double-clicking on the scene’s name allows you to rename an existing scene.
If you choose to add a new scene or clone the existing scene, you will be prompted to input the name for the new scene.
The AddScene and Remove Scene options will be disabled when multiple scenes are included within the imported Intermediate Language file.
Configure the Scene’s Content
Let’s assume you got a graphic file from your designer with 2 scenes, an IVI scene (e.g. with a music player and climate control) and a Cluster scene. You will create two scenes in the Import Settings panel: an “IVI_Scene” and a “Cluster_Scene”. Select the “IVI_Scene” and adjust the visibility of the layers in the Layer Tree panel – only “IVI” and “Background_1” will be checked. Handle the “Cluster Scene” similarly – only “Cluster” and “Background_1” will be checked.
When clicking the OK button, the import is started. You can then see the imported scenes and resources in the Solution Explorer panel and in the Imports panel of Scene Composer.
Detection, Configuration and Import of a GaugeControl
When you import a graphics file that includes a gauge using the Smart Importer the AI will detect this control and import the template scene including the correctly identified gauge control-
To make the AI detect the gauge in your graphics file, open the graphics file with the Smart Importer (via the Menu: Import – Smart Importer and choose your graphics file). Your graphics file will be displayed in the “Preview” panel.
Now you can select your gauge by clicking on the corresponding graphics in the “Preview” panel. The Layer Tree panel will expand the layers and mark the layer you selected.
As an alternative, you can browse to the desired layer in the “Layer Tree” panel. If you know at least part the layer’s name, you may use the filter field in the top of the Layer Tree panel to find the correct layer more easily. The content you select in the “Layer Tree” panel will be highlighted with a yellow frame in the “Preview” panel.
Whenever you select any content – no matter if selecting single layers or multiple layers – the AI tries to detect known controls. You can see the list of detected controls in the “Control List” panel on the bottom right.
In our example the AI correctly detected a Gauge Control, so you will press the “Apply” button on the right. The Appearance Tab is put to the foreground, offering you the possibility to configure the GaugeControl’s NeedleImage and BackgroundImage. After performing this Layer Mapping, you will see the GaugeControl Layer in the “Layer Tree” panel and its content will be colored, indicating a successful application of the GaugeControl (blue font) and a successful mapping of the image (yellow font).
Configure the Pivot Point
For all images configured in the Layer Mapping, you can configure the pivot point in the Appearance Tab on the bottom right. In our example for the GaugeControl it is important that the pivot point of the needle image is set correctly in order to guarantee the correct movement of the needle in Scene Composer.
There are 3 ways to configure the pivot point:
      • Enter digits for the X/Y coordinate.
      • Freehand position a crosshair cursor using the mouse.
      • Configure the pivot point to be in the center of the image.
      • X/Y: You can choose this option to enter the X/Y coordinates for the pivot point in the following editor.
          • Freehand: If you choose this option, you can move the crosshair cursor to the desired pivot point in the “Bitmap Preview” panel.
              • Center: With this option, the pivot point will be configured to the center of the image. A center configuration of the pivot point will be indicated by the text “centered” in the Appearance tab.
              Configure Basic Properties
              The controls have been detected by the AI and you have applied them to your layers. In the appearance tab you have mapped your layers to images that are part of the controls (i.e. the gauge’s needle image and the background image). You can also define values for basic properties of the applied control.
              The following basic properties are available for the gauge control. To easily find our gauge control instance in Scene Composer after the import, you may also change its name to e.g. “Gauge_for_speed”.
              Individual properties from your design will be automatically mapped if the property’s name is the same as the control’s property name.
              Import to Scene Composer
              Once you are finished applying the detected controls and configuring images, pivot points and other properties, click the OK button to import your configured file.
              You can now see that the folder “AI_Advanced_Cluster_Sample§ has been created and the content of your psd file has been imported. The gauge control instance “Gauge_for_speed” you configured using the Smart Importer can be found in the “Imports” panel.
