Advanced Cluster Part 3
In part 3 of this Best Practice the Custom_Gauge control will be further customized adding controls:
- A TextValue control to display the gauge's current value numerically
- A Text control above of the numeric value to display the gauge's scope (e.g. speed)
- Another Text control below the numeric value, which can be used to display the unit (e.g. km/h)
In order to make our control more versatile, various properties of our configured Custom_Gauge (like all images and text styles) will be made public.
Public Control Properties are those that can be configured when using a Custom_Gauge in a scene.
Create and Configure Two TextNodes and a TextValue Node
- In Scene Composer's Solution Explorer navigate to the path below and double-click on the "Custom_Gauge" control.
- The Scene Tree panel shows the Custom_Gauge control's tree.
- Scene editor displays the Custom_Gauge control.
Path in Solution Explorer Control Solution/Controls Custom_Gauge
- From the Toolbox panel's Nodes 2D section drag and drop a StackLayout into the Scene Tree panel directly onto the Custom_Gauge node.
- In the Scene Tree panel you can see that a StackLayout has been created directly under the Custom_Gauge node.
- From the Toolbox panel's Controls section under Common drag and drop 2 Text controls and 1 Text Value control into the Scene Tree panel directly onto the StackLayout.
- In the Scene Tree panel you can see the 2 Text controls and the Text Value control directly under the StackLayout.
- In the Scene Tree panel select the StackLayout as well as the 2 Text controls one after the other and rename them according to the table below either via the context menu entry "Rename" or by pressing <F2> on your keyboard.
- In the Scene Tree panel you can see that the Controls have been renamed.
Target Item New Name StackLayout StackLayout_Texts Text Text_Top Text_1 Text_Bottom
- In the Scene Tree panel re-arrange StackLayout_Texts and its contents via drag and drop until it looks like in the image below.
- The Scene Tree looks as in the image below.
- In the Scene Tree panel select StackLayout_Texts controls. In the Properties panel under Layouter and Layout adjust the properties as in the table below.
- In the Properties panel you can see that the correct values are set.
Property Value Layouter Arrangement Vertical Layout Vertical Alignment VCenter MinimumSize X 250.00 Y 0.00
- In the Scene tree panel select Text_Top, Text Value and Text_Bottom one after the other. In the Properties panel under Layout and Control configure the properties as in the table below.
- In the Scene Editor the texts are centered and the Text Value appears in a bigger font.
Property Text_Top Text Value Text_Bottom Layout VerticalAlignment VCenter VCenter VCenter HorizontalAlignment HCenter HCenter HCenter Control Text RPM - <empty String> Text Style OpenSans35
Vera96 OpenSans35 Text Alignment Center Center Center Text Format - %04d -
Configure the TextNodes' and TextValue Node's Position
- In the Scene Tree panel select StackLayout_Texts. In the Scene Tree panel's right side click on the [Fusion...] button.
- Fusion will be opened covering the Scene Editor.
- StackLayout_Texts Fusion diagram will be displayed. It only has one Fusion Node.
- In Fusion use the StackLayout_Texts' "Behaviors" connector to add 2 new Fusion Nodes: Connect 2 Value Processing > Value behaviors to the StackLayout_Texts Fusion Node.
Please check Fusion's Basic Operations documentation on how to add Fusion Nodes.
- In Fusion 2 new Fusion Nodes "Value" and "Value_1" have been created.
- In Fusion select and right-click on the behavior nodes and rename them according to the table below.
- In Fusion the Value behavior fusion nodes have been renamed.
Target Item New Name Value Value_TextPos_X Value_1 Value_TextPos_Y
- In Fusion use the Value behaviors' "Receivers" connectors to add a Value Processing > Transformation > SetPosition Fusion Node to each of them.
- In Fusion 2 new Fusion Nodes "Set Position" have been created, one of which is connected to Value_TextPos_X, the other to Value_TextPos_Y.
- In Fusion the Set Position behavior fusion nodes have been renamed.
Target Item New Name Value_TextPos_X > Set Position Set Position_X Value_TextPos_Y > Set Position Set Position_Y
- In Fusion configure the behaviors' Fusion Nodes according to the table below.
- In Fusion the Fusion Nodes' Properties have been changed.
- In Scene Editor the position of StackLayout_Texts has been changed. The texts are now neatly placed inside the Custom_Gauge control as you can see in the image below.
Fusion Node Property Set Position_X Set Position_Y TargetNode Custom_Gauge > StackLayout_Texts
Custom_Gauge > StackLayout_Texts TranslationAxis2D AxisX AxisY Property Value_TextPosX Value_TextPosY Variant (Float) 205 (Float) 230
Configure Value Forwarding and Maximum Value
- In Fusion add a Value Processing > Forward Value behavior to the Behaviors connector of the Custom_Gauge Fusion Node. Configure its TargetNode according to the table below.
- In Fusion the property will be changed accordingly.
Forward Value Fusion Node Property Value TargetNode Custom_Gauge > StackLayout_Texts > Text Value
- In Fusion in the ControlValueProvider Fusion Node configure the property Maximum according to the table below.
- In Fusion the the property is changed accordingly.
- Custom_Gauge's Fusion diagram will look as in the image below.
ControlValueProvider Property Value Maximum (Float) 6000.8000.00
Configure Public Control Properties
- In the Scene Tree panel right click "Custom_Gauge" and select "Control Properties..." from the context menu.
- The Configure Public Control Properties dialog will be opened.
- In the Configure Public Properties dialog the Properties which should be public to the user of the Custom_Gauge control need to be marked with the "Is Public" checkbox. Check the "Is Public" checkbox and eventually change the image properties' names according to the table and images below.
- Image properties necessary for using and configuring the Custom_Gauge will be made public.
- The Custom_Gauge control is now fully configured and ready to use.
Custom_Gauge > Group_Bitmaps > Property Is Public Source Name BackgroundImage > ProvideImageProperty x Image BackgroundImage NeedleImage > ProvideImageProperty x Image NeedleImage NeedleEffectImage > ProvideImageProperty x Image NeedleEffectImage ForegroundImage > ProvideImageProperty x Image ForegroundImage
- In the Configure Public Properties dialog check the "Is Public" checkbox and perform other configurations according to the table and images below.
The properties made public in this Configure Public Properties dialog will be configurable in the Properties panel's Controls section.
| Custom_Gauge > StackLayout_Texts > | |||
| Property | IsPublic | Source | Name |
| TextBottom | x | Text | Bottom_Text |
| x | TextColor | Bottom_TextColor | |
| x | TextStyle | Bottom_TextStyle | |
| Text_Top | x | Text | Top_Text |
| x | TextColor | Top_TextColor | |
| x | TextStyle | Top_TextStyle | |
| Text Value | x | FormatText | Value_FormatText |
| x | Style | Value_Style | |
| x | TextColor | Value_TextColor | |
| Behaviors > Value_TextPos_X | x | Variant | TextPosX |
| Behaviors > Value_TextPos_Y | x | Variant | TextPosY |