              You may create an instance of your “Gauge_for_speed” by dragging it into your scene – either into the Scene Editor panel or into the Scene Tree panel.
              7.3.5. Layer Merging
              Sometimes the graphics file to import will be quite complex, having several images for a gauge’s background and a few images for a gauge’s needle to achieve a brilliant HMI. The built in GaugeControl of Scene Composer however requires only one image for the background and one image for the needle. To meet the needs of both, complex graphics files and a clear implementation and configuration of the control, the Smart Importer is able to configure several layers for a single image of the control.
              In the following example the layers for the gauge’s background are marked in orange and the layers for the needle are marked in blue.
              Select the root of the gauge in the “Layer Tree” üanel that includes both the background images and the needle images. In our example this layer is called “LayerGroup”. In the “Control List” panel you will see that the AI has detected the GaugeControl. After pressing the “Apply” button next to the GaugeControl you can map the layers to the GaugeControl’s background and needle image.
              Useful Hints:
              • You can configure a complex layer group by selecting and configuring only the root. All its children will be configured similarly.
              • You can select multiple layers and configure them all at once. For multi selection you can keep the <ctrl> or <shift> key pressed while selecting the layers with a mouse click or you can click-and-drag a box around the layers you want to select.
              Finalize the configuzration of your GaugeControl by setting the NeedleImage’s pivot point to exactly that point where the needle should rotate around as described in Configure the Pivot Point.
              After the configuration is complete you can press the “OK” Button of the Smart Importer to import your graphics file and the configured GaugeControl Instance into SceneComposer.
              Smart Importer has created a single image for the needle and a single image for the background as you can see in the Solution Explorer.
              To test the functionality of the GaugeControl, drag and drop the configured GaugeControl instance to the scene (as described in Import to Scene Composer). When altering the GaugeControl’s value in the Properties panel, the needle of the GaugeControl in the Scene Editor panel will rotate in front of the background according to the alteration of the Control’s value.
              7.3.6.
              Re-Importing of Graphics Content
              When importing the same content to the same location once again, the resources and scenes in Scene Composer are overwritten. This allows you to replace outdated graphics of your scene with newly updated graphics from your designer while maintaining the mapping between layers and controls.
              7.3.6.1.
              Reload Configuration for New Graphics File
              If you use the Smart Importer to open the same graphics file (same path, same filename) again, which you have already made configurations to, you will see your configurations are available again (marked with orange font in the layer tree panel). The applied controls as well as the Layer Mapping have been loaded.
              You will be notified by blue information icons that the import target folder or the scene already exist (A tooltip gives you the necessary information once you hover those icons). Starting the import as currently configured will overwrite already imported resources and scenes and therefore update the graphics of your Scene Composer solution to the newest graphics version, while keeping the information of mapped layers and applied controls.
              Figure 76 – Loaded Configuration when Re-Importing a Graphics File.
              Note: If you want to import graphics content to your Scene Composer solution for a second time, maintaining the resources and scenes from both imports, you can choose a different import location or a different scene name.
              7.3.6.2.
              Re-Import of a Graphics File with Different Layers
              When importing a graphics file with the same path and filename but partially different layers, you will see the configuration of the layers that are still available has been loaded.
                The orange font indicates that a bitmap from the node assigned to the control is currently in use within another control.
                • Layers that had not been part of the graphics file before will be displayed in green font. They are not visible in the preview panel since they are disabled by the layer tree panel’s checkbox.
                • Layers that are missing in the currently loaded file are displayed in red font in the layer tree panel. The content of layers that are not available in the currently loaded graphics file cannot be displayed since the image data is simply missing. Checking the checkbox in the layer tree panel won’t make any change in the preview panel.
                Figure 77
                – New Layers and Deleted Layers when Re-Importing a Graphics File
                7.3.6.3.
                Restore a Configuration
                If you have already imported a graphics file into a certain folder and you are attempting to import the same graphics file to the same folder again, the Smart Importer will load the configuration you applied last time. If you are reverting your configuration using the Revert All button, the loaded configuration is gone. However, the configuration of the last successful import is still saved with the lastly imported scene. So, changing the import location and changing it back to the original import location, where the configuration is saved, makes a dialog pop up asking you whether you want to restore the saved configuration.
                Choose Restore to restore the configuration from your last import or Cancel to start configuring all over again.
                Figure 78 – Restore Configuration Dialog
                7.3.6.4.
                Merge Configurations
                A configuration that has been imported to Scene Composer is saved to the imported scene. You can use one graphics file, import various configurations to Scene Composer and merge them together into one final configuration.
                I. Create Configurations
                1.
                  Open your Cluster graphics file using the Smart Importer, configure the Telltale controls and import them to folder Cluster_Telltales for example.
                  2. Open the graphics file again and configure the Gauge Controls; import them to folder Cluster_Gauge.
                  3. Once again open the graphics file and configure the ProgressBar Controls; import them to folder Cluster_ProgressBar.
                  Figure 79 – Cluster_TellTales
                  Figure 80 – Cluster_Gauge
                  Figure 81 – Cluster_ProgressBar
                  II. Merge Configurations
                  1.
                  1. If you now open the Cluster graphics file again and set the import folder to Cluster_Telltale you can restore the configuration for your Telltale controls by clicking Restore in the Restore a Configuration dialog.
                    2.
                  2. Now, change the import folder to Cluster_Gauge, which triggers the following dialog, where you choose Merge to add the Gauge configuration to the currently loaded Telltale configuration.
                    Figure 82
                  Merge Configuration Dialog
                  3.
                  Change the import folder to Cluster_Progressbar and merge the configuration of the progressbars to your currently loaded and merged configurations.
                  And finally, you’ll end up with a configuration having applied TellTale Controls, Gauge Controls and ProgressBar Controls.
                  Advanced Configuration of PSD Content for Import to Scene Composer
                  Import Bitmap Resources
                  Images of Image Layers in psd data are imported as Bitmap Resources. By default, the value of the Pivot Hint of imported Bitmap Resources is calculated to be in the center as follows:
                  Pivot Hint X = Image Layer width /2
                  Pivot Hint Y = Image Layer height /2
                  You can set the Pivot Hint in Photoshop by embedding the token into the layer’s name. The Pivot Hint tokens are removed from the Bitmap Resource name upon import.
                  E.g. 1: If the layer’s name in the photoshop file is "Image@X30.5@Y40"
                  the Bitmap resource name will be “Image”,
                  Pivot Hint X = 30.50
                  Pivot Hint Y = 40.00
                  E.g. 2: If the layer’s name in the photoshop file is "ImageData@Y40.55"
                  the Bitmap resource name will be “ImageData”,
                  Pivot Hint X = "ImageData@Y40.5" layer width / 2
                  Pivot Hint Y = 40.55
                  TextStyle
                  When importing a Text Layer into Scene Composer, a new TextStyle is created. Its name will be a combination of the font name and the font size used in the Text Layer of the PSD file. Upon creation of a new TextStyle Scene Composer checks if a font resource with the corresponding name is registered in the Scene Composer solution. In case no suitable font resource has been found in the solution, a new TextStyle will be created using the font resources displayed in the “Not imported font” dialog.
                  Fonts that are not imported are also marked with a warning sign in the “Layer Tree” panel. A tooltip offers additional information:
                  Technical Details
                  Collaboration of Scene Composer, ControlsAIService and ControlsAIApp
                  Scene Composer comes with two additional applications that are needed to make the AI detection work:
                    ControlsAIService: A windows service application that provides the AI data for Scene Composer.
                    ControlsAIApp: A tray icon application that controls the service.
                    The following diagram explains the collaboration of the Scene Composer, the ControlsAIService and the ControlsAIApp:
                    XML Scene Composer Intermediate Format – XSCIL
                    XML Scene Composer Intermediate Format (XSCIL) is an open and well-defined format which has been invented to export graphics data from various user experience design tools (Axure RP, Adobe XY, Sketch etc.) and import them into Scene Composer via the Smart Importer. An API is available which you can use to implement an exporter for your favorite graphics editor, if it isn’t already available.
                    These are the recommended steps for Photoshop layers’ naming and structure of a Control when creating a PSD file with Adobe Photoshop. Tis procedure makes it easier to apply properties to a Control via the Smart Importer.
                      Create a group for the target Control – in this case, a TextButton (blue highlight in Figure below)
                      Create layers for the properties of the Control under the group created in step 1. Restore(red TellTalesand 2.green Mergehighlight Gaugein ControlsFigure 3.88 Mergebelow)
                      ProgressBars
                      Set
                      the names of the layers to be the same as the property names of the target Control. (layers names in Figure 88 below correspond to property names in Figure 89)
                        The group name is arbitrary.
                        For the layer name, use the property name but remove the spaces. For example, “Normal Image” becomes “NormalImage”.
                        Figure 90 –shows Restorethe TellTalesSmart Importer dialog when a PSD file following the correct format is opened.
                        In the Smart Importer dialog, if you apply the TextButton control to the TextButton node, the layers of the PSD file will be reflected in each property as shown in Figure 8391. –
                        Merge
                        Gauge
                        Figure  shows the Properties panel after import settings shown in Figure 91. The contents/layers of the PSD file are reflexted in the Properties panel.
                        In Figure 92, when Button is applied instead of TextButton, Text property is not applied correctly since a Button control does not have this property.
                        7.5.1. Layer Structure and Naming Guideline for Controls
                        Figure
                        84
                        In –Mergegeneral, ProgressBarsit is recommended to keep the PSD layer format close to the standard Controls. Below is a guide on how the layers for some Controls should be formatted and named.
                        AnalogClock  Breadcrumb CheckBox
                          SecondsNeedleImage
                          MinutesNeedleImage
                          HoursNeedleImage
                          FaceImage
                            Name
                            EllipsisText
                            Button
                            NormalImage
                            PressedImage
                            FocusImage
                              NormalImage
                              PressedImage
                              SelectedImage
                              SelectedPressedImage
                              FocusedImage  CircularSlider  Gauge  GroupBox
                                BackgroundImage
                                ActiveImage
                                ThumbImage
                                ThumbImagePressed
                                FocusImage
                                  NeedleImage
                                  BackgroundImage
                                    BackgroundImage   IconButton  InputField Menu Icon
                                      NormalImage
                                      PressedImage
                                      FocusedImage
                                      IconNormalImage
                                      IconPressedImage
                                      IconFocusedImage
                                        CaretImage
                                        BackgroundImage
                                        FocusedImage
                                          BackgroundImage  Menu Item Menu Screen Mesh2D
                                            FocusImageOnSelection
                                            FocusImageOnDragging
                                            DeleteButtonNormalImage
                                            DeleteButtonPressedImage
                                              BackgroundImage
                                              FocusBorderImage
                                                Image  MultiStateButton PageIndicator RadioButton
                                                  ButtonState1Bmp
                                                  ButtonState2Bmp
                                                  ButtonState3Bmp
                                                  ButtonState4Bmp
                                                  FocusedImage
                                                    PressedImage
                                                    SelectedIndicatorImage
                                                    IndicatorImage
                                                    SelectedIndicatorPressedImage IndicatorPressedImage
                                                      NormalImage
                                                      PressedImage
                                                      SelectedImage
                                                      FocusedImage   Roll SpinBox  TextButton
                                                        DecorationImage
                                                        TextEditBackground
                                                          BackgroundImage
                                                          ArrowUpNormalImage
                                                          ArrowUpPressedImage
                                                          ArrowDownNormalImage
                                                          ArrowDownPressedImage
                                                            Text
                                                            NormalImage
                                                            PressedImage
                                                            FocusedImage  ToggleButton TouchIndication
                                                              FirstImage
                                                              FirstPressedImage
                                                              SecondImage
                                                              SecondPressedImage
                                                              FocusedImage
